[PATCH 02/18] smpmulticast01: Use T_TEST_CASE()
Mon May 20 07:33:28 UTC 2019
 testsuites/smptests/smpmulticast01/init.c | 49 +++++++++++++++++--------------
 1 file changed, 27 insertions(+), 22 deletions(-)
diff --git a/testsuites/smptests/smpmulticast01/init.c b/testsuites/smptests/smpmulticast01/init.c
index f8e74e22cc..a2180bdf14 100644
--- a/testsuites/smptests/smpmulticast01/init.c
+++ b/testsuites/smptests/smpmulticast01/init.c
@@ -258,35 +258,40 @@ static void test_wrong_cpu_state_to_perform_jobs(void)
   rtems_fatal(RTEMS_FATAL_SOURCE_APPLICATION, 0);
-static void Init(rtems_task_argument arg)
+T_TEST_CASE(UnicastDuringMultitasking)
-  test_context *ctx;
-  ctx = &test_instance;
+  test_unicast(&test_instance, _SMP_Multicast_action);
-  T_case_begin("UnicastDuringMultitasking", NULL);
-  test_unicast(ctx, _SMP_Multicast_action);
-  T_case_end();
+T_TEST_CASE(UnicastDuringMultitaskingIRQDisabled)
+  test_unicast(&test_instance, multicast_action_irq_disabled);
-  T_case_begin("UnicastDuringMultitaskingIRQDisabled", NULL);
-  test_unicast(ctx, multicast_action_irq_disabled);
-  T_case_end();
+T_TEST_CASE(UnicastDuringMultitaskingDispatchDisabled)
+  test_unicast(&test_instance, multicast_action_dispatch_disabled);
-  T_case_begin("UnicastDuringMultitaskingDispatchDisabled", NULL);
-  test_unicast(ctx, multicast_action_dispatch_disabled);
-  T_case_end();
+T_TEST_CASE(BroadcastDuringMultitasking)
+  test_broadcast(&test_instance, _SMP_Multicast_action);
-  T_case_begin("BroadcastDuringMultitasking", NULL);
-  test_broadcast(ctx, _SMP_Multicast_action);
-  T_case_end();
+T_TEST_CASE(BroadcastDuringMultitaskingIRQDisabled)
+  test_broadcast(&test_instance, multicast_action_irq_disabled);
-  T_case_begin("BroadcastDuringMultitaskingIRQDisabled", NULL);
-  test_broadcast(ctx, multicast_action_irq_disabled);
-  T_case_end();
+T_TEST_CASE(BroadcastDuringMultitaskingDispatchDisabled)
+  test_broadcast(&test_instance, multicast_action_dispatch_disabled);
-  T_case_begin("BroadcastDuringMultitaskingDispatchDisabled", NULL);
-  test_broadcast(ctx, multicast_action_dispatch_disabled);
-  T_case_end();
+static void Init(rtems_task_argument arg)
+  T_register();
+  T_run_all();
   if (rtems_scheduler_get_processor_maximum() > 1) {
     test_wrong_cpu_state_to_perform_jobs();
2.16.4
