Error during execution of testsuites on host OS, for ARM Architecture.
Fri May 3 00:55:29 UTC 2019
Hi
I tried to post this earlier but was having outgoing mail problems.
The command varies between versions of qemu. It is likely the rtems-tester
configuration file
for this BSP doesn't match the version of qemu you have built. This is from
a shell script
I use on an application. Notice the difference in arguments due to qemu
version.
 #echo "-no-reboot -serial null -serial mon:stdio -net none -nographic -M
xilinx-zynq-a9 -m 256M ${COVERAGE_ARG} -kernel ${1}"
  echo "-no-reboot -monitor none -serial stdio -net none -nographic -M
--joel
On Thu, May 2, 2019, 7:50 PM Chris Johns <chrisj at rtems.org> wrote:
> On 3/5/19 2:49 am, Gedare Bloom wrote:
> > Try to manually run the executable directly by qemu. Ask if you need
> more direction
> Good advice. Also the command line for qemu can be seen by adding
> `--trace` to
> the `rtems-test` command line and then looking in the log file. I suggest
> you
> run a single test until it is working.
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190502/e6cd25a2/attachment-0002.html>
