[PATCH 60/98] doxygen: score: adjust doc in schedulersimplesmp.h to doxygen guidelines
Tue May 7 05:40:05 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
 cpukit/include/rtems/score/schedulersimplesmp.h | 88 ++++++++++++++++++++++++-
 1 file changed, 86 insertions(+), 2 deletions(-)
diff --git a/cpukit/include/rtems/score/schedulersimplesmp.h b/cpukit/include/rtems/score/schedulersimplesmp.h
index 647d4af9d3..eeb07d848e 100644
--- a/cpukit/include/rtems/score/schedulersimplesmp.h
+++ b/cpukit/include/rtems/score/schedulersimplesmp.h
@@ -1,9 +1,9 @@
  * @file
- * @brief Simple SMP Scheduler API
  * @ingroup RTEMSScoreSchedulerSMPSimple
+ * @brief Simple SMP Scheduler API
@@ -32,6 +32,8 @@ extern "C" {
+ * @brief Simple Priority SMP Scheduler
  * The Simple Priority SMP Scheduler allocates a processor for the processor
  * count highest priority ready threads.  The thread priority and position in
  * the ready chain are the only information to determine the scheduling
@@ -85,8 +87,21 @@ typedef struct {
     SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
+ * @brief Initializes the scheduler's context.
+ * @param scheduler The scheduler instance to initialize the context of.
 void _Scheduler_simple_SMP_Initialize( const Scheduler_Control *scheduler );
+ * @brief Initializes the node with the given attributes.
+ * @param scheduler The scheduler instance.
+ * @param[out] node The node to initialize.
+ * @param the_thread The user of the node, if RTEMS_SMP is defined.
+ * @param priority The priority of the node to initialize.
 void _Scheduler_simple_SMP_Node_initialize(
   const Scheduler_Control *scheduler,
   Scheduler_Node          *node,
@@ -94,36 +109,84 @@ void _Scheduler_simple_SMP_Node_initialize(
   Priority_Control         priority
+ * @brief Blocks a thread.
+ * @param[in, out] thread The thread to block.
+ * @param[in, out] node The scheduler node of @a thread.
 void _Scheduler_simple_SMP_Block(
   Thread_Control          *thread,
+ * @brief Unblocks a thread.
+ * @param[in, out] thread The thread to unblock.
 void _Scheduler_simple_SMP_Unblock(
+ * @brief Updates the priority of the node.
+ * @param the_thread The thread of @a node.
+ * @param node The node to update the priority of.
 void _Scheduler_simple_SMP_Update_priority(
   Thread_Control          *the_thread,
+ * @brief Asks for help.
+ * @param scheduler The scheduler instance to ask for help.
+ * @param the_thread The thread needing help.
+ * @param node The scheduler node.
+ * @retval true Ask for help was successful.
+ * @retval false Ask for help was not successful.
 bool _Scheduler_simple_SMP_Ask_for_help(
+ * @brief Reconsiders help.
+ * @param scheduler The scheduler instance to reconsider the help
+ *   request.
+ * @param the_thread The thread reconsidering a help request.
 void _Scheduler_simple_SMP_Reconsider_help_request(
+ * @brief Withdraws node.
+ * @param scheduler The scheduler instance to withdraw the node.
+ * @param the_thread The thread using the node.
+ * @param node The scheduler node to withdraw.
+ * @param next_state The next thread scheduler state in the case the node is
+ *   scheduled.
 void _Scheduler_simple_SMP_Withdraw_node(
@@ -131,16 +194,37 @@ void _Scheduler_simple_SMP_Withdraw_node(
   Thread_Scheduler_state   next_state
+ * @brief Adds @a idle to @a scheduler.
+ * @param[in, out] scheduler The scheduler instance to add the processor to.
+ * @param idle The idle thread control.
 void _Scheduler_simple_SMP_Add_processor(
   Thread_Control          *idle
+ * @brief Removes an idle thread from the given cpu.
+ * @param cpu The cpu control to remove from @a scheduler.
+ * @return The idle thread of the processor.
 Thread_Control *_Scheduler_simple_SMP_Remove_processor(
   struct Per_CPU_Control  *cpu
+ * Performs a yield operation for the thread.
+ * @param thread The thread to yield.
+ * @param[in, out] node The node of the thread to perform a yield.
 void _Scheduler_simple_SMP_Yield(
2.16.4
