[PATCH] Separate libbsd and RTEMS clock ticks
Sebastian Huber
Mon May 13 09:20:59 UTC 2019
freebsd/sys/kern/kern_timeout.c | 5 ++++-
freebsd/sys/sys/kernel.h | 9 ---------
rtemsbsd/rtems/rtems-kernel-init.c | 25 +++++++++++++++----------
3 files changed, 19 insertions(+), 20 deletions(-)
diff --git a/freebsd/sys/kern/kern_timeout.c b/freebsd/sys/kern/kern_timeout.c
index 8ef42c9a9..2f478afc5 100644
--- a/freebsd/sys/kern/kern_timeout.c
+++ b/freebsd/sys/kern/kern_timeout.c
@@ -317,6 +317,7 @@ rtems_bsd_callout_timer(rtems_id id, void *arg)
sc = rtems_timer_reset(id);
BSD_ASSERT(sc == RTEMS_SUCCESSFUL);
+ ++ticks;
callout_process(sbinuptime());
@@ -339,7 +340,9 @@ rtems_bsd_timeout_init_late(void *unused)
sc = rtems_timer_create(rtems_build_name('_', 'C', 'L', 'O'), &id);
- sc = rtems_timer_server_fire_after(id, 1, rtems_bsd_callout_timer, NULL);
+ sc = rtems_timer_server_fire_after(id,
+ rtems_clock_get_ticks_per_second() / (rtems_interval)hz,
+ rtems_bsd_callout_timer, NULL);
diff --git a/freebsd/sys/sys/kernel.h b/freebsd/sys/sys/kernel.h
index 42a376049..41a5233ab 100644
--- a/freebsd/sys/sys/kernel.h
+++ b/freebsd/sys/sys/kernel.h
@@ -70,16 +70,7 @@ extern int psratio; /* ratio: prof / stat */
extern int stathz; /* statistics clock's frequency */
extern int profhz; /* profiling clock's frequency */
extern int profprocs; /* number of process's profiling */
-#ifndef __rtems__
extern volatile int ticks;
-#else /* __rtems__ */
- * This must be a singed integer type, otherwise expressions like
- * (x - ticks) > 0 would yield unexpected results.
-extern volatile int32_t _bsd_ticks;
-#define ticks _bsd_ticks
-#endif /* __rtems__ */
#endif /* _KERNEL */
diff --git a/rtemsbsd/rtems/rtems-kernel-init.c b/rtemsbsd/rtems/rtems-kernel-init.c
index 846ca1f12..42d495d58 100644
--- a/rtemsbsd/rtems/rtems-kernel-init.c
+++ b/rtemsbsd/rtems/rtems-kernel-init.c
@@ -85,6 +85,7 @@ void mi_startup(void);
int hz;
int tick;
+volatile int ticks;
sbintime_t tick_sbt;
struct bintime bt_timethreshold;
struct bintime bt_tickthreshold;
@@ -105,22 +106,26 @@ SYSCTL_INT(_kern_smp, OID_AUTO, maxid, CTLFLAG_RD|CTLFLAG_CAPRD,
SYSCTL_INT(_kern_smp, OID_AUTO, maxcpus, CTLFLAG_RD|CTLFLAG_CAPRD,
&maxid_maxcpus, 0, "Max number of CPUs that the system was compiled for.");
-#undef _bsd_ticks
-RTEMS_STATIC_ASSERT(sizeof(int) == sizeof(int32_t), ticks);
-volatile uint32_t _Watchdog_Ticks_since_boot;
- __attribute__ ((__alias__("_Watchdog_Ticks_since_boot")));
rtems_status_code
rtems_bsd_initialize(void)
static const char name[] = "TIME";
rtems_status_code sc;
+ int tps;
+ tps = (int)rtems_clock_get_ticks_per_second();
+ * Limit the libbsd ticks per second to 100Hz. This helps to reduce
+ * the processor load on low end targets which use 1000Hz for the RTEMS
+ * clock tick.
+ if (tps > 100) {
+ hz = tps / (tps / 100);
+ } else {
+ hz = tps;
- hz = (int) rtems_clock_get_ticks_per_second();
tick = 1000000 / hz;
tick_sbt = SBT_1S / hz;
FREQ2BT(hz, &tc_tick_bt);
2.16.4
