Where to Store Requirements for RTEMS Components
Thu May 23 05:40:33 UTC 2019
On 23/05/2019 07:35, Chris Johns wrote:
> On 23/5/19 12:25 am, Sebastian Huber wrote:
>> We definitely need a repository to store the requirements files (Doorstop,
>> YAML). This is the first thing we have to know. If it later turns out that the
>> choice was bad, we can still remove it from one repository and do a subtree
>> import in another.
> I suggest you use personal repos under your name to experiment with. It will
> give you more freedom and will not impact on the main repos until we know the
> direction.
Yes, we can do this. The drawback with this approach is that the work is
a bit more detached from the RTEMS development and will probably end up
with a huge patch set out of nothing.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
