rtems-libbsd build error
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Mon Mar 18 19:31:13 UTC 2019
On Tue, 19 Mar 2019 at 00:56, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> Hi Christian,
> (it got sent by mistake :) )
Thanks for telling about the script, now I have the code imported and it's
building successfully.
I have forked the repo and created a branch with my commits. Please have a
look and see if
It's going in the right direction.
https://github.com/thelunatic/rtems-libbsd/tree/hdmi_framer
I have also wrote a first draft of the proposal. Are we supposed to send
the draft proposals only after the the application period stars? or can we
just share it offlist with the mentors now?
Thanks
> On Sun, 17 Mar 2019 at 14:30, Christian Mauderer <list at c-mauderer.de>
> wrote:
>> Am 16.03.19 um 23:52 schrieb Vijay Kumar Banerjee:
>> > On Sat, 16 Mar 2019 at 01:00, Christian Mauderer <list at c-mauderer.de
>> > <mailto:list at c-mauderer.de>> wrote:
>> >     Am 15.03.19 um 19:20 schrieb Vijay Kumar Banerjee:
>> >     > On Fri, 15 Mar 2019 at 21:47, Christian Mauderer
>> >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>> >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>> >     >     Am 15.03.19 um 15:48 schrieb Vijay Kumar Banerjee:
>> >     >     > Hello,
>> >     >     > I am trying to `./waf install` the libbsd but getting some
>> >     error,
>> >     >     need help
>> >     >     > with that. The commands used and the errors are given below
>> >     >     > configured using: `./waf configure
>> >     --buildset=buildset/default.ini
>> >     >     > --prefix=$HOME/development/rtems/5 --rtems-arch=arm`
>> >     >     > configure was successful.
>> >     >     > then : `./waf install`
>> >     >     > Error ...
>> >     >     > Build failed
>> >     >     >  -> task in 'lex__nsyy' failed with exit status 1 (run with
>> >     -v to
>> >     >     > display more information)
>> >     >     >  -> task in 'yacc__nsyy' failed with exit status 1 (run with
>> >     -v to
>> >     >     >  -> task in 'lex_pcap' failed with exit status 1 (run with
>> -v to
>> >     >     display
>> >     >     > more information)
>> >     >     >  -> task in 'yacc_pcap' failed with exit status 1 (run with
>> >     -v to
>> >     >     >  -> task in 'objs01' failed with exit status 1 (run with -v
>> >     to display
>> >     >     > more information)
>> >     to display
>> >     >     > more information)
>> >     >     >  -> task in 'yacc_pfctly' failed with exit status 1 (run
>> >     with -v to
>> >     >     > Thanks
>> >     >     > --vijay
>> >     >     Hello Vijay,
>> >     >     did you try to build before the install? I don't see the call.
>> >     >     Normally it's
>> >     >       waf configure ...
>> >     >       waf
>> >     >       waf install
>> >     >     If you did that: It seems that some of the lex / yacc files
>> >     should be
>> >     >     regenerated. Did you enable --enable-auto-regen somewhen
>> during an
>> >     >     earlier configuration run (not necessary except if you import
>> >     yacc or
>> >     >     lex files)? Did you import some yacc or lex files?
>> >     > I had to install `byacc` package using yum in fedora, then I used
>> the
>> >     > --enable-auto-regen
>> >     > option, that worked.
>> >     > However, it's still not building and I'm seeing a lot of
>> warnings, I
>> >     > think this is because of the
>> >     > files I imported from the freebsd source, maybe they depend on
>> some
>> >     > other headers that
>> >     > I didn't include. Any suggestion on how to debug, if this is the
>> >     case?
>> >     >     Best regards
>> >     >     Christian
>> >     Hello Vijay,
>> >     normally you shouldn't need the --enable-auto-regen option. It only
>> >     changes a lot of files that you don't want to change. Especially:
>> If you
>> >     use Fedora (or some other Linux) you get GPL licensed output. We
>> >     normally use FreeBSD for that step and check in the generated files
>> so
>> >     that no user has to use --enable-auto-regen.
>> >     Regarding how to start such a port: Normally it's a good idea to get
>> >     some overview over what's missing. For that you import the files
>> that
>> >     you think are relevant (like you already did). Then you can build
>> with
>> >     `waf -k -j1` which continues even if some files are not compilable
>> (-k
>> >     is for continue, -j1 so that you receive the messages in order). You
>> >     should get a lot of compiler errors during that run.
>> >     Now comes the hard part: You have to analyse the errors and try to
>> find
>> >     out what's the reason for them. If some big part is missing you most
>> >     likely get a lot of similar errors (like "header xy.h not found").
>> Most
>> >     likely you can identify some groups. With that you can estimate
>> what has
>> >     to be ported besides the files you already imported.
>> >     Identifying these groups is a quite relevant step for planning the
>> >     amount of work for your GSoC proposal. If you are unsure, try to
>> ask on
>> >     the mailing list. You can also post the build output and an
>> assumption
>> >     what groups you estimate to get some feedback.
>> >     Best regards
>> >     Christian
>> > Hi
>> > I figured out that there were some unnecessary imports I was doing and
>> > also some necessary
>> > header files that I'm missing, after adding those most of the warnings
>> > vanished. The error I'm
>> > seeing now is due to a missing '.m' header file. The error looks like
>> > this ...
>> >    ../../freebsd/sys/arm/ti/am335x/tda19988.c:56:10: fatal error:
>> > rtems/bsd/local/iicbus_if.h: No such file or directory
>> >  #include <rtems/bsd/local/iicbus_if.h>
>> > There's an iicbus_if.m file in the freebsd source which is being
>> included as
>> > ``#include "iicbus_if.h"``
>> > How to work with the .m files ?
>> > Thanks
>> Hello Vijay,
>> that sounds like somewhere during the FreeBSD build process at least the
>> .h file is generated out of the .m file. As far as I can tell, most .m
>> files are processed with the makeobjops.awk script.
>> That's something that isn't yet cleanly integrated into the waf build
>> system yet. Instead there is a "Makefile.todo" in libbsd that is used
>> for this cases. Most likely you can just add that .m file and call a
>> make on that target.
>> Some background for the "Makefile.todo": Originally the libbsd has been
>> build using one big Makefile. Due to the decision that RTEMS should go
>> toward waf, most parts of that Makefile has been replaced. The
>> "Makefile.todo" is the part that is left and should be integrated into
>> waf as soon as someone feels like doing it or finds someone who funds
>> the the time.
>> Regarding iicbus: Most likely that is an interfaces that needs a
>> translation layer so that the RTEMS i2c framework is used. So importing
>> the header with the declarations is good and correct. But you will need
>> to plan some time to implement the functions based on the RTEMS i2c
>> interface.
>> Best regards
>> Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190319/2645ff23/attachment-0002.html>
