Where to Store Requirements for RTEMS Components
Thu May 23 05:35:02 UTC 2019
On 23/5/19 12:25 am, Sebastian Huber wrote:
> We definitely need a repository to store the requirements files (Doorstop,
> YAML). This is the first thing we have to know. If it later turns out that the
> choice was bad, we can still remove it from one repository and do a subtree
> import in another.
I suggest you use personal repos under your name to experiment with. It will
give you more freedom and will not impact on the main repos until we know the
direction.
