[PATCH v2] new CBS version
Joel Oliveira Pinto jollp at isep.ipp.pt
Thu May 16 16:40:00 UTC 2019
 cpukit/Makefile.am                                |   2 +-
 cpukit/include/rtems/cbs.h                        |  24 +--
 cpukit/include/rtems/qreslib.h                    |  22 +-
 cpukit/include/rtems/score/schedulercbs.h         | 242 +++++++---------------
 cpukit/include/rtems/score/schedulercbsimpl.h     | 219 ++++++++++++++++++--
 cpukit/include/rtems/score/statesimpl.h           |  66 ++++--
 cpukit/score/src/schedulercbs.c                   |  29 +--
 cpukit/score/src/schedulercbsattachthread.c       |  16 +-
 cpukit/score/src/schedulercbsblock.c              |  60 ++++++
 cpukit/score/src/schedulercbscreateserver.c       |  12 +-
 cpukit/score/src/schedulercbsdestroyserver.c      |  17 +-
 cpukit/score/src/schedulercbsdetachthread.c       |  56 +++--
 cpukit/score/src/schedulercbsgetapprovedbudget.c  |   7 +-
 cpukit/score/src/schedulercbsgetexecutiontime.c   |  60 ------
 cpukit/score/src/schedulercbsgetparameters.c      |   7 +-
 cpukit/score/src/schedulercbsgetremainingbudget.c |  16 +-
 cpukit/score/src/schedulercbsgetserverid.c        |  25 ++-
 cpukit/score/src/schedulercbsnodeinit.c           |   2 +-
 cpukit/score/src/schedulercbsreleasejob.c         |  30 ++-
 cpukit/score/src/schedulercbssetparameters.c      |   5 +-
 cpukit/score/src/schedulercbsunblock.c            |  42 +---
 testsuites/sptests/Makefile.am                    |  23 +-
 testsuites/sptests/configure.ac                   |   2 +
 testsuites/sptests/spcbssched02/init.c            |  70 ++-----
 testsuites/sptests/spcbssched02/task_periodic.c   |  38 +---
 testsuites/sptests/spcbssched03/system.h          |   1 +
 testsuites/sptests/spcbssched03/tasks_periodic.c  |  20 +-
 testsuites/sptests/spcbssched04/hard_tasks.c      |  74 +++++++
 testsuites/sptests/spcbssched04/init.c            | 114 ++++++++++
 testsuites/sptests/spcbssched04/soft_tasks.c      |  85 ++++++++
 testsuites/sptests/spcbssched04/spcbssched04.doc  |  20 ++
 testsuites/sptests/spcbssched04/spcbssched04.scn  |  79 +++++++
 testsuites/sptests/spcbssched04/system.h          |  80 +++++++
 testsuites/sptests/spcbssched05/init.c            | 102 +++++++++
 testsuites/sptests/spcbssched05/soft_tasks.c      |  79 +++++++
 testsuites/sptests/spcbssched05/spcbssched05.doc  |  20 ++
 testsuites/sptests/spcbssched05/spcbssched05.scn  |  82 ++++++++
 testsuites/sptests/spcbssched05/system.h          |  75 +++++++
 testsuites/sptests/spqreslib/init.c               |  29 +--
 testsuites/sptests/spqreslib/task_periodic.c      |  28 +--
 40 files changed, 1382 insertions(+), 598 deletions(-)
 create mode 100644 cpukit/score/src/schedulercbsblock.c
 delete mode 100644 cpukit/score/src/schedulercbsgetexecutiontime.c
 create mode 100644 testsuites/sptests/spcbssched04/hard_tasks.c
 create mode 100644 testsuites/sptests/spcbssched04/init.c
 create mode 100644 testsuites/sptests/spcbssched04/soft_tasks.c
 create mode 100644 testsuites/sptests/spcbssched04/spcbssched04.doc
 create mode 100644 testsuites/sptests/spcbssched04/spcbssched04.scn
 create mode 100644 testsuites/sptests/spcbssched04/system.h
 create mode 100644 testsuites/sptests/spcbssched05/init.c
 create mode 100644 testsuites/sptests/spcbssched05/soft_tasks.c
 create mode 100644 testsuites/sptests/spcbssched05/spcbssched05.doc
 create mode 100644 testsuites/sptests/spcbssched05/spcbssched05.scn
 create mode 100644 testsuites/sptests/spcbssched05/system.h
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index b431581..60142e8 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -907,13 +907,13 @@ librtemscpu_a_SOURCES += score/src/schedulercbscreateserver.c
 librtemscpu_a_SOURCES += score/src/schedulercbsdestroyserver.c
 librtemscpu_a_SOURCES += score/src/schedulercbsdetachthread.c
 librtemscpu_a_SOURCES += score/src/schedulercbsgetapprovedbudget.c
-librtemscpu_a_SOURCES += score/src/schedulercbsgetexecutiontime.c
 librtemscpu_a_SOURCES += score/src/schedulercbsgetparameters.c
 librtemscpu_a_SOURCES += score/src/schedulercbsgetremainingbudget.c
 librtemscpu_a_SOURCES += score/src/schedulercbsgetserverid.c
 librtemscpu_a_SOURCES += score/src/schedulercbssetparameters.c
 librtemscpu_a_SOURCES += score/src/schedulercbsreleasejob.c
 librtemscpu_a_SOURCES += score/src/schedulercbsunblock.c
+librtemscpu_a_SOURCES += score/src/schedulercbsblock.c
 librtemscpu_a_SOURCES += score/src/pheapallocate.c
 librtemscpu_a_SOURCES += score/src/pheapextend.c
 librtemscpu_a_SOURCES += score/src/pheapfree.c
diff --git a/cpukit/include/rtems/cbs.h b/cpukit/include/rtems/cbs.h
index a42061d..cd49cef 100644
--- a/cpukit/include/rtems/cbs.h
+++ b/cpukit/include/rtems/cbs.h
@@ -46,8 +46,7 @@ extern "C" {
 #define RTEMS_CBS_ERROR_EMPTY              SCHEDULER_CBS_ERROR_EMPTY
 #define RTEMS_CBS_ERROR_NOSERVER           SCHEDULER_CBS_ERROR_NOSERVER
-/** Callback function invoked when a budget overrun of a task occurs. */
-typedef Scheduler_CBS_Budget_overrun rtems_cbs_budget_overrun;
 /** Server id. */
 typedef Scheduler_CBS_Server_id rtems_cbs_server_id;
@@ -88,13 +87,11 @@ RTEMS_INLINE_ROUTINE int rtems_cbs_cleanup ( void )
 RTEMS_INLINE_ROUTINE int rtems_cbs_create_server (
   rtems_cbs_parameters     *params,
-  rtems_cbs_budget_overrun  budget_overrun_callback,
   rtems_cbs_server_id      *server_id
   return _Scheduler_CBS_Create_server(
              params,
-             budget_overrun_callback,
              server_id
@@ -122,11 +119,10 @@ RTEMS_INLINE_ROUTINE int rtems_cbs_attach_thread (
  * @return status code.
 RTEMS_INLINE_ROUTINE int rtems_cbs_detach_thread (
-  rtems_cbs_server_id server_id,
   rtems_id            task_id
-  return _Scheduler_CBS_Detach_thread( server_id, task_id );
+  return _Scheduler_CBS_Detach_thread( task_id );
@@ -190,22 +186,6 @@ RTEMS_INLINE_ROUTINE int rtems_cbs_set_parameters (
- * @brief Get the CBS get execution time.
- * Retrieve time info relative to the current server.
- * @return status code.
-RTEMS_INLINE_ROUTINE int rtems_cbs_get_execution_time (
-  time_t                *exec_time,
-  time_t                *abs_time
-  return _Scheduler_CBS_Get_execution_time( server_id, exec_time, abs_time );
  * @brief Get the remaining CBS budget.
  * Retrieve remaining budget for the current server instance.
diff --git a/cpukit/include/rtems/qreslib.h b/cpukit/include/rtems/qreslib.h
index 88d9aba..18ca488 100644
--- a/cpukit/include/rtems/qreslib.h
+++ b/cpukit/include/rtems/qreslib.h
@@ -110,7 +110,6 @@ RTEMS_INLINE_ROUTINE qos_rv qres_create_server (
              (Scheduler_CBS_Parameters *) params,
-             NULL,
              server_id
@@ -144,7 +143,7 @@ RTEMS_INLINE_ROUTINE qos_rv qres_detach_thread (
   tid_t      task_id
@@ -196,7 +195,7 @@ RTEMS_INLINE_ROUTINE qos_rv qres_get_params (
+/** server_id,
  *  @brief qres set params
  *  Change QoS scheduling parameters.
@@ -214,21 +213,6 @@ RTEMS_INLINE_ROUTINE qos_rv qres_set_params (
- *  @brief qres get execution time
-RTEMS_INLINE_ROUTINE qos_rv qres_get_exec_time (
-  qres_sid_t    server_id,
-  qres_time_t  *exec_time,
-  qres_atime_t *abs_time
  *  @brief qres get current budget
@@ -241,7 +225,7 @@ RTEMS_INLINE_ROUTINE qos_rv qres_get_curr_budget (
   qres_time_t *current_budget
   return _Scheduler_CBS_Get_remaining_budget( server_id, current_budget );
diff --git a/cpukit/include/rtems/score/schedulercbs.h b/cpukit/include/rtems/score/schedulercbs.h
index ee4af2f..cc063c7 100644
--- a/cpukit/include/rtems/score/schedulercbs.h
+++ b/cpukit/include/rtems/score/schedulercbs.h
@@ -1,17 +1,18 @@
- * @file
+ *  @file
- * @ingroup RTEMSScoreSchedulerCBS
+ *  @brief Thread manipulation for the CBS scheduler
- * @brief Thread manipulation for the CBS scheduler
- * This include file contains all the constants and structures associated
- * with the manipulation of threads for the CBS scheduler.
+ *  This include file contains all the constants and structures associated
+ *  with the manipulation of threads for the CBS scheduler.
  *  Copryight (c) 2011 Petr Benes.
  *  Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
+ *  Copyright (C) 2019 Joel Pinto, Research Centre in Real-Time & Embedded Computing Systems (CISTER).
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
@@ -25,7 +26,7 @@
 #include <rtems/score/priority.h>
 #include <rtems/score/rbtree.h>
-#include <rtems/score/scheduleredf.h>
+#include <rtems/score/scheduleredfimpl.h>
 #include <rtems/rtems/signal.h>
 #include <rtems/rtems/timer.h>
@@ -35,14 +36,11 @@ extern "C" {
 #endif
- * @defgroup RTEMSScoreSchedulerCBS CBS Scheduler
+ *  @defgroup RTEMSScoreSchedulerCBS CBS Scheduler
- * @brief CBS Scheduler.
+ *  @ingroup RTEMSScoreScheduler
 #define SCHEDULER_CBS_MAXIMUM_PRIORITY SCHEDULER_EDF_MAXIMUM_PRIORITY
@@ -57,7 +55,7 @@ extern "C" {
     _Scheduler_EDF_Initialize,       /* initialize entry point */ \
     _Scheduler_EDF_Schedule,         /* schedule entry point */ \
     _Scheduler_EDF_Yield,            /* yield entry point */ \
-    _Scheduler_EDF_Block,            /* block entry point */ \
+    _Scheduler_CBS_Block,            /* block entry point */ \
     _Scheduler_CBS_Unblock,          /* unblock entry point */ \
     _Scheduler_EDF_Update_priority,  /* update priority entry point */ \
     _Scheduler_EDF_Map_priority,     /* map priority entry point */ \
@@ -94,10 +92,6 @@ extern const uint32_t _Scheduler_CBS_Maximum_servers;
 /** Server id. */
 typedef uint32_t Scheduler_CBS_Server_id;
-typedef void (*Scheduler_CBS_Budget_overrun)(
-    Scheduler_CBS_Server_id server_id
  * This structure handles server parameters.
@@ -114,16 +108,20 @@ typedef struct {
 typedef struct {
-   * Task id.
-   * @note: The current implementation of CBS handles only one task per server.
+   * Current served task
-  rtems_id                 task_id;
+  rtems_id                 current_thread;
   /** Server paramenters. */
   Scheduler_CBS_Parameters parameters;
-  /** Callback function invoked when a budget overrun occurs. */
-  Scheduler_CBS_Budget_overrun  cbs_budget_overrun;
+  /* Absolute deadline of the server. */
+  Priority_Node            priority;
+  /** Remaining reserved capacity. */
+  int32_t                 remaining_budget;
+   * Server's RB-Tree
+   * Job's are enqueued and ordered by their deadline ( deadline given by the RM Manager).
+  RBTree_Control     tree;
    * @brief Indicates if this CBS server is initialized.
@@ -139,9 +137,14 @@ typedef struct {
   /** EDF scheduler specific data of a task. */
   Scheduler_EDF_Node            Base;
   /** CBS server specific data of a task. */
-  Scheduler_CBS_Server         *cbs_server;
+  Scheduler_CBS_Server         *server;
   Priority_Node                *deadline_node;
+  RBTree_Node                   thread_cbs_node;
+  /** thread deadline given by RM Manager. */
+  uint64_t                      rms_dead;
 } Scheduler_CBS_Node;
@@ -151,28 +154,18 @@ typedef struct {
 extern Scheduler_CBS_Server _Scheduler_CBS_Server_list[];
- * @brief Unblocks a thread.
- * @param scheduler The scheduler control.
- * @param the_thread The thread to unblock.
- * @param node The scheduler node.
 void _Scheduler_CBS_Unblock(
   const Scheduler_Control *scheduler,
   Thread_Control          *the_thread,
   Scheduler_Node          *node
- * @brief Releases a job.
- * @param scheduler The scheduler for the operation.
- * @param the_thread The corresponding thread.
- * @param priority_node The priority node for the operation.
- * @param deadline The deadline for the job.
- * @param queue_context The thread queue context.
+void _Scheduler_CBS_Block(
+  const Scheduler_Control *scheduler,
+  Thread_Control          *the_thread,
+  Scheduler_Node          *the_node
 void _Scheduler_CBS_Release_job(
@@ -181,14 +174,6 @@ void _Scheduler_CBS_Release_job(
   Thread_queue_Context    *queue_context
- * @brief Cancels a job.
 void _Scheduler_CBS_Cancel_job(
@@ -197,27 +182,20 @@ void _Scheduler_CBS_Cancel_job(
- * @brief _Scheduler_CBS_Initialize
+ *  @brief _Scheduler_CBS_Initialize
- * Initializes the CBS library.
+ *  Initializes the CBS library.
- * @return SCHEDULER_CBS_OK This method always returns this status.
+ *  @retval status code.
 int _Scheduler_CBS_Initialize(void);
- * @brief Attaches a task to an already existing server.
- * Attach a task to an already existing server.
+ *  @brief Attach a task to an already existing server.
- * @param server_id The id of the existing server.
- * @param task_id The id of the task to attach.
+ *  Attach a task to an already existing server.
- * @retval SCHEDULER_CBS_OK The operation was successful.
- * @retval SCHEDULER_CBS_ERROR_INVALID_PARAMETER The server id is so big
- *      or there is no thread for this task id.
- * @retval SCHEDULER_CBS_ERROR_NOSERVER The server is not yet initialized.
- * @retval SCHEDULER_CBS_ERROR_FULL The server already has a task.
 int _Scheduler_CBS_Attach_thread (
   Scheduler_CBS_Server_id server_id,
@@ -225,81 +203,57 @@ int _Scheduler_CBS_Attach_thread (
- * @brief Detaches from the CBS Server.
+ *  @brief Detach from the CBS Server.
- * Detach from the CBS Server.
+ *  Detach from the CBS Server.
- * @retval SCHEDULER_CBS_ERROR_INVALID_PARAMETER The server id is to big,
- *      or the task with this id is not attached to this server or there is
- *      no thread with this task.
 int _Scheduler_CBS_Detach_thread (
-  Scheduler_CBS_Server_id server_id,
   rtems_id                task_id
- * @brief Cleans up resources associated to the CBS Library.
+ *  @brief Cleanup resources associated to the CBS Library.
- * Cleanup resources associated to the CBS Library.
+ *  Cleanup resources associated to the CBS Library.
- * @return This method always returns SCHEDULER_CBS_OK.
 int _Scheduler_CBS_Cleanup (void);
- * @brief Creates a new server with specified parameters.
+ *  @brief Create a new server with specified parameters.
- * Create a new server with specified parameters.
+ *  Create a new server with specified parameters.
- * @param params The parameters for the server.
- * @param budget_overrun_callback The budget overrun for the new server.
- * @param[out] server_id In the case of success, this parameter contains the
- *      id of the newly created server.
- * @retval SCHEDULER_CBS_OK The operation succeeded.
- * @retval SCHEDULER_CBS_ERROR_INVALID_PARAMETER The given parameters are invalid.
- * @retval SCHEDULER_CBS_ERROR_FULL The maximum number of servers was already
- *      created, a new server cannot be created.
 int _Scheduler_CBS_Create_server (
   Scheduler_CBS_Parameters     *params,
-  Scheduler_CBS_Budget_overrun  budget_overrun_callback,
   rtems_id                     *server_id
- * @brief Detaches all tasks from a server and destroys it.
+ *  @brief Detach all tasks from a server and destroy it.
- * Detach all tasks from a server and destroy it.
+ *  Detach all tasks from a server and destroy it.
- * @param server_id The id of the server to destroy.
+ *  @param[in] server_id is the ID of the server
- * @retval SCHEDULER_CBS_ERROR_INVALID_PARAMETER The server id is too big.
- * @retval SCHEDULER_CBS_ERROR_NOSERVER There is no initialized server with this id.
 int _Scheduler_CBS_Destroy_server (
- * @brief Retrieves the approved budget.
- * Retrieve the budget that has been approved for the subsequent
- * server instances.
+ *  @brief Retrieve the approved budget.
- * @param server_id The id of the server instance of which the budget is wanted.
- * @param[out] approved_budget Contains the approved budget after a successful method call.
+ *  Retrieve the budget that has been approved for the subsequent
+ *  server instances.
 int _Scheduler_CBS_Get_approved_budget (
@@ -307,52 +261,25 @@ int _Scheduler_CBS_Get_approved_budget (
- * @brief Retrieves remaining budget for the current server instance.
- * Retrieve remaining budget for the current server instance.
+ *  @brief Retrieve remaining budget for the current server instance.
- * @param server_id The id of the server instance of which the remaining budget is wanted.
- * @param[out] remaining_budget Contains the remaining budget after a successful method call.
+ *  Retrieve remaining budget for the current server instance.
 int _Scheduler_CBS_Get_remaining_budget (
   time_t                  *remaining_budget
- * @brief Gets relative time info.
- * Retrieve time info relative to @a server_id. The server status code is returned.
- * @param server_id is the server to get the status code from.
- * @param[out] exec_time Contains the execution time after a successful method call.
- * @param abs_time Not apparently used.
-int _Scheduler_CBS_Get_execution_time (
-  time_t                   *abs_time
- * @brief Retrieves CBS scheduling parameters.
- * Retrieve CBS scheduling parameters.
+ *  @brief Retrieve CBS scheduling parameters.
- * @param server_id The id of the server to get the scheduling parameters from.
- * @param[out] params Will contain the scheduling parameters after successful method call.
+ *  Retrieve CBS scheduling parameters.
 int _Scheduler_CBS_Get_parameters (
@@ -360,15 +287,12 @@ int _Scheduler_CBS_Get_parameters (
- * @brief Gets a thread server id.
+ *  @brief Get a thread server id.
- * Get a thread server id, or SCHEDULER_CBS_ERROR_NOT_FOUND if it is not
- * attached to any server.
+ *  Get a thread server id, or SCHEDULER_CBS_ERROR_NOT_FOUND if it is not
+ *  attached to any server.
- * @param task_id The id of the task to get the corresponding server.
- * @param[out] server_id Will contain the server id after successful method call.
- * @retval SCHEDULER_CBS_ERROR_NOSERVER There is no server with this task attached.
 int _Scheduler_CBS_Get_server_id (
   rtems_id                 task_id,
@@ -376,17 +300,14 @@ int _Scheduler_CBS_Get_server_id (
- * @brief Sets parameters for CBS scheduling.
+ *  @brief Set parameters for CBS scheduling.
- * Change CBS scheduling parameters.
+ *  Change CBS scheduling parameters.
- * @param server_id The id of the server.
- * @param parameters The parameters to set.
+ *  @param[in] server_id is the ID of the server.
+ *  @param[in] parameters are the parameters to set.
- * @retval SCHEDULER_CBS_ERROR_INVALID_PARAMETER The server id is too big or the
- *      given parameters are invalid.
- * @retval SCHEDULER_CBS_ERROR_NOSERVER There is no server with this id.
 int _Scheduler_CBS_Set_parameters (
@@ -394,23 +315,16 @@ int _Scheduler_CBS_Set_parameters (
- * @brief Invoked when a limited time quantum is exceeded.
+ *  @brief Invoked when a limited time quantum is exceeded.
- * This routine is invoked when a limited time quantum is exceeded.
- * @param the_thread The thread that exceeded a limited time quantum.
+ *  This routine is invoked when a limited time quantum is exceeded.
 void _Scheduler_CBS_Budget_callout(
- * @brief Initializes a CBS specific scheduler node of @a the_thread.
- * @param scheduler The scheduler control for the operation.
- * @param[out] node The scheduler node to initalize.
- * @param the_thread The thread to initialize a scheduler node for.
- * @param priority The priority for the node.
+ *  @brief Initializes a CBS specific scheduler node of @a the_thread.
 void _Scheduler_CBS_Node_initialize(
@@ -423,7 +337,7 @@ void _Scheduler_CBS_Node_initialize(
 #endif
 #endif
 /* end of include file */
diff --git a/cpukit/include/rtems/score/schedulercbsimpl.h b/cpukit/include/rtems/score/schedulercbsimpl.h
index 7985adb..927d43b 100644
--- a/cpukit/include/rtems/score/schedulercbsimpl.h
+++ b/cpukit/include/rtems/score/schedulercbsimpl.h
@@ -14,6 +14,8 @@
  *  82178 Puchheim
  *  Germany
  *  <rtems at embedded-brains.de>
@@ -24,8 +26,7 @@
 #define _RTEMS_SCORE_SCHEDULERCBSIMPL_H
 #include <rtems/score/schedulercbs.h>
-#include <rtems/score/schedulerimpl.h>
+#include <inttypes.h>
 #ifdef __cplusplus
 extern "C" {
 #endif /* __cplusplus */
@@ -36,13 +37,6 @@ extern "C" {
- * @brief Gets the CBS node of the thread.
- * @param the_thread The thread to get the CBS node of.
- * @return Pointer to the scheduler node of @a the_thread.
 RTEMS_INLINE_ROUTINE Scheduler_CBS_Node *_Scheduler_CBS_Thread_get_node(
@@ -50,13 +44,6 @@ RTEMS_INLINE_ROUTINE Scheduler_CBS_Node *_Scheduler_CBS_Thread_get_node(
   return (Scheduler_CBS_Node *) _Thread_Scheduler_get_home_node( the_thread );
- * @brief Casts the scheduler node to a scheduler CBS node.
- * @param node The node to be casted to a scheduler CBS node.
- * @return CBS Node pointer to @a node.
 RTEMS_INLINE_ROUTINE Scheduler_CBS_Node *_Scheduler_CBS_Node_downcast(
@@ -64,6 +51,206 @@ RTEMS_INLINE_ROUTINE Scheduler_CBS_Node *_Scheduler_CBS_Node_downcast(
   return (Scheduler_CBS_Node *) node;
+RTEMS_INLINE_ROUTINE Thread_Control *_Scheduler_CBS_Node_get_owner
+  Scheduler_CBS_Node *node
+  return _Scheduler_Node_get_owner(&node->Base.Base);
+RTEMS_INLINE_ROUTINE Scheduler_CBS_Node *_Scheduler_CBS_Node_Retrieve(
+  const RBTree_Node *cbs_tree_node
+  return RTEMS_CONTAINER_OF( cbs_tree_node, Scheduler_CBS_Node, thread_cbs_node );
+RTEMS_INLINE_ROUTINE bool _Scheduler_CBS_less(
+  const  void         *left,
+  const  RBTree_Node  *right
+  const Scheduler_CBS_Node  *node;
+  const Priority_Control    *the_left;
+  the_left = left;
+  node = _Scheduler_CBS_Node_Retrieve( right );
+  return *the_left<=node->rms_dead;
+RTEMS_INLINE_ROUTINE void _Scheduler_CBS_Dequeue_Thread_Node(
+  RBTree_Control  *tree,
+  RBTree_Node            *node
+  _RBTree_Extract( tree, node );
+RTEMS_INLINE_ROUTINE void _Scheduler_CBS_Enqueue_Thread_Node(
+  RBTree_Node       *node,
+  const uint64_t     priority
+  _RBTree_Insert_inline( tree, node, &priority, _Scheduler_CBS_less );
+RTEMS_INLINE_ROUTINE  bool _Scheduler_CBS_Node_equal(
+  Scheduler_CBS_Node *the_node,
+  RBTree_Node        *node
+  Scheduler_CBS_Node *cbs_node;
+  Thread_Control     *the_thread, *cpm_thread;
+  cbs_node = _Scheduler_CBS_Node_Retrieve( node );
+  the_thread = _Scheduler_CBS_Node_get_owner( the_node );
+  cpm_thread = _Scheduler_CBS_Node_get_owner( cbs_node );
+  return _Objects_Are_ids_equal( the_thread->Object.id, cpm_thread->Object.id );
+RTEMS_INLINE_ROUTINE void _Scheduler_CBS_RBNode_search(
+  RBTree_Control       *the_tree,
+  void               ( *found )( RBTree_Control *, RBTree_Node *)
+  RBTree_Node * const *node;
+  const RBTree_Control  *tree;
+  uint64_t key;
+  tree = the_tree;
+  key = the_node->rms_dead;
+  node = _RBTree_Root_const_reference( tree );
+  while( *node != NULL )
+    if( _Scheduler_CBS_Node_equal( the_node, *node ) ) {
+      ( *found )( the_tree, &the_node->thread_cbs_node );
+      break;
+    } else if( _Scheduler_CBS_less( &key, *node ) ) {
+      node = _RBTree_Left_reference( *node );
+    } else {
+      node = _RBTree_Right_reference( *node );
+RTEMS_INLINE_ROUTINE void _Scheduler_CBS_Update_Deadline(
+  Priority_Control *old_deadline,
+  Per_CPU_Control  *cpu_self,
+  const uint32_t    period
+  Priority_Control priority;
+  priority = *old_deadline + period;
+  ( priority > cpu_self->Watchdog.ticks ) ? ( *old_deadline = priority ) : ( *old_deadline = cpu_self->Watchdog.ticks + period );
+RTEMS_INLINE_ROUTINE void _Scheduler_CBS_Tranquilize_wait(
+	the_thread->current_state = _States_Clear( STATES_WAITING_FOR_SERVER, the_thread->current_state );
+RTEMS_INLINE_ROUTINE void _Scheduler_CBS_Schedule_Server(
+  Scheduler_CBS_Node      *cbs_node,
+  bool                     release
+  Scheduler_Node       *node;
+  Per_CPU_Control      *cpu_self;
+  Thread_queue_Context  context;
+  uint32_t              time;
+  if( _States_Is_Waiting_For_Server( the_thread->current_state ) )
+		_Scheduler_CBS_Tranquilize_wait( the_thread );
+  cbs_node->server->current_thread = the_thread->Object.id;
+  node = _Thread_Scheduler_get_home_node( the_thread );
+  cpu_self = _Per_CPU_Get();
+  ( cbs_node->server->priority.priority < cpu_self->Watchdog.ticks ) ? ( time=0 ) : ( time=cpu_self->Watchdog.ticks );
+  if( ( ( cbs_node->server->remaining_budget * cbs_node->server->parameters.deadline ) > ( ( cbs_node->server->priority.priority - time ) * cbs_node->server->parameters.budget ) )
+   || cbs_node->server->remaining_budget <= 0 ) {
+    _Scheduler_CBS_Update_Deadline( &cbs_node->server->priority.priority, cpu_self, cbs_node->server->parameters.deadline );
+    cbs_node->server->remaining_budget = cbs_node->server->parameters.budget;
+  the_thread->cpu_time_budget = cbs_node->server->remaining_budget;
+  _Priority_Node_set_priority( cbs_node->deadline_node, SCHEDULER_PRIORITY_MAP( cbs_node->server->priority.priority ) );
+  _Thread_queue_Context_clear_priority_updates( &context );
+  if( _Priority_Node_is_active( cbs_node->deadline_node ) ) {
+    _Thread_Priority_changed(
+      the_thread,
+      cbs_node->deadline_node,
+      false,
+      &context
+  } else {
+    _Thread_Priority_add( the_thread, cbs_node->deadline_node, &context );
+  if( release ) {
+    _Scheduler_EDF_Update_priority( scheduler, the_thread, node );
+  } else {
+    _Scheduler_EDF_Unblock(scheduler, the_thread, node);
+RTEMS_INLINE_ROUTINE void _Scheduler_CBS_Update_Heir (
+  _Thread_Set_state( the_thread, STATES_WAITING_FOR_SERVER );
+RTEMS_INLINE_ROUTINE void _Scheduler_CBS_Schedule(
+  Scheduler_CBS_Server    *server,
+  bool                     release
+  Scheduler_CBS_Node    *minimum_node_cbs;
+  RBTree_Node           *minimum_node;
+  Thread_Control        *heir_thread, *the_thread;
+  ISR_lock_Context       lock_context;
+  minimum_node = _RBTree_Minimum( &server->tree );
+  if( minimum_node == NULL )
+    return;
+  minimum_node_cbs =  _Scheduler_CBS_Node_Retrieve( minimum_node );
+  heir_thread = _Scheduler_CBS_Node_get_owner( minimum_node_cbs );
+  if( server->current_thread != heir_thread->Object.id ) {
+    if( server->current_thread != -1 ) {
+      the_thread = _Thread_Get( server->current_thread, &lock_context );
+      _ISR_lock_ISR_enable( &lock_context );
+      _Scheduler_CBS_Update_Heir( the_thread );
+    } else {
+      _Scheduler_CBS_Schedule_Server( scheduler, heir_thread, minimum_node_cbs, release );
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/score/statesimpl.h b/cpukit/include/rtems/score/statesimpl.h
index 49d4395..8024cac 100644
--- a/cpukit/include/rtems/score/statesimpl.h
+++ b/cpukit/include/rtems/score/statesimpl.h
@@ -101,6 +101,9 @@ extern "C" {
 /** This macro corresponds to a task those life is changing. */
 #define STATES_LIFE_IS_CHANGING                0x00020000
+/** This macro corresponds to a thread that sufferred from a preemption in server context */
+#define STATES_WAITING_FOR_SERVER              0x00040000
 /** This macro corresponds to a task being held by the debugger. */
 #define STATES_DEBUGGER                        0x08000000
@@ -236,15 +239,28 @@ RTEMS_INLINE_ROUTINE bool _States_Is_suspended (
- * @brief Checks if WAITING_FOR_TIME state is set.
+ *  This function returns true if the ZOMBIE state is set in
+ * the_state, and false otherwise.
+ * @param[in] the_states is the task state set to test
+ * @return This method returns true if the desired state condition is set
+RTEMS_INLINE_ROUTINE bool _States_Is_zombie (
+  States_Control the_states
+  return (the_states & STATES_ZOMBIE);
  * This function returns true if the WAITING_FOR_TIME state is set in
- * @a the_states, and false otherwise.
+ * the_states, and false otherwise.
- * @param the_states The task state set to test.
- * @retval true WAITING_FOR_TIME state is set in @a the_states.
- * @retval false WAITING_FOR_TIME state is not set in @a the_states.
+ * @return This method returns true if the desired state condition is set.
 RTEMS_INLINE_ROUTINE bool _States_Is_waiting_for_rpc_reply (
@@ -272,43 +288,49 @@ RTEMS_INLINE_ROUTINE bool _States_Is_waiting_for_join_at_exit(
- * @brief Checks if the state is set to be interruptible.
  * This function returns true if the task's state is set in
  * way that allows it to be interrupted by a signal.
- * @retval true @a the_states is interruptible.
- * @retval false @a the_states is not interruptible.
 RTEMS_INLINE_ROUTINE bool _States_Is_interruptible_by_signal (
-   return (the_states & STATES_INTERRUPTIBLE_BY_SIGNAL);
+  return (the_states & STATES_INTERRUPTIBLE_BY_SIGNAL);
- * @brief Checks if the state is blocked waiting on a local resource.
  * This function returns true if one of the states which indicates
  * that a task is blocked waiting for a local resource is set in
- * @retval true The state indicates that the task is blocked waiting on a local
- *      resource.
- * @retval false The state indicates that the task is not blocked waiting on a
- *      local resource.
 RTEMS_INLINE_ROUTINE bool _States_Is_locally_blocked (
-   return (the_states & STATES_LOCALLY_BLOCKED);
+  return (the_states & STATES_LOCALLY_BLOCKED);
+ * This function returns true if STATES_WAITING_FOR_SERVER is set in the thread
+ * current states, and false otherwise.
+ * @param[in] the_states is the tasj state set to test
+RTEMS_INLINE_ROUTINE bool _States_Is_Waiting_For_Server (
+  return ( the_states & STATES_WAITING_FOR_SERVER );
diff --git a/cpukit/score/src/schedulercbs.c b/cpukit/score/src/schedulercbs.c
index d4001d8..3878352 100644
--- a/cpukit/score/src/schedulercbs.c
+++ b/cpukit/score/src/schedulercbs.c
@@ -8,6 +8,8 @@
  *  Copyright (C) 2011 Petr Benes.
@@ -24,30 +26,11 @@ void _Scheduler_CBS_Budget_callout(
-  Scheduler_CBS_Node      *node;
-  Scheduler_CBS_Server_id  server_id;
-  Thread_queue_Context     queue_context;
+  Scheduler_CBS_Node      *the_node;
+  the_node = _Scheduler_CBS_Thread_get_node( the_thread );
-  node = _Scheduler_CBS_Thread_get_node( the_thread );
-  /* Put violating task to background until the end of period. */
-  _Thread_queue_Context_clear_priority_updates( &queue_context );
-  _Scheduler_CBS_Cancel_job(
-    NULL,
-    the_thread,
-    node->deadline_node,
-    &queue_context
-  _Thread_Priority_update( &queue_context );
-  /* Invoke callback function if any. */
-  if ( node->cbs_server->cbs_budget_overrun ) {
-    _Scheduler_CBS_Get_server_id(
-        node->cbs_server->task_id,
-        &server_id
-    node->cbs_server->cbs_budget_overrun( server_id );
diff --git a/cpukit/score/src/schedulercbsattachthread.c b/cpukit/score/src/schedulercbsattachthread.c
index 4193882..dbe0923 100644
--- a/cpukit/score/src/schedulercbsattachthread.c
+++ b/cpukit/score/src/schedulercbsattachthread.c
@@ -6,8 +6,11 @@
+ *  Copyright (C) 2019 Joel Pinto, , Research Centre in Real-Time & Embedded Computing Systems (CISTER).
@@ -19,7 +22,6 @@
 #endif
 #include <rtems/score/schedulercbsimpl.h>
-#include <rtems/score/threadimpl.h>
@@ -41,10 +43,6 @@ int _Scheduler_CBS_Attach_thread (
     return SCHEDULER_CBS_ERROR_NOSERVER;
-  if ( server->task_id != -1 ) {
-    return SCHEDULER_CBS_ERROR_FULL;
   the_thread = _Thread_Get( task_id, &lock_context );
   if ( the_thread == NULL ) {
@@ -53,15 +51,13 @@ int _Scheduler_CBS_Attach_thread (
-  if ( node->cbs_server != NULL ) {
+  if ( node->server != NULL ) {
-  node->cbs_server = server;
-  server->task_id = task_id;
+  node->server = server;
   the_thread->budget_callout   = _Scheduler_CBS_Budget_callout;
   the_thread->budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_CALLOUT;
   the_thread->is_preemptible   = true;
diff --git a/cpukit/score/src/schedulercbsblock.c b/cpukit/score/src/schedulercbsblock.c
new file mode 100644
index 0000000..0f4f92d
--- /dev/null
+++ b/cpukit/score/src/schedulercbsblock.c
@@ -0,0 +1,60 @@
+ * @file
+ * @ Removes the Thread from the Ready Queue
+ * @ingroup ScoreScheduler
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/schedulercbsimpl.h>
+void _Scheduler_CBS_Block (
+  the_node = _Scheduler_CBS_Node_downcast( node );
+  server = NULL;
+  if( the_node->server != NULL ) {
+    if( _Objects_Are_ids_equal( the_node->server->current_thread, the_thread->Object.id ) ) {
+      the_node->server->remaining_budget = the_thread->cpu_time_budget;
+      the_node->server->current_thread = -1;
+      server = the_node->server;
+    if( !_States_Is_Waiting_For_Server( the_thread->current_state ) ) {
+      _Scheduler_CBS_RBNode_search( &the_node->server->tree, the_node, _Scheduler_CBS_Dequeue_Thread_Node );
+      if( _States_Is_zombie( the_thread->current_state ) )
+        the_node->server = NULL;
+  _Scheduler_EDF_Block(
+    scheduler,
+    the_thread,
+    node
+  //if( server != NULL && ( _States_Is_zombie( the_thread->current_state ) || _States_Is_Waiting_For_period( the_thread->current_state ) || _States_Is_Waiting_For_Server( the_thread->current_state ) ) )
+  if( server != NULL )
+    _Scheduler_CBS_Schedule( scheduler, server, false );
\ No newline at end of file
diff --git a/cpukit/score/src/schedulercbscreateserver.c b/cpukit/score/src/schedulercbscreateserver.c
index 15262cf..07457df 100644
--- a/cpukit/score/src/schedulercbscreateserver.c
+++ b/cpukit/score/src/schedulercbscreateserver.c
@@ -8,22 +8,23 @@
 #if HAVE_CONFIG_H
 #include "config.h"
 #endif
-#include <rtems/score/scheduleredfimpl.h>
   rtems_id                     *server_id
@@ -47,8 +48,11 @@ int _Scheduler_CBS_Create_server (
   *server_id = i;
   the_server = &_Scheduler_CBS_Server_list[*server_id];
   the_server->parameters = *params;
-  the_server->task_id = -1;
-  the_server->cbs_budget_overrun = budget_overrun_callback;
+  the_server->current_thread = -1;
+  the_server->remaining_budget = the_server->parameters.budget;
   the_server->initialized = true;
+  _RBTree_Initialize_empty( &the_server->tree );
   return SCHEDULER_CBS_OK;
diff --git a/cpukit/score/src/schedulercbsdestroyserver.c b/cpukit/score/src/schedulercbsdestroyserver.c
index 5121e3a..1a044e4 100644
--- a/cpukit/score/src/schedulercbsdestroyserver.c
+++ b/cpukit/score/src/schedulercbsdestroyserver.c
@@ -9,6 +9,8 @@
@@ -19,25 +21,22 @@
 #include "config.h"
 #endif
-#include <rtems/score/schedulercbs.h>
-  int ret = SCHEDULER_CBS_OK;
-  rtems_id tid;
   if ( server_id >= _Scheduler_CBS_Maximum_servers )
     return SCHEDULER_CBS_ERROR_INVALID_PARAMETER;
   if ( !_Scheduler_CBS_Server_list[server_id].initialized )
-  if ( (tid = _Scheduler_CBS_Server_list[server_id].task_id) != -1 )
-    ret = _Scheduler_CBS_Detach_thread ( server_id, tid );
-  _Scheduler_CBS_Server_list[server_id].initialized = false;
-  return ret;
+  _Scheduler_CBS_Server_list[ server_id ].initialized = false;
+  return SCHEDULER_CBS_OK;
diff --git a/cpukit/score/src/schedulercbsdetachthread.c b/cpukit/score/src/schedulercbsdetachthread.c
index c840c8b..3821301 100644
--- a/cpukit/score/src/schedulercbsdetachthread.c
+++ b/cpukit/score/src/schedulercbsdetachthread.c
@@ -9,58 +9,54 @@
 #if HAVE_CONFIG_H
 #include "config.h"
 #endif
   rtems_id                task_id
-  Scheduler_CBS_Server *server;
-  ISR_lock_Context      lock_context;
+  Thread_Close_context  context;
   Thread_Control       *the_thread;
-  if ( server_id >= _Scheduler_CBS_Maximum_servers ) {
+  the_thread =  _Thread_Get( task_id, &context.Base.Lock_context.Lock_context );
+  if( the_thread == NULL )
+  _ISR_lock_ISR_enable( &context.Base.Lock_context.Lock_context );
-  server = &_Scheduler_CBS_Server_list[ server_id ];
-  if ( !server->initialized ) {
+  if( the_node->server == NULL )
-  if ( server->task_id != task_id ) {
-    return SCHEDULER_CBS_ERROR_INVALID_PARAMETER;
+  if( the_thread == _Thread_Executing ) {
+    cpu_self = _Thread_queue_Dispatch_disable( &context.Base );
+    _Thread_Exit(
+      the_thread,
+      THREAD_LIFE_TERMINATING | THREAD_LIFE_DETACHED,
+      NULL
+    _Thread_Dispatch_enable( cpu_self );
+  } else {
+    _Thread_Close( the_thread, _Thread_Executing, &context );
-  the_thread = _Thread_Get( task_id, &lock_context );
-  if ( the_thread == NULL ) {
-  node->cbs_server = NULL;
-  server->task_id = -1;
-  the_thread->budget_algorithm = the_thread->Start.budget_algorithm;
-  the_thread->budget_callout   = the_thread->Start.budget_callout;
-  the_thread->is_preemptible   = the_thread->Start.is_preemptible;
-  _ISR_lock_ISR_enable( &lock_context );
diff --git a/cpukit/score/src/schedulercbsgetapprovedbudget.c b/cpukit/score/src/schedulercbsgetapprovedbudget.c
index e72ef3b..cf221f8 100644
--- a/cpukit/score/src/schedulercbsgetapprovedbudget.c
+++ b/cpukit/score/src/schedulercbsgetapprovedbudget.c
@@ -8,6 +8,8 @@
@@ -19,8 +21,7 @@
 #endif
 #include <rtems/config.h>
-#include <rtems/score/scheduler.h>
@@ -29,9 +30,11 @@ int _Scheduler_CBS_Get_approved_budget (
   *approved_budget = _Scheduler_CBS_Server_list[server_id].parameters.budget;
diff --git a/cpukit/score/src/schedulercbsgetexecutiontime.c b/cpukit/score/src/schedulercbsgetexecutiontime.c
deleted file mode 100644
index b18ce9a..0000000
--- a/cpukit/score/src/schedulercbsgetexecutiontime.c
+++ /dev/null
@@ -1,60 +0,0 @@
- * @file
- * @brief Get Thread Execution Info
- *  Copyright (C) 2011 Petr Benes.
- *  Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-  time_t                   *abs_time
-  Thread_Control       *the_thread;
-    return SCHEDULER_CBS_ERROR_NOSERVER;
-  if ( server->task_id == -1 ) {
-    *exec_time = 0;
-    return SCHEDULER_CBS_OK;
-  the_thread = _Thread_Get( server->task_id, &lock_context );
-  if ( the_thread != NULL ) {
-    *exec_time = server->parameters.budget - the_thread->cpu_time_budget;
-  } else {
-    *exec_time = server->parameters.budget;
diff --git a/cpukit/score/src/schedulercbsgetparameters.c b/cpukit/score/src/schedulercbsgetparameters.c
index 1abe5d9..3c895a1 100644
--- a/cpukit/score/src/schedulercbsgetparameters.c
+++ b/cpukit/score/src/schedulercbsgetparameters.c
@@ -8,6 +8,8 @@
@@ -19,19 +21,20 @@
 #endif
   *params = _Scheduler_CBS_Server_list[server_id].parameters;
diff --git a/cpukit/score/src/schedulercbsgetremainingbudget.c b/cpukit/score/src/schedulercbsgetremainingbudget.c
index d556f33..c4f88c6 100644
--- a/cpukit/score/src/schedulercbsgetremainingbudget.c
+++ b/cpukit/score/src/schedulercbsgetremainingbudget.c
@@ -8,18 +8,18 @@
 #if HAVE_CONFIG_H
 #include "config.h"
 #endif
@@ -29,7 +29,7 @@ int _Scheduler_CBS_Get_remaining_budget (
@@ -40,18 +40,18 @@ int _Scheduler_CBS_Get_remaining_budget (
-    *remaining_budget = server->parameters.budget;
+  if( server->current_thread == -1 ) {
+    *remaining_budget = server->remaining_budget;
     *remaining_budget = the_thread->cpu_time_budget;
   } else {
-    *remaining_budget = 0;
diff --git a/cpukit/score/src/schedulercbsgetserverid.c b/cpukit/score/src/schedulercbsgetserverid.c
index 276c08f..6ec29e2 100644
--- a/cpukit/score/src/schedulercbsgetserverid.c
+++ b/cpukit/score/src/schedulercbsgetserverid.c
@@ -8,29 +8,44 @@
 #if HAVE_CONFIG_H
 #include "config.h"
 #endif
   rtems_id                 task_id,
   Scheduler_CBS_Server_id *server_id
+  Thread_Control         *the_thread;
+  the_thread = _Thread_Get( task_id, &lock_context );
+    return SCHEDULER_CBS_ERROR_NOT_FOUND;
+  node = _Scheduler_CBS_Thread_get_node( the_thread );
+  if(node->server == NULL)
+    return SCHEDULER_CBS_ERROR_NOSERVER;
   unsigned int i;
   for ( i = 0; i<_Scheduler_CBS_Maximum_servers; i++ ) {
-    if ( _Scheduler_CBS_Server_list[i].initialized &&
-         _Scheduler_CBS_Server_list[i].task_id == task_id ) {
+    if ( &_Scheduler_CBS_Server_list[i] == node->server ) {
       *server_id = i;
diff --git a/cpukit/score/src/schedulercbsnodeinit.c b/cpukit/score/src/schedulercbsnodeinit.c
index 08f63a1..8a16fb4 100644
--- a/cpukit/score/src/schedulercbsnodeinit.c
+++ b/cpukit/score/src/schedulercbsnodeinit.c
@@ -32,6 +32,6 @@ void _Scheduler_CBS_Node_initialize(
   _Scheduler_EDF_Node_initialize( scheduler, node, the_thread, priority );
-  the_node->cbs_server = NULL;
   the_node->deadline_node = NULL;
diff --git a/cpukit/score/src/schedulercbsreleasejob.c b/cpukit/score/src/schedulercbsreleasejob.c
index 3ac07eb..80143d6 100644
--- a/cpukit/score/src/schedulercbsreleasejob.c
+++ b/cpukit/score/src/schedulercbsreleasejob.c
@@ -9,6 +9,8 @@
@@ -29,19 +31,25 @@ void _Scheduler_CBS_Release_job(
-  Scheduler_CBS_Server *serv_info;
+  the_node->deadline_node = priority_node;
-  serv_info = node->cbs_server;
-  /* Budget replenishment for the next job. */
-  if ( serv_info != NULL ) {
-    the_thread->cpu_time_budget = serv_info->parameters.budget;
+    the_node->rms_dead = deadline;
+    if( _States_Is_ready( the_thread->current_state ) ) {
+      _Thread_Wait_acquire_critical( the_thread, queue_context );
+      _Scheduler_CBS_Enqueue_Thread_Node( &the_node->server->tree, &the_node->thread_cbs_node, the_node->rms_dead );
+      _Scheduler_CBS_Schedule( scheduler, the_node->server, true );
+      _Thread_Wait_release_critical( the_thread, queue_context );
+    return;
-  node->deadline_node = priority_node;
   _Scheduler_EDF_Release_job(
     scheduler,
     the_thread,
diff --git a/cpukit/score/src/schedulercbssetparameters.c b/cpukit/score/src/schedulercbssetparameters.c
index 0b8b664..edf6b4f 100644
--- a/cpukit/score/src/schedulercbssetparameters.c
+++ b/cpukit/score/src/schedulercbssetparameters.c
@@ -9,6 +9,8 @@
@@ -19,8 +21,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/schedulercbsunblock.c b/cpukit/score/src/schedulercbsunblock.c
index 4d751f9..9119543 100644
--- a/cpukit/score/src/schedulercbsunblock.c
+++ b/cpukit/score/src/schedulercbsunblock.c
@@ -9,6 +9,8 @@
@@ -20,9 +22,6 @@
 #endif
@@ -32,39 +31,14 @@ void _Scheduler_CBS_Unblock(
-  Priority_Control      priority;
-  serv_info = the_node->cbs_server;
-  priority = _Scheduler_Node_get_priority( &the_node->Base.Base );
-  priority = SCHEDULER_PRIORITY_PURIFY( priority );
-   * Late unblock rule for deadline-driven tasks. The remaining time to
-   * deadline must be sufficient to serve the remaining computation time
-   * without increased utilization of this task. It might cause a deadline
-   * miss of another task.
-  if ( serv_info != NULL && ( priority & SCHEDULER_EDF_PRIO_MSB ) == 0 ) {
-    time_t deadline = serv_info->parameters.deadline;
-    time_t budget = serv_info->parameters.budget;
-    uint32_t deadline_left = the_thread->cpu_time_budget;
-    Priority_Control budget_left = priority - _Watchdog_Ticks_since_boot;
-    if ( deadline * budget_left > budget * deadline_left ) {
-      /* Put late unblocked task to background until the end of period. */
-        scheduler,
-        the_thread,
-        the_node->deadline_node,
-        &queue_context
+  if( the_node->server != NULL && the_node->rms_dead != 0 ) {
+    _Scheduler_CBS_Schedule( scheduler, the_node->server, false );
+    return;
   _Scheduler_EDF_Unblock( scheduler, the_thread, &the_node->Base.Base );
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index eae5630..962c6fd 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -14,6 +14,7 @@ sp_libs =
 support_includes = -I$(top_srcdir)/../support/include
 if TEST_sp01
 sp_tests += sp01
 sp_screens += sp01/sp01.scn
@@ -54,7 +55,7 @@ sp_screens += sp05/sp05.scn
 sp_docs += sp05/sp05.doc
 sp05_SOURCES = sp05/init.c sp05/task1.c sp05/task2.c sp05/task3.c \
 	sp05/system.h
-sp05_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_sp05) $(support_includes)
+sp05_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS40020_sp05) $(support_includes)
 endif
 if TEST_sp06
@@ -680,6 +681,26 @@ spcbssched03_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spcbssched03) \
 	$(support_includes)
 endif
+if TEST_spcbssched04
+sp_tests += spcbssched04
+sp_screens += spcbssched04/spcbssched04.scn
+sp_docs += spcbssched04/spcbssched04.doc
+spcbssched04_SOURCES = spcbssched04/init.c \
+	 spcbssched04/system.h spcbssched04/hard_tasks.c spcbssched04/soft_tasks.c
+spcbssched04_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spcbssched04) \
+	$(support_includes)
+endif
+if TEST_spcbssched05
+sp_tests += spcbssched05
+sp_screens += spcbssched05/spcbssched05.scn
+sp_docs += spcbssched05/spcbssched05.doc
+spcbssched05_SOURCES = spcbssched05/init.c \
+	 spcbssched05/system.h spcbssched05/soft_tasks.c
+spcbssched05_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spcbssched05) \
+endif
 if TEST_spchain
 sp_tests += spchain
 sp_screens += spchain/spchain.scn
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 3222196..98b5868 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -114,6 +114,8 @@ RTEMS_TEST_CHECK([spcache01])
 RTEMS_TEST_CHECK([spcbssched01])
 RTEMS_TEST_CHECK([spcbssched02])
 RTEMS_TEST_CHECK([spcbssched03])
+RTEMS_TEST_CHECK([spcbssched04])
+RTEMS_TEST_CHECK([spcbssched05])
 RTEMS_TEST_CHECK([spchain])
 RTEMS_TEST_CHECK([spclock_err01])
 RTEMS_TEST_CHECK([spclock_err02])
diff --git a/testsuites/sptests/spcbssched02/init.c b/testsuites/sptests/spcbssched02/init.c
index acaf7a7..78b025d 100644
--- a/testsuites/sptests/spcbssched02/init.c
+++ b/testsuites/sptests/spcbssched02/init.c
@@ -87,58 +87,45 @@ rtems_task Init(
     printf( "ERROR: DESTROY SERVER PASSED UNEXPECTEDLY\n" );
   if ( rtems_cbs_destroy_server( 0 ) != SCHEDULER_CBS_ERROR_NOSERVER )
-  if ( rtems_cbs_create_server( &params1, NULL, &server_id ) !=
+  if ( rtems_cbs_create_server( &params1, &server_id ) !=
        SCHEDULER_CBS_ERROR_INVALID_PARAMETER )
     printf( "ERROR: CREATE SERVER PASSED UNEXPECTEDLY\n" );
-  if ( rtems_cbs_create_server( &params3, NULL, &server_id ) !=
+  if ( rtems_cbs_create_server( &params3,  &server_id ) !=
-  if ( rtems_cbs_create_server( &params, NULL, &server_id2 ) )
+  if ( rtems_cbs_create_server( &params,  &server_id2 ) )
     printf( "ERROR: CREATE SERVER FAILED\n" );
-  if ( rtems_cbs_create_server( &params, NULL, &server_id ) )
+  if ( rtems_cbs_create_server( &params,  &server_id ) )
-    printf( "ERROR: CREATE SERVER FAILED\n" );
-  if ( rtems_cbs_create_server( &params, NULL, &server_id ) !=
-       SCHEDULER_CBS_ERROR_FULL )
-    printf( "ERROR: CREATE SERVER PASSED UNEXPECTEDLY\n" );
   /* Error checks for Attach thread and Detach thread */
   printf( "Init: Attach thread\n" );
   if ( rtems_cbs_attach_thread( -5, RTEMS_SELF ) !=
-    printf( "ERROR: ATTACH THREAD PASSED UNEXPECTEDLY\n" );
+    printf( "ERROR: ATTACH THREAD PASSED UNEXPECTEDLY 1\n" );
   if ( rtems_cbs_attach_thread( 5, RTEMS_SELF ) !=
+    printf( "ERROR: ATTACH THREAD PASSED UNEXPECTEDLY 2 \n" );
   if ( rtems_cbs_attach_thread( server_id, 1234 ) !=
-  if ( rtems_cbs_attach_thread( server_id, RTEMS_SELF ) )
-    printf( "ERROR: ATTACH THREAD FAILED\n" );
-  if ( rtems_cbs_attach_thread( server_id, RTEMS_SELF ) !=
-    printf( "ERROR: ATTACH THREAD AGAIN PASSED UNEXPECTEDLY\n" );
-  if ( rtems_cbs_attach_thread( server_id, Task_id ) !=
-    printf( "ERROR: ATTACH THREAD TO FULL SERVER PASSED UNEXPECTEDLY \n" );
+    printf( "ERROR: ATTACH THREAD PASSED UNEXPECTEDLY 3\n" );
   if ( rtems_cbs_destroy_server( server_id ) )
     printf( "ERROR: DESTROY SERVER WITH THREAD ATTACHED FAILED\n" );
+    printf( "ERROR: ATTACH THREAD PASSED UNEXPECTEDLY 4\n" );
   printf( "Init: Detach thread\n" );
-  if ( rtems_cbs_detach_thread( -5, RTEMS_SELF ) !=
-       SCHEDULER_CBS_ERROR_INVALID_PARAMETER )
+  if ( rtems_cbs_detach_thread( RTEMS_SELF ) !=
+       SCHEDULER_CBS_ERROR_NOSERVER )
     printf( "ERROR: DETACH THREAD PASSED UNEXPECTEDLY\n" );
-  if ( rtems_cbs_detach_thread( 5, RTEMS_SELF ) !=
-  if ( rtems_cbs_detach_thread( server_id2, 1234 ) !=
+  if ( rtems_cbs_detach_thread( 1234 ) !=
     printf( "ERROR: DETACH THREAD PASSED UNEXPECTEDLY \n" );
-  if ( rtems_cbs_detach_thread( server_id, RTEMS_SELF ) !=
     printf( "ERROR: DETACH THREAD PASSED UNEXPECTEDLY4\n" );
   rtems_cbs_destroy_server( server_id2 );
@@ -160,7 +147,7 @@ rtems_task Init(
     printf( "ERROR: GET PARAMETERS PASSED UNEXPECTEDLY\n" );
   if ( rtems_cbs_get_parameters( 5, &params ) !=
-    printf( "ERROR: GET PARAMETERS PASSED UNEXPECTEDLY\n" );
+    printf( "ERROR: GET PARAM/*ETERS PASSED UNEXPECTEDLY\n" );
   if ( rtems_cbs_get_parameters( server_id, &params ) !=
@@ -186,9 +173,7 @@ rtems_task Init(
   if ( rtems_cbs_get_approved_budget( 5, &approved_budget ) !=
     printf( "ERROR: GET APPROVED BUDGET PASSED UNEXPECTEDLY\n" );
-  if ( rtems_cbs_get_approved_budget( server_id, &approved_budget ) !=
-       SCHEDULER_CBS_ERROR_NOSERVER )
-    printf( "ERROR: GET APPROVED BUDGET PASSED UNEXPECTEDLY\n" );
   /* Error checks for Get remaining budget */
   printf( "Init: Get remaining budget\n" );
@@ -198,26 +183,13 @@ rtems_task Init(
   if ( rtems_cbs_get_remaining_budget( 5, &remaining_budget ) !=
     printf( "ERROR: GET REMAINING BUDGET PASSED UNEXPECTEDLY\n" );
-  if ( rtems_cbs_get_remaining_budget( server_id, &remaining_budget ) !=
-    printf( "ERROR: GET REMAINING BUDGET PASSED UNEXPECTEDLY\n" );
-  /* Error checks for Get execution time */
-  printf( "Init: Get execution time\n" );
-  if ( rtems_cbs_get_execution_time( -5, &exec_time, &abs_time ) !=
-    printf( "ERROR: GET EXECUTION TIME PASSED UNEXPECTEDLY\n" );
-  if ( rtems_cbs_get_execution_time( 5, &exec_time, &abs_time ) !=
-  if ( rtems_cbs_get_execution_time( server_id, &exec_time, &abs_time ) !=
   /* Restart CBS library */
   printf( "Init: Cleaning up CBS\n" );
   if ( rtems_cbs_cleanup() )
     printf( "ERROR: CBS CLEANUP FAILED\n" );
   printf( "Init: Initializing the CBS\n" );
   if ( rtems_cbs_initialize() )
     printf( "ERROR: CBS INITIALIZATION FAILED\n" );
@@ -231,12 +203,6 @@ rtems_task Init(
   rtems_task_wake_after( 130 );
-  printf( "Init: Checking server with a deleted task\n" );
-  if ( rtems_cbs_get_execution_time( 0, &exec_time, &abs_time ) )
-    printf( "ERROR: GET EXECUTION TIME FAILED\n" );
-  if ( rtems_cbs_get_remaining_budget( 0, &remaining_budget) )
-    printf( "ERROR: GET REMAINING BUDGET FAILED\n" );
     printf( "ERROR: CBS CLEANUP\n" );
diff --git a/testsuites/sptests/spcbssched02/task_periodic.c b/testsuites/sptests/spcbssched02/task_periodic.c
index 39516cc..0e1b1e6 100644
--- a/testsuites/sptests/spcbssched02/task_periodic.c
+++ b/testsuites/sptests/spcbssched02/task_periodic.c
@@ -26,7 +26,7 @@ rtems_task Task_Periodic(
   rtems_id          rmid;
   rtems_status_code status;
-  time_t approved_budget, exec_time, abs_time, remaining_budget;
+  time_t approved_budget;
   int start, stop, now;
@@ -35,11 +35,13 @@ rtems_task Task_Periodic(
   params.deadline = Period;
   params.budget = Execution+1;
+  printf(" here \n");
   /* Taks 1 will be attached to a server, task 2 not. */
   if ( argument == 1 ) {
     printf( "Periodic task: Create server and Attach thread\n" );
     if ( rtems_cbs_attach_thread( server_id, Task_id ) )
@@ -55,25 +57,6 @@ rtems_task Task_Periodic(
          params.budget != tparams.budget )
       printf( "ERROR: PARAMETERS MISMATCH\n" );
-    printf( "Periodic task: Detach thread and Destroy server\n" );
-    if ( rtems_cbs_detach_thread( server_id, Task_id ) )
-      printf( "ERROR: DETACH THREAD FAILED\n" );
-    if ( rtems_cbs_destroy_server( server_id ) )
-      printf( "ERROR: DESTROY SERVER FAILED\n" );
-    printf( "Periodic task: Remaining budget and Execution time\n" );
-    if ( rtems_cbs_get_remaining_budget( server_id, &remaining_budget ) )
-    if ( remaining_budget != params.budget )
-      printf( "ERROR: REMAINING BUDGET MISMATCH\n" );
-    if ( rtems_cbs_get_execution_time( server_id, &exec_time, &abs_time ) )
-    printf( "Periodic task: Set parameters\n" );
-    if ( rtems_cbs_attach_thread( server_id, Task_id ) )
     params.deadline = Period * 2;
     params.budget = Execution * 2 +1;
     if ( rtems_cbs_set_parameters( server_id, &params ) )
@@ -114,22 +97,11 @@ rtems_task Task_Periodic(
     while(FOREVER) {
       now = rtems_clock_get_ticks_since_boot();
       if ( now >= start + Execution ) break;
-      if ( server_id != 0 ) {
-        if ( rtems_cbs_get_remaining_budget( server_id, &remaining_budget) )
-        if ( (remaining_budget + exec_time) > (Execution + 1) ) {
-          printf( "ERROR: REMAINING BUDGET AND EXECUTION TIME MISMATCH\n" );
-          rtems_test_exit( 0 );
     stop = rtems_clock_get_ticks_since_boot();
     printf( "P%" PRIdPTR "-F ticks:%d\n", argument, stop );
   /* delete period and SELF */
   status = rtems_rate_monotonic_delete( rmid );
   if ( status != RTEMS_SUCCESSFUL ) {
diff --git a/testsuites/sptests/spcbssched03/system.h b/testsuites/sptests/spcbssched03/system.h
index 1f864b5..94fdaed 100644
--- a/testsuites/sptests/spcbssched03/system.h
+++ b/testsuites/sptests/spcbssched03/system.h
@@ -72,4 +72,5 @@ TEST_EXTERN uint32_t  Phases[1 + NUM_TASKS];
 TEST_EXTERN uint32_t  Execution[1 + NUM_TASKS];
 TEST_EXTERN bool Violating_task[1 + NUM_PERIODIC_TASKS];
diff --git a/testsuites/sptests/spcbssched03/tasks_periodic.c b/testsuites/sptests/spcbssched03/tasks_periodic.c
index aa68228..7a3869f 100644
--- a/testsuites/sptests/spcbssched03/tasks_periodic.c
+++ b/testsuites/sptests/spcbssched03/tasks_periodic.c
@@ -19,19 +19,6 @@
 #include "system.h"
-/* forward declarations to avoid warnings */
-void overrun_handler_task_4(rtems_cbs_server_id server_id);
-  printk( "Signal overrun, fixing the task\n" );
-  Violating_task[ 4 ] = 0;
-  /* rtems_task_restart( RTEMS_SELF, 4 ); might be also possible*/
-  return;
 rtems_task Tasks_Periodic(
   rtems_task_argument argument
@@ -50,11 +37,11 @@ rtems_task Tasks_Periodic(
   params.budget = Execution[ argument ]+1;
   if ( argument == 4 ) {
-    if ( rtems_cbs_create_server( &params, &overrun_handler_task_4, &server_id ))
+    if ( rtems_cbs_create_server( &params, &server_id ))
   else {
   if ( rtems_cbs_attach_thread( server_id, Task_id[ argument ] ) )
@@ -152,8 +139,7 @@ rtems_task Tasks_Periodic(
     printf("rtems_rate_monotonic_delete failed with status of %d.\n",status);
-  if ( rtems_cbs_cleanup() )
-    printf( "ERROR: CBS CLEANUP\n" );
   fflush(stdout);
   TEST_END();
diff --git a/testsuites/sptests/spcbssched04/hard_tasks.c b/testsuites/sptests/spcbssched04/hard_tasks.c
index 0000000..a7f85b6
--- /dev/null
+++ b/testsuites/sptests/spcbssched04/hard_tasks.c
@@ -0,0 +1,74 @@
+/*  Tasks_Periodic
+ *  This routine serves as a test task for the CBS scheduler
+ *  implementation.
+ *  Input parameters:
+ *    argument - task argument
+ *  Output parameters:  NONE
+#ifdef HAVE_CONFIG_H
+#endif
+#include "system.h"
+rtems_task Hard_Task(
+  rtems_task_argument argument
+  rtems_id          rmid;
+  rtems_status_code status;
+  int start, stop, now;
+  status = rtems_rate_monotonic_create( argument, &rmid );
+  directive_failed( status, "rtems_rate_monotonic_create" );
+  printf( "Periodic task: Starting periodic behavior\n" );
+  //status = rtems_task_wake_after( 1 + Phase );
+  while ( FOREVER ) {
+    //printf("Rate mon initiating \n ");
+    if ( rtems_rate_monotonic_period(rmid, Hard_Period) == RTEMS_TIMEOUT )
+      printf( "P%" PRIdPTR " - Deadline miss\n", argument );
+    if( !sync_milestone[ argument - 1] )
+      status = rtems_barrier_wait(
+        barrier_id,
+        RTEMS_WAIT
+      directive_failed( status , "Barrier waiting failed ");
+      sync_milestone[ argument - 1] = true;
+    start = rtems_clock_get_ticks_since_boot();
+    printf( "P%" PRIdPTR "-S ticks:%d\n", argument, start );
+    if ( start >  3 * Hard_Period ) break; /* stop */
+    /* active computing */
+    while(FOREVER)
+      now = rtems_clock_get_ticks_since_boot();
+      if ( now >= ( start + Hard_Execution ) )
+        break;
+    stop = rtems_clock_get_ticks_since_boot();
+    printf( "P%" PRIdPTR "-F ticks:%d\n", argument, stop );
+  printf("Gonna eliminate rms \n");
+  status = rtems_rate_monotonic_delete( rmid );
+  directive_failed( status, " ERROR Deleting RM \n");
+  rtems_task_exit();
diff --git a/testsuites/sptests/spcbssched04/init.c b/testsuites/sptests/spcbssched04/init.c
index 0000000..58762f9
--- /dev/null
+++ b/testsuites/sptests/spcbssched04/init.c
@@ -0,0 +1,114 @@
+/*  Init
+ *  This routine is the initialization task for this test program.
+ *  It is a user initialization task and has the responsibility for creating
+ *  and starting the tasks that make up the test.  If the time of day
+ *  clock is required for the test, it should also be set to a known
+ *  value by this function.
+#endif
+#define CONFIGURE_INIT
+const char rtems_test_name[] = "SPCBSSCHED 4";
+rtems_task Init(
+  uint8_t index;
+  Hard_Period = 250;
+  Hard_Execution = 25;
+  Hard_Priority = 15;
+  Soft_Period = 400;
+  Soft_Execution = 25;
+  Soft_Priority = 30;
+  TEST_BEGIN();
+  status = rtems_barrier_create(
+    rtems_build_name('B','A','A',' '),
+    RTEMS_BARRIER_AUTOMATIC_RELEASE,
+    CONFIGURE_MAXIMUM_TASKS - 1,
+    &barrier_id
+  directive_failed( status , " ERROR Creating barrier \n");
+  for( index = 0 ; index < CONFIGURE_MAXIMUM_TASKS - 1 ; index++ )
+    char name = " " + ( index + 1);
+    rtems_task_priority priority;
+    ( index > MAXIMUM_HARD_TASKS - 1 )?(priority=Soft_Priority):(priority=Hard_Priority);
+    Task_name[ index ] = rtems_build_name( 'H', 'R', name, ' ');
+    status = rtems_task_create(
+      Task_name[ index ],
+      priority,
+      RTEMS_MINIMUM_STACK_SIZE * 5,
+      RTEMS_DEFAULT_MODES,
+      RTEMS_DEFAULT_ATTRIBUTES,
+      &Task_id[index]
+    directive_failed( status, "rtems_task_create loop" );
+  printf( "Init: Initializing the CBS\n" );
+  if ( rtems_cbs_initialize() )
+    printf( "ERROR: CBS INITIALIZATION FAILED\n" );
+  params.deadline = 300;
+  params.budget = 90;
+  printf( "Periodic task: Create server and Attach thread\n" );
+    printf("ERROR CREATE s1 \n");
+  for( index = 0; index < CONFIGURE_MAXIMUM_TASKS - 1; index++ )
+    rtems_task_entry entry_point;
+    ( index > MAXIMUM_HARD_TASKS - 1 )?(entry_point = Soft_Task):(entry_point = Hard_Task);
+    status = rtems_task_start( Task_id[ index ], entry_point, index + 1 );
+    directive_failed( status, "rtems_task_start error \n");
+  rtems_task_wake_after( 2000 );
+  rtems_cbs_detach_thread( Task_id[7]);
+  rtems_cbs_detach_thread( Task_id[8]);
+  if ( rtems_cbs_cleanup() )
+    printf( "ERROR: CBS CLEANUP\n" );
+  printf("Test Time in Nanoseconds as %"PRIu64" \n", rtems_clock_get_uptime_nanoseconds());
+  fflush(stdout);
+  TEST_END();
+  rtems_test_exit( 0 );
diff --git a/testsuites/sptests/spcbssched04/soft_tasks.c b/testsuites/sptests/spcbssched04/soft_tasks.c
index 0000000..300eb70
--- /dev/null
+++ b/testsuites/sptests/spcbssched04/soft_tasks.c
@@ -0,0 +1,85 @@
+/*  Tasks_Periodic
+ *  implementation.
+#endif
+rtems_task Soft_Task(
+  rtems_id          rmid;
+  directive_failed( status, "rtems_rate_monotonic_create \n");
+  if( argument > 6 )
+    status = rtems_cbs_attach_thread( server_id2, rtems_task_self() );
+    directive_failed( status, "rtems_attach_thread error \n");
+  else
+    status = rtems_cbs_attach_thread( server_id, rtems_task_self() );
+    if ( rtems_rate_monotonic_period(rmid, Soft_Period) == RTEMS_TIMEOUT )
+      printf( "P%" PRIdPTR " thread %d- Deadline miss time %"PRIu64" \n ", argument, rtems_task_self(), rtems_clock_get_uptime_nanoseconds() );
+        barrier_id,
+        RTEMS_WAIT
+    if( argument == 5 && ( start > 3 * Soft_Period ) )
+      break;
+    while(FOREVER)
+      if ( now >= ( start + Soft_Execution ) )
+        break;
+  rtems_cbs_detach_thread( Task_id[ 5 ] );
+  rtems_cbs_detach_thread( rtems_task_self() );
diff --git a/testsuites/sptests/spcbssched04/spcbssched04.doc b/testsuites/sptests/spcbssched04/spcbssched04.doc
index 0000000..147c350
--- /dev/null
+++ b/testsuites/sptests/spcbssched04/spcbssched04.doc
@@ -0,0 +1,20 @@
+#  COPYRIGHT (c) 2019.
+#  Joel Pinto.
+#  Research Centre in Real-Time & Embedded Computing Systems (CISTER).
+#  The license and distribution terms for this file may be
+#  found in the file LICENSE in this distribution or at
+#  http://www.rtems.org/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+test set name:  spcbssched04
+directives:
+concepts:
+  a.  Verifies CBS Scheduling behavior.
diff --git a/testsuites/sptests/spcbssched04/spcbssched04.scn b/testsuites/sptests/spcbssched04/spcbssched04.scn
index 0000000..28a8f0c
--- /dev/null
+++ b/testsuites/sptests/spcbssched04/spcbssched04.scn
@@ -0,0 +1,79 @@
+*** BEGIN OF TEST SPCBSSCHED 4 ***
+*** TEST VERSION: 5.0.0.c6cb95fd585d692f32c8c2253f8487abc84f9cd6-modified
+*** TEST STATE: EXPECTED-PASS
+*** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API
+*** TEST TOOLS: 7.4.0 20181206 (RTEMS 5, RSB 38241392a4f96dabf2d1aba51a43dcb623db4dfb, Newlib 1d35a003f)
+Init: Initializing the CBS
+Periodic task: Create server and Attach thread
+Periodic task: Starting periodic behavior
+P1-S ticks:2
+P1-F ticks:27
+P2-S ticks:27
+P2-F ticks:52
+P3-S ticks:52
+P3-F ticks:77
+P4-S ticks:77
+P4-F ticks:102
+P8-S ticks:102
+P8-F ticks:127
+P5-S ticks:127
+P5-F ticks:152
+P7-S ticks:152
+P7-F ticks:177
+P6-S ticks:177
+P6-F ticks:202
+P1-S ticks:251
+P1-F ticks:276
+P2-S ticks:276
+P2-F ticks:301
+P3-S ticks:301
+P3-F ticks:326
+P4-S ticks:326
+P4-F ticks:351
+P5-S ticks:402
+P5-F ticks:427
+P7-S ticks:427
+P7-F ticks:452
+P6-S ticks:452
+P8-S ticks:467
+P6-F ticks:482
+P8-F ticks:492
+P1-S ticks:501
+P1-F ticks:526
+P2-S ticks:526
+P2-F ticks:551
+P3-S ticks:551
+P3-F ticks:576
+P4-S ticks:576
+P4-F ticks:601
+P1-S ticks:751
+Gonna eliminate rms
+P2-S ticks:751
+P3-S ticks:752
+P4-S ticks:752
+P5-S ticks:802
+P5-F ticks:827
+P7-S ticks:827
+P7-F ticks:852
+P6-S ticks:852
+P6-F ticks:877
+P8-S ticks:877
+P8-F ticks:902
+P5-S ticks:1202
+P7-S ticks:1202
+P7-F ticks:1227
+P8-S ticks:1227
+P8-F ticks:1252
+P7-S ticks:1602
+P7-F ticks:1627
+P8-S ticks:1627
+P8-F ticks:1652
+Test Time in Nanoseconds as 40020016999
+*** END OF TEST SPCBSSCHED 4 ***
diff --git a/testsuites/sptests/spcbssched04/system.h b/testsuites/sptests/spcbssched04/system.h
index 0000000..22f4a49
--- /dev/null
+++ b/testsuites/sptests/spcbssched04/system.h
@@ -0,0 +1,80 @@
+/*  system.h
+ *  This include file contains information that is included in every
+ *  function in the test set.
+ *  COPYRIGHT (c) 1989-1999.
+ *  On-Line Applications Research Corporation (OAR).
+#include <tmacros.h>
+/* functions */
+rtems_task Init(
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_MICROSECONDS_PER_TICK 20000
+#define MAXIMUM_HARD_TASKS                    4
+#define MAXIMUM_SOFT_TASKS                    4
+#define CONFIGURE_MAXIMUM_TASKS               ( MAXIMUM_HARD_TASKS + MAXIMUM_SOFT_TASKS + 1 )
+#define CONFIGURE_MAXIMUM_PERIODS             8
+#define CONFIGURE_MAXIMUM_BARRIERS            1
+#define CONFIGURE_INIT_TASK_PRIORITY          10
+#define CONFIGURE_INIT_TASK_INITIAL_MODES     RTEMS_DEFAULT_MODES
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_EXTRA_TASK_STACKS         (20 * 4 * RTEMS_MINIMUM_STACK_SIZE)
+#define CONFIGURE_SCHEDULER_CBS
+#define CONFIGURE_CBS_MAXIMUM_SERVERS 2
+#define CONFIGURE_DISABLE_SMP_CONFIGURATION
+#include <rtems/rtems/clock.h>
+#include <rtems/cbs.h>
+#include <rtems/confdefs.h>
+/* global variables */
+TEST_EXTERN rtems_id   Task_id[ CONFIGURE_MAXIMUM_TASKS - 1 ], barrier_id;
+TEST_EXTERN rtems_name Task_name[ CONFIGURE_MAXIMUM_TASKS - 1 ];
+TEST_EXTERN  bool sync_milestone[ CONFIGURE_MAXIMUM_TASKS - 1];
+TEST_EXTERN rtems_task_priority Hard_Priority;
+TEST_EXTERN rtems_task_priority Soft_Priority;
+TEST_EXTERN time_t  Hard_Period;
+TEST_EXTERN time_t  Hard_Execution;
+TEST_EXTERN time_t  Soft_Period;
+TEST_EXTERN time_t  Soft_Execution;
+TEST_EXTERN rtems_cbs_server_id server_id, server_id2;
+TEST_EXTERN rtems_cbs_parameters params;
+/* end of include file */
diff --git a/testsuites/sptests/spcbssched05/init.c b/testsuites/sptests/spcbssched05/init.c
index 0000000..f8ef631
--- /dev/null
+++ b/testsuites/sptests/spcbssched05/init.c
@@ -0,0 +1,102 @@
+/*  Init
+#endif
+const char rtems_test_name[] = "SPCBSSCHED 5";
+rtems_task Init(
+  uint8_t index;
+  Soft_Period = 250;
+  Soft_Execution = 40;
+  TEST_BEGIN();
+    &barrier_id
+      Soft_Priority,
+      &Task_id[index]
+  params.deadline = 250;
+    status = rtems_task_start( Task_id[ index ], Soft_Task, index + 1 );
+  fflush(stdout);
+  TEST_END();
diff --git a/testsuites/sptests/spcbssched05/soft_tasks.c b/testsuites/sptests/spcbssched05/soft_tasks.c
index 0000000..a46eb47
--- /dev/null
+++ b/testsuites/sptests/spcbssched05/soft_tasks.c
@@ -0,0 +1,79 @@
+/*  Tasks_Periodic
+ *  implementation.
+#endif
+  rtems_id          rmid;
+  int start, stop, now, index;
+  printf("Soft period %"PRIu64" \n", Soft_Period );
+      printf("Waiting  for bar \n ");
+        barrier_id,
+        RTEMS_WAIT
+    if( argument == 1 && ( start > 7 * Soft_Period ) )
+      break;
+    while(FOREVER)
+        break;
+  for( index = 1; index < CONFIGURE_MAXIMUM_TASKS - 1; index++ ) {
+    rtems_cbs_detach_thread( index );
diff --git a/testsuites/sptests/spcbssched05/spcbssched05.doc b/testsuites/sptests/spcbssched05/spcbssched05.doc
index 0000000..931e76e
--- /dev/null
+++ b/testsuites/sptests/spcbssched05/spcbssched05.doc
@@ -0,0 +1,20 @@
+#  Joel Pinto.
+test set name:  spcbssched05
+directives:
+concepts:
diff --git a/testsuites/sptests/spcbssched05/spcbssched05.scn b/testsuites/sptests/spcbssched05/spcbssched05.scn
index 0000000..f296fb1
--- /dev/null
+++ b/testsuites/sptests/spcbssched05/spcbssched05.scn
@@ -0,0 +1,82 @@
+*** BEGIN OF TEST SPCBSSCHED 5 ***
+P3-S ticks:2
+P3-F ticks:42
+P2-S ticks:42
+P2-F ticks:82
+P1-S ticks:82
+P1-F ticks:122
+P4-S ticks:122
+P4-F ticks:162
+P3-S ticks:251
+P3-F ticks:291
+P2-S ticks:291
+P2-F ticks:331
+P1-S ticks:331
+P1-F ticks:371
+P4-S ticks:371
+P4-F ticks:411
+P3-S ticks:501
+P3-F ticks:541
+P2-S ticks:541
+P2-F ticks:581
+P1-S ticks:581
+P1-F ticks:621
+P4-S ticks:621
+P4-F ticks:661
+P3-S ticks:751
+P3-F ticks:791
+P2-S ticks:791
+P2-F ticks:831
+P1-S ticks:831
+P1-F ticks:871
+P4-S ticks:871
+P4-F ticks:911
+P3-S ticks:1001
+P3-F ticks:1041
+P2-S ticks:1041
+P2-F ticks:1081
+P1-S ticks:1081
+P1-F ticks:1121
+P4-S ticks:1121
+P4-F ticks:1161
+P3-S ticks:1251
+P3-F ticks:1291
+P2-S ticks:1291
+P2-F ticks:1331
+P1-S ticks:1331
+P1-F ticks:1371
+P4-S ticks:1371
+P4-F ticks:1411
+P3-S ticks:1501
+P3-F ticks:1541
+P2-S ticks:1541
+P2-F ticks:1581
+P1-S ticks:1581
+P1-F ticks:1621
+P4-S ticks:1621
+P4-F ticks:1661
+P3-S ticks:1751
+P3-F ticks:1791
+P2-S ticks:1791
+P2-F ticks:1831
+P1-S ticks:1831
+P4-S ticks:1831
+P4-F ticks:1871
+P3-S ticks:2001
+P3-F ticks:2041
+P2-S ticks:2041
+P2-F ticks:2081
+P4-S ticks:2081
+P4-F ticks:2121
+Test Time in Nanoseconds as 42420008999
+*** END OF TEST SPCBSSCHED 5 ***
diff --git a/testsuites/sptests/spcbssched05/system.h b/testsuites/sptests/spcbssched05/system.h
index 0000000..d482e7f
--- /dev/null
+++ b/testsuites/sptests/spcbssched05/system.h
@@ -0,0 +1,75 @@
+/*  system.h
+/* functions */
+rtems_task Init(
+#define CONFIGURE_MAXIMUM_TASKS               5
+#define CONFIGURE_MAXIMUM_PERIODS             4
+#define CONFIGURE_CBS_MAXIMUM_SERVERS 1
+TEST_EXTERN rtems_cbs_server_id server_id;
diff --git a/testsuites/sptests/spqreslib/init.c b/testsuites/sptests/spqreslib/init.c
index 33e638b..15b07f0 100644
--- a/testsuites/sptests/spqreslib/init.c
+++ b/testsuites/sptests/spqreslib/init.c
@@ -102,14 +102,7 @@ rtems_task Init(
   if ( qres_attach_thread( server_id, 0, 1234 ) !=
        QOS_E_INVALID_PARAM )
-  if ( qres_attach_thread( server_id, 0, RTEMS_SELF ) )
-  if ( qres_attach_thread( server_id, 0, RTEMS_SELF ) !=
-       QOS_E_FULL )
-  if ( qres_attach_thread( server_id, 0, Task_id ) !=
-       QOS_E_FULL )
   if ( qres_destroy_server( server_id ) )
@@ -119,16 +112,16 @@ rtems_task Init(
   if ( qres_detach_thread( -5, 0, RTEMS_SELF ) !=
-    printf( "ERROR: DETACH THREAD PASSED UNEXPECTEDLY\n" );
+    printf( "ERROR: DETACH THREAD PASSED UNEXPECTEDLY 1 \n" );
   if ( qres_detach_thread( 5, 0, RTEMS_SELF ) !=
+    printf( "ERROR: DETACH THREAD PASSED UNEXPECTEDLY 2 \n" );
   if ( qres_detach_thread( server_id2, 0, 1234 ) !=
-    printf( "ERROR: DETACH THREAD PASSED UNEXPECTEDLY \n" );
+    printf( "ERROR: DETACH THREAD PASSED UNEXPECTEDLY 3  \n" );
   if ( qres_detach_thread( server_id, 0, RTEMS_SELF ) !=
        QOS_E_NOSERVER )
-    printf( "ERROR: DETACH THREAD PASSED UNEXPECTEDLY4\n" );
+    printf( "ERROR: DETACH THREAD PASSED UNEXPECTEDLY 4\n" );
   qres_destroy_server( server_id2 );
   /* Error checks for Set params and Get params */
@@ -190,18 +183,6 @@ rtems_task Init(
        QOS_E_NOSERVER )
-  if ( qres_get_exec_time( -5, &exec_time, &abs_time ) !=
-       QOS_E_INVALID_PARAM )
-  if ( qres_get_exec_time( 5, &exec_time, &abs_time ) !=
-  if ( qres_get_exec_time( server_id, &exec_time, &abs_time ) !=
-       QOS_E_NOSERVER )
   /* Restart QRES library */
   printf( "Init: Cleaning up QRES\n" );
   if ( qres_cleanup() )
diff --git a/testsuites/sptests/spqreslib/task_periodic.c b/testsuites/sptests/spqreslib/task_periodic.c
index b219514..5e5be59 100644
--- a/testsuites/sptests/spqreslib/task_periodic.c
+++ b/testsuites/sptests/spqreslib/task_periodic.c
@@ -22,7 +22,7 @@ rtems_task Task_Periodic(
   rtems_id          rmid;
-  time_t approved_budget, exec_time, abs_time, current_budget;
+  time_t approved_budget, current_budget;
@@ -49,25 +49,13 @@ rtems_task Task_Periodic(
        params.Q != tparams.Q )
-  if ( qres_detach_thread( server_id, 0, Task_id ) )
-  if ( qres_destroy_server( server_id ) )
-  if ( qres_create_server( &params, &server_id ) )
   printf( "Periodic task: Current budget and Execution time\n" );
   if ( qres_get_curr_budget( server_id, &current_budget ) )
   if ( current_budget != params.Q )
-  if ( qres_get_exec_time( server_id, &exec_time, &abs_time ) )
-  if ( qres_attach_thread( server_id, 0, Task_id ) )
   params.P = Period * 2;
   params.Q = Execution * 2 +1;
   if ( qres_set_params( server_id, &params ) )
@@ -107,28 +95,16 @@ rtems_task Task_Periodic(
     while(FOREVER) {
-      if ( qres_get_curr_budget( server_id, &current_budget) )
-        printf( "ERROR: GET CURRENT BUDGET FAILED\n" );
-      if ( (current_budget + exec_time) > (Execution + 1) ) {
-        printf( "ERROR: CURRENT BUDGET AND EXECUTION TIME MISMATCH\n" );
     printf("rtems_rate_monotonic_delete failed with status of %d.\n", status);
-  if ( qres_cleanup() )
-    printf( "ERROR: QRES CLEANUP\n" );
   fflush(stdout);
   TEST_END();
2.7.4
