[PATCH] psxhdrs: Add POSIX API Signature Compliance Tests for sys/wait.h
Jacob Shin
jacobshin313 at gmail.com
Mon May 20 02:28:10 UTC 2019
testsuites/psxtests/Makefile.am | 5 +-
testsuites/psxtests/psxhdrs/sys/wait/wait.c | 49 +++++++++++++++++
testsuites/psxtests/psxhdrs/sys/wait/waitid.c | 52 +++++++++++++++++++
.../psxtests/psxhdrs/sys/wait/waitpid.c | 52 +++++++++++++++++++
4 files changed, 157 insertions(+), 1 deletion(-)
create mode 100755 testsuites/psxtests/psxhdrs/sys/wait/wait.c
create mode 100755 testsuites/psxtests/psxhdrs/sys/wait/waitid.c
create mode 100755 testsuites/psxtests/psxhdrs/sys/wait/waitpid.c
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 1e354c0df7..d18c438f72 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1837,12 +1837,15 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
psxhdrs/termios/tcgetattr.c \
psxhdrs/termios/tcgetsid.c \
psxhdrs/termios/tcsendbreak.c \
- psxhdrs/termios/tcsetattr.c
+ psxhdrs/termios/tcsetattr.c \
+ psxhdrs/sys/wait/wait.c \
+ psxhdrs/sys/wait/waitpid.c
## Not supported by RTEMS, but POSIX API Compliance tests exist.
## lib_a_SOURCES += psxhdrs/ulimit/ulimit.c
## lib_a_SOURCES += psxhdrs/monetary/strfmon.c
## lib_a_SOURCES += psxhdrs/monetary/strfmon_l.c
+## lib_a_SOURCES += psxhdrs/sys/wait/waitid.c
## Specific issues that tickets are tracking
## lib_a_SOURCES += psxhdrs/dirent/dirfd.c See ticket #3371
diff --git a/testsuites/psxtests/psxhdrs/sys/wait/wait.c b/testsuites/psxtests/psxhdrs/sys/wait/wait.c
new file mode 100755
index 0000000000..8bf951ed75
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/sys/wait/wait.c
@@ -0,0 +1,49 @@
+ * @file
+ * @brief wait() API Conformance Test
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019 Jacob Shin
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <sys/wait.h>
+int test( void );
+int test( void )
+ pid_t result;
+ int stat_loc = 0;
+ result = wait(&stat_loc);
+ return result != (pid_t)-1;
diff --git a/testsuites/psxtests/psxhdrs/sys/wait/waitid.c b/testsuites/psxtests/psxhdrs/sys/wait/waitid.c
index 0000000000..9fa8672ad2
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/sys/wait/waitid.c
@@ -0,0 +1,52 @@
+ * @file
+ * @brief waitid() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ int result;
+ idtype_t idtype = P_PID;
+ id_t id = (id_t)-1;
+ siginfo_t infop;
+ int options = WSTOPPED;
+ result = waitid(idtype, id, &infop, options);
+ return (result != -1);
diff --git a/testsuites/psxtests/psxhdrs/sys/wait/waitpid.c b/testsuites/psxtests/psxhdrs/sys/wait/waitpid.c
index 0000000000..991de0796c
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/sys/wait/waitpid.c
@@ -0,0 +1,52 @@
+ * @file
+ * @brief waitpid() API Conformance Test
+ * are met:
+#endif
+int test( void );
+int test( void )
+ pid_t result;
+ pid_t pid = (pid_t)-1;
+ int stat_loc = 0;
+ int options = WUNTRACED;
+ result = waitpid(pid, &stat_loc, options);
2.17.1
