Instructions to send a Patch
Joel Sherrill
joel at rtems.org
Tue May 28 16:24:02 UTC 2019
Also the newlib community really appreciates it if we review the patches on
the RTEMS development list first. When the patch is OK, then it can go to
the newlib list.
--joel
On Mon, May 27, 2019 at 12:12 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> Hello, okay I will keep that in mind.
> But there is one problem with this patch then.
> If i just copy-paste ndbm.h, db.h(needed by ndbm.h) and ndbm.c and make
> the entry of ndbm.c in Makefile.am.
> Then run 'autoreconf' to add the entry for ndbm.c in Makefile.in. And
> then run `make` command. There will be compilation error.
> Header files needed by libc/posic/*.c files are present in libc/include
> directory. It is default path.
> But ndbm.c also requires "hash.h" which is present inside "libc/search".
> To over come it, i had to modify the entry of ndbm.c in Makefile.in and
> add "-I (topr_srcdir)/search" to specify the compiler for alternative
> source path.
> The problem is, to modify Makefile.in there should be entry of ndbm.c .
> And for that i need to run autoreconf command. Because of that multiple
> files get modified and hence the patch size got bigger..
> One solution can be that I should not use autoreconf and make manual
> entries for ndbm.c in Makefile.in . Should I try that?
> Because there is need to mention alternative source path for header files,
> to compile ndbm.c.
> Thankyou
> Vaibhav Gupta
> On Mon, 27 May, 2019, 7:38 PM Aditya Upadhyay, <aadit0402 at gmail.com>
> wrote:
>> Hi Vaibhav,
>> You have sent a completely wrong patch. You do not need to include all
>> these files what are existed there. You should generate a patch for
>> your work like addition or modification or if you have added any other
>> file.
>> This patch should go to newlib mailing list. For your entire GSoC
>> period, You will send patch to Newlib-Cygwin and For testing
>> contributed methods, you will be adding testcases in rtems/testsuite.
>> For testing those methods, you will have to apply patches to
>> rtems-source-builder, see instructions here:
>> https://docs.rtems.org/releases/rtemsdocs-4.10.2/share/rtems/html/started/started00036.html
>> If you have not introduced yourself on newlib mailing list, then
>> Introduce yourself there. Point your plan what you are going to do
>> this GSoC Period. Though these are parts of Community bonding period.
>> I appreciate your effort. This is just an initial phase of GSoC. You
>> should take care of these things.
>> Thanks,
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190528/fc320b7a/attachment.html>
