[PATCH] CONTRIBUTING: mention pyelftools dependency
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun May 19 11:15:50 UTC 2019
CONTRIBUTING.md | 3 +++
1 file changed, 3 insertions(+)
diff --git a/CONTRIBUTING.md b/CONTRIBUTING.md
index 78be5ca6..f2e5da21 100644
--- a/CONTRIBUTING.md
+++ b/CONTRIBUTING.md
@@ -181,6 +181,9 @@ original FreeBSD code.
`python ./userspace-header-gen.py build/arm-rtems4.12-xilinx_zynq_a9_qemu/freebsd/sbin/pfctl/*.o -p pfctl`
Replace the name (given via -p option) by the name of the userspace tool. It
has to match the name that is used in the RTEMS linker set further below.
+ `Note:` the script `userspace-header-gen.py` depends on pyelftools. It can be
+ installed using pip:
+ `pip install --user pyelftools`
* If you regenerated files that have already been generated, you may have to
remove RTEMS-specific names from the namespace. The defaults (linker set names
and rtems_bsd_program_.*) should already be filtered.
2.20.1
