Error during execution of testsuites on host OS, for ARM Architecture.
Chris Johns
chrisj at rtems.org
Fri May 3 00:58:42 UTC 2019
> On 3 May 2019, at 10:55 am, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I tried to post this earlier but was having outgoing mail problems.
> The command varies between versions of qemu. It is likely the rtems-tester configuration file
> for this BSP doesn't match the version of qemu you have built. This is from a shell script
> I use on an application. Notice the difference in arguments due to qemu version.
> #echo "-no-reboot -serial null -serial mon:stdio -net none -nographic -M xilinx-zynq-a9 -m 256M ${COVERAGE_ARG} -kernel ${1}"
> echo "-no-reboot -monitor none -serial stdio -net none -nographic -M xilinx-zynq-a9 -m 256M ${COVERAGE_ARG} -kernel ${1}"
Yes. The `rtems-test` command if configured to use the RSB built version of qemu.
Do you know version is which command line?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190503/7a64530b/attachment.html>
