[PATCH 76/98] doxygen: score: adjust doc in sysstate.h to doxygen guidelines
Tue May 7 05:40:21 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
 cpukit/include/rtems/score/sysstate.h | 45 ++++++++++++++++++++++++++++++++++-
 1 file changed, 44 insertions(+), 1 deletion(-)
diff --git a/cpukit/include/rtems/score/sysstate.h b/cpukit/include/rtems/score/sysstate.h
index 15820a0d3e..647da1dea5 100644
--- a/cpukit/include/rtems/score/sysstate.h
+++ b/cpukit/include/rtems/score/sysstate.h
@@ -30,8 +30,9 @@ extern "C" {
  * @ingroup RTEMSScore
  * @brief Management of the internal system state of RTEMS.
  * @brief System states.
@@ -69,6 +70,11 @@ extern bool _System_state_Is_multiprocessing;
 extern System_state_Codes _System_state_Current;
+ * @brief Sets the current system state to the given state.
+ * @param state The state to set.
 RTEMS_INLINE_ROUTINE void _System_state_Set (
   System_state_Codes state
@@ -76,11 +82,24 @@ RTEMS_INLINE_ROUTINE void _System_state_Set (
   _System_state_Current = state;
+ * @brief Gets the current system state.
+ * @return The current system state.
 RTEMS_INLINE_ROUTINE System_state_Codes _System_state_Get ( void )
   return _System_state_Current;
+ * @brief Checks if the state is before initialization.
+ * @param state The state to check.
+ * @retval true @a state is before initialization.
+ * @retval false @a state is not before initialization.
 RTEMS_INLINE_ROUTINE bool _System_state_Is_before_initialization (
@@ -88,6 +107,14 @@ RTEMS_INLINE_ROUTINE bool _System_state_Is_before_initialization (
   return (state == SYSTEM_STATE_BEFORE_INITIALIZATION);
+ * @brief Checks if the state is before multitasking.
+ * @retval true @a state is before multitasking.
+ * @retval false @a state is not before multitasking.
 RTEMS_INLINE_ROUTINE bool _System_state_Is_before_multitasking (
@@ -95,6 +122,14 @@ RTEMS_INLINE_ROUTINE bool _System_state_Is_before_multitasking (
   return (state == SYSTEM_STATE_BEFORE_MULTITASKING);
+ * @brief Checks if the state is up.
+ * @retval true @a state is up.
+ * @retval false @a state is not up.
 RTEMS_INLINE_ROUTINE bool _System_state_Is_up (
@@ -102,6 +137,14 @@ RTEMS_INLINE_ROUTINE bool _System_state_Is_up (
   return (state == SYSTEM_STATE_UP);
+ * @brief Checks if the state is terminated.
+ * @retval true @a state is terminated.
+ * @retval false @a state is not terminated.
 RTEMS_INLINE_ROUTINE bool _System_state_Is_terminated (
2.16.4
