AW: SMP for pc686 BSP
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Fri May 17 10:38:18 UTC 2019
> -----Ursprüngliche Nachricht-----
> Von: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Gesendet: Freitag, 17. Mai 2019 06:57
> An: Sommer, Jan; devel at rtems.org
> Betreff: Re: SMP for pc686 BSP
> Hello Jan,
> there is also an amd64 BSP:
> https://docs.rtems.org/branches/master/user/bsps/bsps-
> x86_64.html#amd64
> I think it was intended for further development and all the i386 is a
> variants are legacy BSPs?
Thanks for the pointer. It seems to be in an early stage, though and only considering 64bit, so far.
Atm I don't feel familiar enough with the build system and project layout to integrate 32bit support from scratch.
However, fixing the pc386-BSP I learned again quite a lot. If I find some time, I might look into 64bit ASM.
