[PATCH 61/98] doxygen: score: adjust doc in schedulersmp.h to doxygen guidelines
Tue May 7 05:40:06 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
 cpukit/include/rtems/score/schedulersmp.h | 13 +++++++++++--
 1 file changed, 11 insertions(+), 2 deletions(-)
diff --git a/cpukit/include/rtems/score/schedulersmp.h b/cpukit/include/rtems/score/schedulersmp.h
index afc504bb83..268585f0be 100644
--- a/cpukit/include/rtems/score/schedulersmp.h
+++ b/cpukit/include/rtems/score/schedulersmp.h
@@ -1,9 +1,9 @@
  * @file
- * @brief SMP Scheduler API
  * @ingroup RTEMSScoreSchedulerSMP
+ * @brief SMP Scheduler API
@@ -35,6 +35,8 @@ extern "C" {
@@ -112,6 +114,13 @@ typedef struct {
   Priority_Control priority;
 } Scheduler_SMP_Node;
+ * @brief Starts an idle thread on the specified cpu.
+ * @param scheduler The scheduler instance.
+ * @param[in, out] idle The idle thread to schedule.
+ * @param[out] cpu The cpu to run the idle thread on.
 void _Scheduler_SMP_Start_idle(
   const Scheduler_Control *scheduler,
   Thread_Control          *idle,
2.16.4
