rtems-libbsd build error
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Mon Mar 18 19:26:55 UTC 2019
Hi Christian,
On Sun, 17 Mar 2019 at 14:30, Christian Mauderer <list at c-mauderer.de> wrote:
> Am 16.03.19 um 23:52 schrieb Vijay Kumar Banerjee:
> > On Sat, 16 Mar 2019 at 01:00, Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> >     Am 15.03.19 um 19:20 schrieb Vijay Kumar Banerjee:
> >     > On Fri, 15 Mar 2019 at 21:47, Christian Mauderer
> >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
> >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> >     >     Am 15.03.19 um 15:48 schrieb Vijay Kumar Banerjee:
> >     >     > Hello,
> >     >     > I am trying to `./waf install` the libbsd but getting some
> >     error,
> >     >     need help
> >     >     > with that. The commands used and the errors are given below
> >     >     > configured using: `./waf configure
> >     --buildset=buildset/default.ini
> >     >     > --prefix=$HOME/development/rtems/5 --rtems-arch=arm`
> >     >     > configure was successful.
> >     >     > then : `./waf install`
> >     >     > Error ...
> >     >     > Build failed
> >     >     >  -> task in 'lex__nsyy' failed with exit status 1 (run with
> >     -v to
> >     >     > display more information)
> >     >     >  -> task in 'yacc__nsyy' failed with exit status 1 (run with
> >     -v to
> >     >     >  -> task in 'lex_pcap' failed with exit status 1 (run with
> -v to
> >     >     display
> >     >     > more information)
> >     >     >  -> task in 'yacc_pcap' failed with exit status 1 (run with
> >     -v to
> >     >     >  -> task in 'objs01' failed with exit status 1 (run with -v
> >     to display
> >     >     > more information)
> >     to display
> >     >     > more information)
> >     >     >  -> task in 'yacc_pfctly' failed with exit status 1 (run
> >     with -v to
> >     >     > Thanks
> >     >     > --vijay
> >     >     Hello Vijay,
> >     >     did you try to build before the install? I don't see the call.
> >     >     Normally it's
> >     >       waf configure ...
> >     >       waf
> >     >       waf install
> >     >     If you did that: It seems that some of the lex / yacc files
> >     should be
> >     >     regenerated. Did you enable --enable-auto-regen somewhen
> during an
> >     >     earlier configuration run (not necessary except if you import
> >     yacc or
> >     >     lex files)? Did you import some yacc or lex files?
> >     > I had to install `byacc` package using yum in fedora, then I used
> the
> >     > --enable-auto-regen
> >     > option, that worked.
> >     > However, it's still not building and I'm seeing a lot of warnings,
> I
> >     > think this is because of the
> >     > files I imported from the freebsd source, maybe they depend on some
> >     > other headers that
> >     > I didn't include. Any suggestion on how to debug, if this is the
> >     case?
> >     >     Best regards
> >     >     Christian
> >     Hello Vijay,
> >     normally you shouldn't need the --enable-auto-regen option. It only
> >     changes a lot of files that you don't want to change. Especially: If
> you
> >     use Fedora (or some other Linux) you get GPL licensed output. We
> >     normally use FreeBSD for that step and check in the generated files
> so
> >     that no user has to use --enable-auto-regen.
> >     Regarding how to start such a port: Normally it's a good idea to get
> >     some overview over what's missing. For that you import the files that
> >     you think are relevant (like you already did). Then you can build
> with
> >     `waf -k -j1` which continues even if some files are not compilable
> (-k
> >     is for continue, -j1 so that you receive the messages in order). You
> >     should get a lot of compiler errors during that run.
> >     Now comes the hard part: You have to analyse the errors and try to
> find
> >     out what's the reason for them. If some big part is missing you most
> >     likely get a lot of similar errors (like "header xy.h not found").
> Most
> >     likely you can identify some groups. With that you can estimate what
> has
> >     to be ported besides the files you already imported.
> >     Identifying these groups is a quite relevant step for planning the
> >     amount of work for your GSoC proposal. If you are unsure, try to ask
> on
> >     the mailing list. You can also post the build output and an
> assumption
> >     what groups you estimate to get some feedback.
> >     Best regards
> >     Christian
> > Hi
> > I figured out that there were some unnecessary imports I was doing and
> > also some necessary
> > header files that I'm missing, after adding those most of the warnings
> > vanished. The error I'm
> > seeing now is due to a missing '.m' header file. The error looks like
> > this ...
> >    ../../freebsd/sys/arm/ti/am335x/tda19988.c:56:10: fatal error:
> > rtems/bsd/local/iicbus_if.h: No such file or directory
> >  #include <rtems/bsd/local/iicbus_if.h>
> > There's an iicbus_if.m file in the freebsd source which is being
> included as
> > ``#include "iicbus_if.h"``
> > How to work with the .m files ?
> > Thanks
> Hello Vijay,
> that sounds like somewhere during the FreeBSD build process at least the
> .h file is generated out of the .m file. As far as I can tell, most .m
> files are processed with the makeobjops.awk script.
> That's something that isn't yet cleanly integrated into the waf build
> system yet. Instead there is a "Makefile.todo" in libbsd that is used
> for this cases. Most likely you can just add that .m file and call a
> make on that target.
> Some background for the "Makefile.todo": Originally the libbsd has been
> build using one big Makefile. Due to the decision that RTEMS should go
> toward waf, most parts of that Makefile has been replaced. The
> "Makefile.todo" is the part that is left and should be integrated into
> waf as soon as someone feels like doing it or finds someone who funds
> the the time.
> Regarding iicbus: Most likely that is an interfaces that needs a
> translation layer so that the RTEMS i2c framework is used. So importing
> the header with the declarations is good and correct. But you will need
> to plan some time to implement the functions based on the RTEMS i2c
> interface.
> Best regards
> Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190319/24dddf9b/attachment-0002.html>
