GSoC Project | Basic Support for Trace Compass
Ravindra Kumar Meena rmeena840 at gmail.com
Sun May 26 11:49:49 UTC 2019
Hi Sebastian, Gedare
On Fri, May 24, 2019 at 8:11 PM Gedare Bloom <gedare at gwmail.gwu.edu> wrote:
> On Fri, May 24, 2019, 8:32 AM Ravindra Kumar Meena <rmeena840 at gmail.com>
> wrote:
>>> >Please clone the repository and look at it a bit more closely.
>> >Which repository? I have already cloned the rtems-libbsd.
> >Get to understand how to use babeltrace. Try some small examples.
 I tried tracing example given here
https://lttng.org/docs/v2.10/#doc-tracing-your-own-user-application. This
example generates the CTF data. I have attached all the files in case if
you want to try them out. After that, I used babeltrace to read the CTF
data and print it in text format. I have also attached the
output("babeltrace CTF.png") of the command line.
I used "babeltrace ~/lttng-traces/my-user-space-session*" command line to
read the CTF data.
> >NB: not all features mentioned in babeltrace docs are supported yet. It
> is best to try things out and dig in.
Okay
>>> > Do I have to code in python to trace the C/C++ application?
>>> No, that would be to slow.
>> Okay
> Babeltrace is written in Python3. If you use it to convert Trace files,
> you can interface to it from python, or there are C/C++ bindings.
Okay Thanks
> Can you please configure your email application not to color the quoted
> reply? (Even better, use plain text email rather than HTML.)
Sure
>> devel mailing list
>> devel at rtems.org
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190526/495babf9/attachment-0001.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190526/495babf9/attachment-0003.bin>
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190526/495babf9/attachment-0004.bin>
Type: text/x-chdr
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190526/495babf9/attachment-0005.bin>
Name: babeltrace output.png
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190526/495babf9/attachment-0001.png>
