Cortex-M3 Errata 602117
Sebastian Huber
Mon May 13 12:47:48 UTC 2019
Hello,
while testing on a NXP LPC1788 it found that this chip is affected by
the Cortex-M3 Errata 602117. NXP didn't bother to document this in their
errata sheet for the chip:
https://www.nxp.com/docs/en/errata/ES_LPC177X_8X.pdf
To avoid the issues, you have to compile everything with
-mfix-cortex-m3-ldrd. This option is enabled by default, if you use
-mcpu=cortex-m3. Has anyone experienced this problem on other Cortex-M3
based chips?
I think we have to change our GCC multilibs to account for this errata.
For example:
diff --git a/gcc/config/arm/t-rtems b/gcc/config/arm/t-rtems
index 026a5895662..e276b4f3e57 100644
--- a/gcc/config/arm/t-rtems
+++ b/gcc/config/arm/t-rtems
@@ -1,7 +1,7 @@
# Custom RTEMS multilibs for ARM
-MULTILIB_OPTIONS = mbig-endian mthumb
march=armv6-m/march=armv7-a/march=armv7-r/march=armv7-m/mcpu=cortex-m7
mfpu=neon/mfpu=vfp/mfpu=vfpv3-d16/mfpu=fpv4-sp-d16/mfpu=fpv5-d16
mfloat-abi=hard
-MULTILIB_DIRNAMES = eb thumb armv6-m armv7-a armv7-r armv7-m cortex-m7
neon vfp vfpv3-d16 fpv4-sp-d16 fpv5-d16 hard
+MULTILIB_OPTIONS = mbig-endian mthumb
march=armv6-m/march=armv7-a/march=armv7-r/mcpu=cortex-m3/mcpu=cortex-m4/mcpu=cortex-m7
mfloat-abi=hard
+MULTILIB_DIRNAMES = eb thumb armv6-m armv7-a armv7-r cortex-m3
cortex-m4 cortex-m7 neon vfp vfpv3-d16 fpv4-sp-d16 fpv5-d16 hard
# Enumeration of multilibs
@@ -16,7 +16,8 @@ MULTILIB_REQUIRED +=
mthumb/march=armv7-a/mfpu=neon/mfloat-abi=hard
MULTILIB_REQUIRED += mthumb/march=armv7-a
MULTILIB_REQUIRED += mthumb/march=armv7-r/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_REQUIRED += mthumb/march=armv7-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_REQUIRED += mthumb/mcpu=cortex-m3
+MULTILIB_REQUIRED += mthumb/mcpu=cortex-m4
+MULTILIB_REQUIRED += mthumb/mcpu=cortex-m4/mfpu=fpv4-sp-d16/mfloat-abi=hard
MULTILIB_REQUIRED += mthumb/mcpu=cortex-m7/mfpu=fpv5-d16/mfloat-abi=hard
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
