[PATCH 78/98] doxygen: score: adjust doc in thread.h to doxygen guidelines
Tue May 7 05:40:23 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
 cpukit/include/rtems/score/thread.h | 41 ++++++++++++++++++++++---------------
 1 file changed, 25 insertions(+), 16 deletions(-)
diff --git a/cpukit/include/rtems/score/thread.h b/cpukit/include/rtems/score/thread.h
index 79853b8d79..b3cfd91e93 100644
--- a/cpukit/include/rtems/score/thread.h
+++ b/cpukit/include/rtems/score/thread.h
@@ -1,10 +1,12 @@
- *  @file
+ * @file
- *  @brief Constants and Structures Related with the Thread Control Block
+ * @ingroup RTEMSScoreThread
- *  This include file contains all constants and structures associated
- *  with the thread control block.
+ * @brief Constants and Structures Related with the Thread Control Block
+ * This include file contains all constants and structures associated
+ * with the thread control block.
@@ -54,21 +56,24 @@ extern "C" {
 #endif
- *  @defgroup RTEMSScoreThread Thread Handler
+ * @defgroup RTEMSScoreThread Thread Handler
+ * @brief Thread Handler
- *  @ingroup RTEMSScore
+ * This handler encapsulates functionality related to the management of
+ * threads.  This includes the creation, deletion, and scheduling of threads.
- *  This handler encapsulates functionality related to the management of
- *  threads.  This includes the creation, deletion, and scheduling of threads.
+ * The following variables are maintained as part of the per cpu data
+ * structure.
- *  The following variables are maintained as part of the per cpu data
- *  structure.
+ * + Idle thread pointer
+ * + Executing thread pointer
+ * + Heir thread pointer
- *  + Idle thread pointer
- *  + Executing thread pointer
- *  + Heir thread pointer
 #define RTEMS_SCORE_THREAD_ENABLE_EXHAUST_TIMESLICE
@@ -876,7 +881,11 @@ struct _Thread_Control {
 typedef void (*rtems_per_thread_routine)( Thread_Control * );
-/* Use rtems_task_iterate() instead */
+ * @brief Deprecated, use rtems_task_iterate() instead.
+ * Use rtems_task_iterate() instead.
 void rtems_iterate_over_all_threads(
   rtems_per_thread_routine routine
 ) RTEMS_DEPRECATED;
@@ -1047,7 +1056,7 @@ Thread_Information name##_Information = { \
 #ifdef __cplusplus
2.16.4
