Stm32l4 contribution
Ярослав Лещинский midniwalker at gmail.com
Fri Mar 29 09:10:36 UTC 2019
The second part of the the first patch.
On Fri, 29 Mar 2019 at 12:09, Ярослав Лещинский <midniwalker at gmail.com>
wrote:
> Hello again,
> Due the email size limit I have splitted the first patch into the 4 peaces
> and gonna send them in separate emails. After that 3 more patches will be
> sent.
> BRs, Yaroslav.
> On Fri, 29 Mar 2019 at 11:50, Ярослав Лещинский <midniwalker at gmail.com>
> wrote:
>> The first one is rather big -- up to 777K. I have splitted them into 4
>> peaces. May I send them in separate emails and after all add 3 patches more?
>> On Fri, 29 Mar 2019 at 11:32, Chris Johns <chrisj at rtems.org> wrote:
>>> Hi
>>> There’s a size limit. How big is the patch?
>>> Can you break it up?
>>> Chris
>>> On 29 Mar 2019, at 7:24 pm, Ярослав Лещинский <midniwalker at gmail.com>
>>> wrote:
>>> Hello again,
>>> First of all sorry that I'm writing directly to you.
>>> I forwarded my previous email. When I tried send an email to
>>> devel at rtems.org I've got message from bot that my email is waiting
>>> approval from moderator -- I attached patches to the forwarded email as you
>>> can see and email is out of size limit.
>>> I followed the instructions here:
>>> https://devel.rtems.org/wiki/Developer/Git/Users#CreatingaPatch but it
>>> looks like I missed something. I'll be really appreciate for your help.
>>> Thanks.
>>> BRs, Yaroslav.
>>> ---------- Forwarded message ---------
>>> From: Ярослав Лещинский <midniwalker at gmail.com>
>>> Date: Fri, 29 Mar 2019 at 10:52
>>> Subject: Re: Stm32l4 contribution
>>> To: Chris Johns <chrisj at rtems.org>
>>> Cc: devel at rtems.org <devel at rtems.org>
>>> Hello Chris,
>>> I have sent patches from email notme9915 at gmail.com to devel at rtems.org
>>> as mentioned here:
>>> In attached you can find those patches. I have added: startup code for
>>> stm32l4, console, gpio, dma, spidev. According to spidev: I forgot to add
>>> spi modes and config for baud rate: currently for stm32l4 dev board spi
>>> mode is SPI_MODE_0 and BR is 500kHz.
>>> I'm assuming that after the code review I would fix some issues with my
>>> code and at that moment I can add SPI modes and BR configuration.
>>> Spidev was tested with LoRa sx1278.
>>> Thanks.
>>> On Fri, 29 Mar 2019 at 06:08, Chris Johns <chrisj at rtems.org> wrote:
>>>> On 29/3/19 8:10 am, Ярослав Лещинский wrote:
>>>> > Today I added some patches related to stm32l4 board support.
>>>> Fantastic.
>>>> > As it was the first
>>>> > time when I’m dealing with a contribution here in RTEMS, could you
>>>> please check:
>>>> > does this patches existed at all? I sent them via git email, so I’m
>>>> not sure
>>>> > that I made all correct.
>>>> Which address did you send them too?
>>>> I have checked this list and there are no pending posts.
>>>> Chris
>>> Kind regards,
>>> *Yaroslav Leshchinsky*
>>> Kind regards,
>>> <0004-licences-description-added.patch>
>>> <0003-move-spidev-into-the-startup-code.patch>
>>> <0002-fixed-console-added-section-for-stm32l4-linker.patch>
>>> <0001-Add-stm32l476vg-discovery-board-support.patch>
>> Kind regards,
> Kind regards,
Kind regards,
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190329/aa66349c/attachment-0002.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190329/aa66349c/attachment-0002.bin>
