Error during execution of testsuites on host OS, for ARM Architecture.
Thu May 2 16:49:03 UTC 2019
Try to manually run the executable directly by qemu. Ask if you need more
direction
On Wed, Apr 24, 2019, 2:04 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> Hello,
> I even tried to run rtems-test for the testsuites/samples for ARM
> Architecture,
> $ rtems-test --rtems-bsp=xilinx_zynq_a9_qemu
> --rtems-tools=$HOME/development/rtems/5
> ~/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples
> RTEMS Testing - Tester, 5.0.not_released
>  Command Line: /home/varodek/development/rtems/5/bin/rtems-test
> --rtems-tools=/home/varodek/development/rtems/5
> /home/varodek/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples
>  Python: 3.7.3 (default, Mar 26 2019, 21:43:19) [GCC 8.2.1 20181127]
> Host: Linux-5.0.5-arch1-1-ARCH-x86_64-with-arch (Linux varodek
> 5.0.5-arch1-1-ARCH #1 SMP PREEMPT Wed Mar 27 17:53:10 UTC 2019 x86_64 )
> [ 1/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
> arm/xilinx_zynq_a9_qemu: base_sp.exe
> [ 4/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
> arm/xilinx_zynq_a9_qemu: cxx_iostream.exe
> error: qemu.cfg:84: execute failed: qemu-system-arm -no-reboot -serial
> null -serial mon:stdio -nographic -net none -M xilinx-zynq-a9 -m 256M
> -kernel
> /home/varodek/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples/base_sp.exe:
> exit-code:2
> -kernel
> exit-code:2
> warning: switched to dry run due to errors
> [ 3/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:1  W:0  |
> arm/xilinx_zynq_a9_qemu: cdtest.exe
> -kernel
> /home/varodek/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples/cxx_iostream.exe:
> exit-code:2
> -kernel
> exit-code:2
> [ 2/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:2  W:0  |
> arm/xilinx_zynq_a9_qemu: capture.exe
> -kernel
> /home/varodek/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples/cdtest.exe:
> exit-code:2
> -kernel
> exit-code:2
> -kernel
> /home/varodek/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples/capture.exe:
> exit-code:2
> -kernel
> exit-code:2
> Result: invalid    Time: 0:00:00.027521 base_sp.exe
> =>  run: qemu-system-arm -no-reboot -serial null -serial mon:stdio
> -nographic -net none -M xilinx-zynq-a9 -m 256M -kernel
> Result: invalid    Time: 0:00:00.005902 capture.exe
> Result: invalid    Time: 0:00:00.021361 cdtest.exe
> Result: invalid    Time: 0:00:00.027792 cxx_iostream.exe
> [ 5/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
> arm/xilinx_zynq_a9_qemu: fileio.exe
> [ 7/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
> arm/xilinx_zynq_a9_qemu: minimum.exe
> -kernel
> /home/varodek/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples/fileio.exe:
> exit-code:2
> -kernel
> exit-code:2
> [ 6/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:5  W:0  |
> arm/xilinx_zynq_a9_qemu: hello.exe
> [ 8/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:5  W:0  |
> arm/xilinx_zynq_a9_qemu: nsecs.exe
> -kernel
> /home/varodek/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples/minimum.exe:
> exit-code:2
> -kernel
> exit-code:2
> -kernel
> /home/varodek/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples/hello.exe:
> exit-code:2
> -kernel
> exit-code:2
> -kernel
> /home/varodek/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples/nsecs.exe:
> exit-code:2
> -kernel
> exit-code:2
> Result: invalid    Time: 0:00:00.041632 fileio.exe
> Result: invalid    Time: 0:00:00.017531 hello.exe
> Result: invalid    Time: 0:00:00.010854 nsecs.exe
> [ 9/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  |
> arm/xilinx_zynq_a9_qemu: paranoia.exe
> [11/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  |
> arm/xilinx_zynq_a9_qemu: unlimited.exe
> [10/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  |
> arm/xilinx_zynq_a9_qemu: ticker.exe
> -kernel
> /home/varodek/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples/paranoia.exe:
> exit-code:2
> -kernel
> exit-code:2
> -kernel
> /home/varodek/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples/unlimited.exe:
> exit-code:2
> -kernel
> exit-code:2
> -kernel
> /home/varodek/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples/ticker.exe:
> exit-code:2
> -kernel
> exit-code:2
> Result: invalid    Time: 0:00:00.036784 paranoia.exe
> Result: invalid    Time: 0:00:00.009978 ticker.exe
> Result: invalid    Time: 0:00:00.017402 unlimited.exe
> Passed:         1
> Failed:         0
> User Input:     0
> Expected Fail:  0
> Indeterminate:  0
> Benchmark:      0
> Timeout:        0
> Invalid:       10
> Wrong Version:  0
> Wrong Build:    0
> Wrong Tools:    0
> Total:         11
> Invalid:
>  base_sp.exe
>  cxx_iostream.exe
>  cdtest.exe
>  capture.exe
>  fileio.exe
>  hello.exe
>  nsecs.exe
>  paranoia.exe
>  unlimited.exe
>  ticker.exe
> Average test time: 0:00:00.095631
> Testing time     : 0:00:01.051941
> Why the executables are not able to execute?
> Thank you
> Vaibhav Gupta
> On Wed, Apr 24, 2019 at 1:26 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> Hello,
>> I have successfully build RTEMS for SPARC erc32, and have run the
>> testsuites, before.
>> This time I have build RTEMS for ARM xilinx_zynq_a9_qemu
>> But when I try to run the hello world example, it gives me following
>> error:
>> $ arm-rtems5-gdb
>> ~/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples/hello.exe
>> GNU gdb (GDB) 8.2.1
>> Copyright (C) 2018 Free Software Foundation, Inc.
>> License GPLv3+: GNU GPL version 3 or later <
>> http://gnu.org/licenses/gpl.html>
>> This is free software: you are free to change and redistribute it.
>> There is NO WARRANTY, to the extent permitted by law.
>> Type "show copying" and "show warranty" for details.
>> This GDB was configured as "--host=x86_64-linux-gnu --target=arm-rtems5".
>> Type "show configuration" for configuration details.
>> For bug reporting instructions, please see:
>> <http://www.gnu.org/software/gdb/bugs/>.
>> Find the GDB manual and other documentation resources online at:
>>     <http://www.gnu.org/software/gdb/documentation/>.
>> For help, type "help".
>> Type "apropos word" to search for commands related to "word"...
>> Reading symbols from
>> /home/varodek/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples/hello.exe...done.
>> (gdb) tar sim
>> Connected to the simulator.
>> (gdb) load
>> Loading section .start, size 0xad0 lma 0x0
>> Loading section .text, size 0x1a5f8 lma 0xb00
>> Loading section .init, size 0xc lma 0x1b0f8
>> Loading section .fini, size 0xc lma 0x1b104
>> Loading section .rodata, size 0x1694 lma 0x1b110
>> Loading section .ARM.exidx, size 0x8 lma 0x1c7a4
>> Loading section .eh_frame, size 0x4 lma 0x1c7ac
>> Loading section .init_array, size 0x4 lma 0x1c7b0
>> Loading section .fini_array, size 0x4 lma 0x1c7b4
>> Loading section .rtemsroset, size 0x38 lma 0x1c7b8
>> Loading section .data, size 0x66c lma 0x101000
>> Start address 0x40
>> Transfer rate: 946528 bits in <1 sec.
>> (gdb) r
>> Starting program:
>> Unknown machine type '19'; please update sim_create_inferior.
>> [Inferior 1 (process 42000) exited with code 060]
>> I am not able to analyze the problem, why is it showing Unknown machine
>> type? The test runs were successful  for SPARC.
>> Thank You
>> Vaibhav Gupta
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190502/2a951ac2/attachment-0001.html>
