GSoC Project | Basic Support for Trace Compass
Mon May 27 14:20:59 UTC 2019
On 26/05/2019 13:49, Ravindra Kumar Meena wrote:
> Hi Sebastian, Gedare
> On Fri, May 24, 2019 at 8:11 PM Gedare Bloom <gedare at gwmail.gwu.edu
> <mailto:gedare at gwmail.gwu.edu>> wrote:
>     On Fri, May 24, 2019, 8:32 AM Ravindra Kumar Meena
>     <rmeena840 at gmail.com <mailto:rmeena840 at gmail.com>> wrote:
>             >Please clone the repository and look at it a bit more closely.
>         >Which repository? I have already cloned the rtems-libbsd.
>     >Get to understand how to use babeltrace. Try some small examples.
>  I tried tracing example given here
> https://lttng.org/docs/v2.10/#doc-tracing-your-own-user-application.
> This example generates the CTF data. I have attached all the files in
> case if you want to try them out. After that, I used babeltrace to
> read the CTF data and print it in text format. I have also attached
> the output("babeltrace CTF.png") of the command line.
> I used "babeltrace ~/lttng-traces/my-user-space-session*" command line
> to read the CTF data.
This is good, since you can use the same method to check the CTF data
you generate from an RTEMS record item stream.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
