[PATCH 77/98] doxygen: score: adjust doc in threaddispatch.h to doxygen guidelines
Tue May 7 05:40:22 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
 cpukit/include/rtems/score/threaddispatch.h | 24 ++++++++++++++----------
 1 file changed, 14 insertions(+), 10 deletions(-)
diff --git a/cpukit/include/rtems/score/threaddispatch.h b/cpukit/include/rtems/score/threaddispatch.h
index 89c737c057..016a9ae9a3 100644
--- a/cpukit/include/rtems/score/threaddispatch.h
+++ b/cpukit/include/rtems/score/threaddispatch.h
@@ -1,4 +1,8 @@
+ * @file
+ * @ingroup RTEMSScoreThread
  * @brief Constants and Structures Related with Thread Dispatch
@@ -114,7 +118,7 @@ void _Thread_Dispatch( void );
  * is useful for operations which synchronously block, e.g. self restart, self
  * deletion, yield, sleep.
- * @param[in] cpu_self The current processor.
+ * @param cpu_self The current processor.
  * @see _Thread_Dispatch().
@@ -128,8 +132,8 @@ void _Thread_Dispatch_direct( Per_CPU_Control *cpu_self );
  * This function assumes that a thread dispatch is necessary.
- * @param[in] level The previous interrupt level.
+ * @param level The previous interrupt level.
@@ -139,8 +143,8 @@ void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level );
  * @brief Disables thread dispatching inside a critical section (interrupts
  * disabled) with the current processor.
- * @param[in] lock_context The lock context of the corresponding
+ * @param lock_context The lock context of the corresponding
  * _ISR_lock_ISR_disable() that started the critical section.
  * @return The current processor.
@@ -167,7 +171,7 @@ RTEMS_INLINE_ROUTINE Per_CPU_Control *_Thread_Dispatch_disable_with_CPU(
  * disabled).
@@ -207,14 +211,14 @@ RTEMS_INLINE_ROUTINE Per_CPU_Control *_Thread_Dispatch_disable( void )
  * May perform a thread dispatch if necessary as a side-effect.
+ * @param[in, out] cpu_self The current processor.
 void _Thread_Dispatch_enable( Per_CPU_Control *cpu_self );
  * @brief Unnests thread dispatching.
 RTEMS_INLINE_ROUTINE void _Thread_Dispatch_unnest( Per_CPU_Control *cpu_self )
@@ -225,8 +229,8 @@ RTEMS_INLINE_ROUTINE void _Thread_Dispatch_unnest( Per_CPU_Control *cpu_self )
  * @brief Requests a thread dispatch on the target processor.
- * @param[in] cpu_target The target processor to request a thread dispatch.
+ * @param[in, out] cpu_target The target processor to request a thread dispatch.
 RTEMS_INLINE_ROUTINE void _Thread_Dispatch_request(
2.16.4
