[PATCH 00/18] Rework _SMP_Multicast_action()
Sebastian Huber
Mon May 20 07:33:26 UTC 2019
The goal of this patch set is to generalize the work done by
_SMP_Multicast_action() so that it can be used to replace the
SMP_MESSAGE_CLOCK_TICK and SMP_MESSAGE_TEST special cases.
Sebastian Huber (18):
score: Use dedicated lock for per-CPU jobs
smpmulticast01: Use T_TEST_CASE()
smptests: Move SMP broadcast action test case
score: Add _SMP_Broadcast_action()
score: Add _SMP_Othercast_action()
score: Simplify _SMP_Multicast_action()
score: Remove SMP_MESSAGE_CLOCK_TICK
score: Move per-processor job data structures
score: Add _Per_CPU_Add_job()
score: Modify _Per_CPU_Perform_jobs()
smpipi01: Use per-CPU jobs for pending IPI test
smpipi01: Ensure IPI works on all processors
smpipi01: Use per-CPU jobs for IPI flood test
score: Remove unused SMP_MESSAGE_TEST
score: Add _SMP_Synchronize()
score: Remove superfluous include
score: Add _Per_CPU_Wait_for_job()
score: Add _SMP_Unicast_action()
bsps/arm/shared/clock/clock-a9mpcore.c | 12 +-
bsps/arm/shared/clock/clock-generic-timer.c | 12 +-
bsps/i386/pc386/clock/ckinit.c | 10 +-
bsps/i386/pc386/start/smp-imps.c | 11 +-
bsps/shared/cache/cacheimpl.h | 25 +-
cpukit/Makefile.am | 1 +
cpukit/include/rtems/score/percpu.h | 88 +++++-
cpukit/include/rtems/score/smpimpl.h | 107 ++++---
cpukit/score/src/smp.c | 2 -
cpukit/score/src/smpmulticastaction.c | 256 +++++++---------
cpukit/score/src/smpunicastaction.c | 51 ++++
testsuites/smptests/smpcache01/init.c | 41 +--
testsuites/smptests/smpipi01/init.c | 121 ++++++--
testsuites/smptests/smpmulticast01/init.c | 337 ++++++++++++++++++---
.../smptests/smpmulticast01/smpmulticast01.scn | 99 +++---
15 files changed, 807 insertions(+), 366 deletions(-)
create mode 100644 cpukit/score/src/smpunicastaction.c
2.16.4
