Error during execution of testsuites on host OS, for ARM Architecture.
    Chris Johns
    chrisj at rtems.org
    Fri May  3 00:50:35 UTC 2019
On 3/5/19 2:49 am, Gedare Bloom wrote:
> Try to manually run the executable directly by qemu. Ask if you need more direction
Good advice. Also the command line for qemu can be seen by adding `--trace` to
the `rtems-test` command line and then looking in the log file. I suggest you
run a single test until it is working.
