[PATCH] score: Compact objects class indices
Wed May 22 13:40:14 UTC 2019
On 22/05/2019 15:23, Joel Sherrill wrote:
> I'm OK with this.
> Is the statement that the API and class numbers are not
> guaranteed to be held constant across releases something
> that should be explicitly in a comment or requirement?
The question is how can an application get one of the class numbers? I
think the only legal way is to create an object and then use
rtems_object_id_get_class(). The constants are only for internal use and
not a part of the API?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
