RTEMS 5.0 error occurred in 'make' while --enable- tests are done
Joel Sherrill
joel at rtems.org
Tue May 7 13:58:44 UTC 2019
This BSP builds for me off the master. There are multiple variants within
this
BSP family and various configurations you could have used. Could you
share your configure command?
Mine was:
../rtems/configure --target=arm-rtems5
--enable-rtemsbsp=tms570ls3137_hdk_sdram
--prefix=/home/joel/rtems-work/tools/5/bsp-install --enable-networking
--enable-posix --disable-smp --disable-multiprocessing
--disable-rtems-debug --disable-profiling --enable-tests --enable-cxx
--enable-maintainer-mode
Thanks.
--joel
On Tue, May 7, 2019 at 8:44 AM Aby Tom <abythayil at gmail.com> wrote:
> Hello everyone,
> I am new to RTEMS, and was trying to build a new bsp for RTEMS 5 for
> tms570 family of boards.
> While doing the make, i come across this error.
> I had done --enable-tests in the previous command.
> Can anyone help me with this? Output from terminal is shown below.
> (.... represent some omitted output results)
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/nfs.c:
> In function 'nfs_fsunmount_me':
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/nfs.c:1928:7:
> warning: variable 'status' set but not used [-Wunused-but-set-variable]
> int status;
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:
> In function 'rpcUdpServerCreate':
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:567:11:
> error: 'llock' undeclared (first use in this function); did you mean
> 'clock'?
> MU_LOCK( llock );
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:204:54:
> note: in definition of macro 'MU_LOCK'
> #define MU_LOCK(mutex) rtems_recursive_mutex_lock(&(mutex))
> note: each undeclared identifier is reported only once for each function it
> appears in
> MU_LOCK( llock );
> In function 'rpcUdpXactCreate':
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:667:11:
> error: 'hlock' undeclared (first use in this function); did you mean
> 'clock'?
> MU_LOCK(hlock);
> In function 'rpcUdpXactDestroy':
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:711:11:
> 'clock'?
> MU_LOCK(hlock);
> In function 'rpcUdpRcv':
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:813:19:
> rtems_status_code status;
> In function 'rpcUdpInit':
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:938:15:
> 'clock'?
> MU_CREAT( &hlock );
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:208:54:
> note: in definition of macro 'MU_CREAT'
> #define MU_CREAT(pmutex) rtems_recursive_mutex_init((pmutex), "RPCl")
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:939:15:
> 'hlock'?
> MU_CREAT( &llock );
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:924:19:
> warning: variable 'wkup' set but not used [-Wunused-but-set-variable]
> struct sockwakeup wkup;
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:922:19:
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:921:7:
> warning: variable 's' set but not used [-Wunused-but-set-variable]
> int s;
> In function 'rpcio_daemon':
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:1173:12:
> 'clock'?
> MU_LOCK(hlock);
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:1149:19:
> In function 'rpcUdpXactPoolCreate':
> /home/dev/kernel/rtems/c/src/../../cpukit/libfs/src/nfsclient/src/rpcio.c:1508:19:
> Makefile:11245: recipe for target 'libfs/src/nfsclient/src/rpcio.o' failed
> make[4]: *** [libfs/src/nfsclient/src/rpcio.o] Error 1
> make[4]: Leaving directory
> Makefile:1221: recipe for target 'cpukit' failed
> make[3]: *** [cpukit] Error 2
> make[3]: Leaving directory
> Makefile:715: recipe for target 'all-recursive' failed
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory
> Makefile:289: recipe for target 'all-recursive' failed
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> Makefile:410: recipe for target 'all-recursive' failed
> make: *** [all-recursive] Error 1
> Thank you.
> Regards,
> Aby
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190507/15d73ec9/attachment-0001.html>
