[PATCH] sb: Add sb-get-sources to download all references source files.
chrisj at rtems.org
chrisj at rtems.org
Mon May 20 22:57:59 UTC 2019
- Downloads all files in a single directory
- Iterates over all support hosts to get any host dependent source
no matter which host you run the command on.
Closes #3532
source-builder/sb-get-sources | 27 ++
source-builder/sb/cmd-get-sources.py | 29 ++
source-builder/sb/getsources.py | 615 +++++++++++++++++++++++++++
3 files changed, 671 insertions(+)
create mode 100755 source-builder/sb-get-sources
create mode 100755 source-builder/sb/cmd-get-sources.py
create mode 100644 source-builder/sb/getsources.py
diff --git a/source-builder/sb-get-sources b/source-builder/sb-get-sources
new file mode 100755
index 0000000..d9f03b7
--- /dev/null
+++ b/source-builder/sb-get-sources
@@ -0,0 +1,27 @@
+#! /bin/sh
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2019 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Permission to use, copy, modify, and/or distribute this software for any
+# purpose with or without fee is hereby granted, provided that the above
+# copyright notice and this permission notice appear in all copies.
+# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
+# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
+# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
+# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
+# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
+# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
+# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+set -e
+base=$(dirname $0)
+PYTHON_CMD=${base}/sb/cmd-get-sources.py
+if test -f ${base}/sb/python-wrapper.sh; then
+ . ${base}/sb/python-wrapper.sh
+fi
+echo "error: python wrapper not found"
diff --git a/source-builder/sb/cmd-get-sources.py b/source-builder/sb/cmd-get-sources.py
index 0000000..480e81d
--- /dev/null
+++ b/source-builder/sb/cmd-get-sources.py
@@ -0,0 +1,29 @@
+# Copyright 2010-2019 Chris Johns (chrisj at rtems.org)
+from __future__ import print_function
+import sys, os
+try:
+ import getsources
+ getsources.run()
+except ImportError:
+ print("Incorrect Source Builder installation", file = sys.stderr)
+ sys.exit(1)
diff --git a/source-builder/sb/getsources.py b/source-builder/sb/getsources.py
new file mode 100644
index 0000000..4fc9395
--- /dev/null
+++ b/source-builder/sb/getsources.py
@@ -0,0 +1,615 @@
+# This code builds a package compiler tool suite given a tool set. A tool
+# set lists the various tools. These are specific tool configurations.
+import argparse
+import copy
+import datetime
+import os
+import sys
+try:
+ import build
+ import check
+ import error
+ import git
+ import log
+ import macros
+ import path
+ import sources
+ import version
+except KeyboardInterrupt:
+ print('abort: user terminated', file = sys.stderr)
+ sys.exit(1)
+except:
+ print('error: unknown application load error', file = sys.stderr)
+ sys.exit(1)
+# Define host profiles so it can simulated on another host.
+host_profiles = {
+ 'darwin': { '_os': ('none', 'none', 'darwin'),
+ '_host': ('triplet', 'required', 'x86_64-apple-darwin18.5.0'),
+ '_host_vendor': ('none', 'none', 'apple'),
+ '_host_os': ('none', 'none', 'darwin'),
+ '_host_os_version': ('none', 'none', '18.5.0'),
+ '_host_cpu': ('none', 'none', 'x86_64'),
+ '_host_alias': ('none', 'none', '%{nil}'),
+ '_host_arch': ('none', 'none', 'x86_64'),
+ '_usr': ('dir', 'optional', '/usr/local'),
+ '_var': ('dir', 'optional', '/usr/local/var') },
+ 'freebsd': { '_os': ('none', 'none', 'freebsd'),
+ '_host': ('triplet', 'required', 'x86_64-freebsd12.0-RELEASE-p3'),
+ '_host_vendor': ('none', 'none', 'pc'),
+ '_host_os': ('none', 'none', 'freebsd'),
+ '_host_os_version': ('none', 'none', '12.0-RELEASE-p3'),
+ 'linux': { '_os': ('none', 'none', 'linux'),
+ '_host': ('triplet', 'required', 'x86_64-linux-gnu'),
+ '_host_vendor': ('none', 'none', 'gnu'),
+ '_host_os': ('none', 'none', 'linux'),
+ '_host_os_version': ('none', 'none', '4.18.0-16'),
+ 'netbsd': { '_os': ('none', 'none', 'netbsd'),
+ '_host': ('triplet', 'required', 'x86_64-netbsd8.0'),
+ '_host_os': ('none', 'none', 'netbsd'),
+ '_host_os_version': ('none', 'none', '8.0'),
+ 'solaris': { '_os': ('none', 'none', 'solaris'),
+ '_host': ('triplet', 'required', 'x86_64-pc-solaris2'),
+ '_host_os': ('none', 'none', 'solaris'),
+ '_host_os_version': ('none', 'none', '2'),
+ 'win32': { '_os': ('none', 'none', 'win32'),
+ '_windows_os': ('none', 'none', 'mingw32'),
+ '_host': ('triplet', 'required', 'x86_64-w64-mingw32'),
+ '_host_os': ('none', 'none', 'win32'),
+ '_host_os_version': ('none', 'none', '10'),
+ 'cygwin': { '_os': ('none', 'none', 'win32'),
+ '_windows_os': ('none', 'none', 'cygwin'),
+ '_host': ('triplet', 'required', 'x86_64-w64-cygwin'),
+ '_host_vendor': ('none', 'none', 'microsoft'),
+class log_capture(object):
+ def __init__(self):
+ self.log = []
+ log.capture = self.capture
+ def __str__(self):
+ return os.linesep.join(self.log)
+ def capture(self, text):
+ self.log += [l for l in text.replace(chr(13), '').splitlines()]
+ def get(self):
+ return self.log
+ def clear(self):
+ self.log = []
+# A skinny options command line class to get the configs to load.
+class options(object):
+ def __init__(self, argv, argopts, defaults):
+ command_path = path.dirname(path.abspath(argv[1]))
+ if len(command_path) == 0:
+ command_path = '.'
+ self.command_path = command_path
+ self.command_name = path.basename(argv[0])
+ extras = ['--dry-run',
+ '--with-download',
+ '--quiet',
+ '--without-log',
+ '--without-error-report',
+ '--without-release-url']
+ self.argv = argv
+ self.args = argv[1:] + extras
+ self.defaults = macros.macros(name = defaults,
+ sbdir = command_path)
+ self.opts = { 'params' : extras }
+ self.sb_git()
+ if argopts.download_dir is not None:
+ self.defaults['_sourcedir'] = ('dir', 'optional', path.abspath(argopts.download_dir))
+ self.defaults['_patchdir'] = ('dir', 'optional', path.abspath(argopts.download_dir))
+ def parse_args(self, arg, error = True, extra = True):
+ for a in range(0, len(self.args)):
+ if self.args[a].startswith(arg):
+ lhs = None
+ rhs = None
+ if '=' in self.args[a]:
+ eqs = self.args[a].split('=')
+ lhs = eqs[0]
+ if len(eqs) > 2:
+ rhs = '='.join(eqs[1:])
+ else:
+ rhs = eqs[1]
+ elif extra:
+ lhs = self.args[a]
+ a += 1
+ if a < len(self.args):
+ rhs = self.args[a]
+ return [lhs, rhs]
+ a += 1
+ return None
+ def sb_git(self):
+ repo = git.repo(self.defaults.expand('%{_sbdir}'), self)
+ if repo.valid():
+ repo_valid = '1'
+ repo_head = repo.head()
+ repo_clean = not repo.dirty()
+ repo_remotes = '%{nil}'
+ remotes = repo.remotes()
+ if 'origin' in remotes:
+ repo_remotes = '%s/origin' % (remotes['origin']['url'])
+ repo_id = repo_head
+ if not repo_clean:
+ repo_id += '-modified'
+ repo_mail = repo.email()
+ else:
+ repo_valid = '0'
+ repo_head = '%{nil}'
+ repo_clean = '%{nil}'
+ repo_id = 'no-repo'
+ repo_mail = None
+ self.defaults['_sbgit_valid'] = repo_valid
+ self.defaults['_sbgit_head'] = repo_head
+ self.defaults['_sbgit_clean'] = str(repo_clean)
+ self.defaults['_sbgit_remotes'] = str(repo_remotes)
+ self.defaults['_sbgit_id'] = repo_id
+ if repo_mail is not None:
+ self.defaults['_sbgit_mail'] = repo_mail
+ def get_arg(self, arg):
+ if self.optargs is None or arg not in self.optargs:
+ return None
+ return self.parse_args(arg)
+ def with_arg(self, label, default = 'not-found'):
+ # the default if there is no option for without.
+ result = default
+ for pre in ['with', 'without']:
+ arg_str = '--%s-%s' % (pre, label)
+ arg_label = '%s_%s' % (pre, label)
+ arg = self.parse_args(arg_str, error = False, extra = False)
+ if arg is not None:
+ if arg[1] is None:
+ result = 'yes'
+ else:
+ result = arg[1]
+ break
+ return [arg_label, result]
+ def dry_run(self):
+ return True
+ def keep_going(self):
+ return False
+ def quiet(self):
+ return True
+ def no_clean(self):
+ return True
+ def always_clean(self):
+ return False
+ def no_install(self):
+ return True
+ def download_disabled(self):
+ return False
+ def disable_install(self):
+ return True
+ def urls(self):
+ return None
+ def info(self):
+ s = ' Command Line: %s%s' % (' '.join(self.argv), os.linesep)
+ s += ' Python: %s' % (sys.version.replace('\n', ''))
+ return s
+class buildset:
+ """Build a set builds a set of packages."""
+ def __init__(self, bset, _configs, opts, macros = None):
+ log.trace('_bset: %s: init' % (bset))
+ self.configs = _configs
+ self.opts = opts
+ if macros is None:
+ self.macros = copy.copy(opts.defaults)
+ else:
+ self.macros = copy.copy(macros)
+ log.trace('_bset: %s: macro defaults' % (bset))
+ log.trace(str(self.macros))
+ self.bset = bset
+ _target = self.macros.expand('%{_target}')
+ if len(_target):
+ pkg_prefix = _target
+ else:
+ pkg_prefix = self.macros.expand('%{_host}')
+ self.bset_pkg = '%s-%s-set' % (pkg_prefix, self.bset)
+ self.build_failure = None
+ def build_package(self, _config, _build):
+ if not _build.disabled():
+ _build.make()
+ def parse(self, bset):
+ # Ouch, this is a copy of the setbuilder.py code.
+ def _clean(line):
+ line = line[0:-1]
+ b = line.find('#')
+ if b >= 0:
+ line = line[1:b]
+ return line.strip()
+ bsetname = bset
+ if not path.exists(bsetname):
+ for cp in self.macros.expand('%{_configdir}').split(':'):
+ configdir = path.abspath(cp)
+ bsetname = path.join(configdir, bset)
+ if path.exists(bsetname):
+ break
+ bsetname = None
+ if bsetname is None:
+ raise error.general('no build set file found: %s' % (bset))
+ try:
+ log.trace('_bset: %s: open: %s' % (self.bset, bsetname))
+ bset = open(path.host(bsetname), 'r')
+ except IOError as err:
+ raise error.general('error opening bset file: %s' % (bsetname))
+ configs = []
+ try:
+ lc = 0
+ for l in bset:
+ lc += 1
+ l = _clean(l)
+ if len(l) == 0:
+ continue
+ log.trace('_bset: %s: %03d: %s' % (self.bset, lc, l))
+ ls = l.split()
+ if ls[0][-1] == ':' and ls[0][:-1] == 'package':
+ self.bset_pkg = ls[1].strip()
+ self.macros['package'] = self.bset_pkg
+ elif ls[0][0] == '%':
+ def err(msg):
+ raise error.general('%s:%d: %s' % (self.bset, lc, msg))
+ if ls[0] == '%define':
+ if len(ls) > 2:
+ self.macros.define(ls[1].strip(),
+ ' '.join([f.strip() for f in ls[2:]]))
+ else:
+ self.macros.define(ls[1].strip())
+ elif ls[0] == '%undefine':
+ if len(ls) > 2:
+ raise error.general('%s:%d: %undefine requires just the name' % \
+ (self.bset, lc))
+ self.macros.undefine(ls[1].strip())
+ elif ls[0] == '%include':
+ configs += self.parse(ls[1].strip())
+ elif ls[0] in ['%patch', '%source']:
+ sources.process(ls[0][1:], ls[1:], self.macros, err)
+ elif ls[0] == '%hash':
+ sources.hash(ls[1:], self.macros, err)
+ else:
+ l = l.strip()
+ c = build.find_config(l, self.configs)
+ if c is None:
+ raise error.general('%s:%d: cannot find file: %s' % (self.bset, lc, l))
+ configs += [c]
+ except:
+ bset.close()
+ raise
+ bset.close()
+ return configs
+ def load(self):
+ # If the build set file ends with .cfg the user has passed to the
+ # buildset builder a configuration so we just return it.
+ if self.bset.endswith('.cfg'):
+ configs = [self.bset]
+ else:
+ exbset = self.macros.expand(self.bset)
+ self.macros['_bset'] = exbset
+ self.macros['_bset_tmp'] = build.short_name(exbset)
+ root, ext = path.splitext(exbset)
+ if exbset.endswith('.bset'):
+ bset = exbset
+ else:
+ bset = '%s.bset' % (exbset)
+ configs = self.parse(bset)
+ return configs
+ def set_host_details(self, host, opts, macros):
+ if host not in host_profiles:
+ raise error.general('invalid host: ' + host)
+ for m in host_profiles[host]:
+ opts.defaults[m] = host_profiles[host][m]
+ macros[m] = host_profiles[host][m]
+ macros_to_copy = [('%{_build}', '%{_host}'),
+ ('%{_build_alias}', '%{_host_alias}'),
+ ('%{_build_arch}', '%{_host_arch}'),
+ ('%{_build_cpu}', '%{_host_cpu}'),
+ ('%{_build_os}', '%{_host_os}'),
+ ('%{_build_vendor}', '%{_host_vendor}')]
+ for m in macros_to_copy:
+ opts.defaults[m[0]] = opts.defaults[m[1]]
+ macros[m[0]] = macros[m[1]]
+ # Look for a valid cc and cxx.
+ for cc in ['/usr/bin/cc', '/usr/bin/clang', '/usr/bin/gcc']:
+ if check.check_exe(cc, cc):
+ opts.defaults['__cc'] = cc
+ macros['__cc'] = cc
+ break
+ if not macros.defined('__cc'):
+ raise error.general('no valid cc found')
+ for cxx in ['/usr/bin/c++', '/usr/bin/clang++', '/usr/bin/g++']:
+ if check.check_exe(cxx, cxx):
+ opts.defaults['__cxx'] = cxx
+ macros['__cxx'] = cxx
+ if not macros.defined('__cxx'):
+ raise error.general('no valid c++ found')
+ def build(self, host, nesting_count = 0):
+ build_error = False
+ nesting_count += 1
+ log.trace('_bset: %s for %s: make' % (self.bset, host))
+ log.notice('Build Set: %s for %s' % (self.bset, host))
+ mail_subject = '%s on %s' % (self.bset,
+ self.macros.expand('%{_host}'))
+ current_path = os.environ['PATH']
+ start = datetime.datetime.now()
+ have_errors = False
+ try:
+ configs = self.load()
+ log.trace('_bset: %s: configs: %s' % (self.bset, ','.join(configs)))
+ sizes_valid = False
+ builds = []
+ for s in range(0, len(configs)):
+ b = None
+ try:
+ # Each section of the build set gets a separate set of
+ # macros so we do not contaminate one configuration with
+ # another.
+ opts = copy.copy(self.opts)
+ macros = copy.copy(self.macros)
+ self.set_host_details(host, opts, macros)
+ if configs[s].endswith('.bset'):
+ log.trace('_bset: == %2d %s' % (nesting_count + 1, '=' * 75))
+ bs = buildset(configs[s], self.configs, opts, macros)
+ bs.build(host, nesting_count)
+ del bs
+ elif configs[s].endswith('.cfg'):
+ log.trace('_bset: -- %2d %s' % (nesting_count + 1, '-' * 75))
+ try:
+ b = build.build(configs[s],
+ False,
+ opts,
+ macros)
+ except:
+ build_error = True
+ raise
+ self.build_package(configs[s], b)
+ builds += [b]
+ # Dump post build macros.
+ log.trace('_bset: macros post-build')
+ log.trace(str(macros))
+ else:
+ raise error.general('invalid config type: %s' % (configs[s]))
+ except error.general as gerr:
+ have_errors = True
+ if b is not None:
+ if self.build_failure is None:
+ self.build_failure = b.name()
+ raise
+ # Clear out the builds ...
+ for b in builds:
+ del b
+ if not build_error:
+ log.stderr(str(gerr))
+ raise
+ except KeyboardInterrupt:
+ raise
+ except:
+ self.build_failure = 'RSB general failure'
+ raise
+ finally:
+ end = datetime.datetime.now()
+ os.environ['PATH'] = current_path
+ build_time = str(end - start)
+ log.notice('Build Set: Time %s' % (build_time))
+def list_bset_files(opts, configs):
+ ext = '.bset'
+ for p in configs['paths']:
+ print('Examining: %s' % (os.path.relpath(p)))
+ for c in configs['files']:
+ if c.endswith(ext):
+ print(' %s' % (c[:c.rfind('.')]))
+def load_log(logfile):
+ log.default = log.log(streams = [logfile])
+def log_default():
+ return 'rsb-log-getsource-%s.txt' % (datetime.datetime.now().strftime('%Y%m%d-%H%M%S'))
+def load_options(argv, argopts, defaults = '%{_sbdir}/defaults.mc'):
+ opts = options(argv, argopts, defaults)
+ opts.defaults['rtems_version'] = argopts.rtems_version
+ return opts
+def run(args = sys.argv):
+ ec = 0
+ get_sources_error = True
+ try:
+ # The RSB options support cannot be used because it loads the defaults
+ # for the host which we cannot do here.
+ description = 'RTEMS Get Sources downloads all the source a build set '
+ description += 'references for all hosts.'
+ argsp = argparse.ArgumentParser(prog = 'rtems-get-sources',
+ description = description)
+ argsp.add_argument('--rtems-version', help = 'Set the RTEMS version.',
+ type = str,
+ default = version.version())
+ argsp.add_argument('--list-hosts', help = 'List the hosts.',
+ action = 'store_true')
+ argsp.add_argument('--list-bsets', help = 'List the hosts.',
+ argsp.add_argument('--download-dir', help = 'Download directory.',
+ type = str)
+ argsp.add_argument('--clean', help = 'Clean the download directory.',
+ argsp.add_argument('--tar', help = 'Create a tarball of all the source.',
+ argsp.add_argument('--log', help = 'Log file.',
+ type = str,
+ default = log_default())
+ argsp.add_argument('--trace', help = 'Enable trace logging for debugging.',
+ argsp.add_argument('bsets', nargs='*', help = 'Build sets.')
+ argopts = argsp.parse_args(args[2:])
+ load_log(argopts.log)
+ log.notice('RTEMS Source Builder - Get Sources, %s' % (version.str()))
+ log.tracing = argopts.trace
+ opts = load_options(args, argopts)
+ configs = build.get_configs(opts)
+ if argopts.list_bsets:
+ list_bset_files(opts, configs)
+ else:
+ if argopts.clean:
+ if argopts.download_dir is None:
+ raise error.general('cleaning of the default download directories is not supported')
+ if path.exists(argopts.download_dir):
+ log.notice('Cleaning source directory: %s' % (argopts.download_dir))
+ path.removeall(argopts.download_dir)
+ if len(argopts.bsets) == 0:
+ raise error.general('no build sets provided on the command line')
+ for bset in argopts.bsets:
+ b = buildset(bset, configs, opts)
+ get_sources_error = False
+ for host in host_profiles:
+ b.build(host)
+ b = None
+ if get_sources_error:
+ log.stderr('Build FAILED')
+ ec = 1
+ except error.internal as ierr:
+ log.stderr(str(ierr))
+ log.stderr('Internal Build FAILED')
+ ec = 1
+ except error.exit as eerr:
+ pass
+ log.notice('abort: user terminated')
+ ec = 1
+ except:
+ raise
+ log.notice('abort: unknown error')
+ ec = 1
+ sys.exit(ec)
+if __name__ == "__main__":
+ run()
2.20.1
