[PATCH 2/2] rcmd.c: Removed references to unsupported functions
Lou Woods Lou.Woods at OARcorp.com
Mon May 6 16:31:30 UTC 2019
All,
I verified that rcmdsh isn't part of libbsd, but as Chris pointed out I didn't add the pre-processor guards according to the CONTRIBUTING.md guide.  I'll fix my mistakes on that and resubmit.  Sorry about that.
Lou
> -----Original Message-----
> From: devel <devel-bounces at rtems.org> On Behalf Of Joel Sherrill
> Sent: Monday, May 6, 2019 9:31 AM
> To: Peter Dufault <dufault at hda.com>
> Cc: Lou Woods <irnhorse4 at gmail.com>; RTEMS Devel <rtems-
> devel at rtems.org>
> Subject: Re: [PATCH 2/2] rcmd.c: Removed references to unsupported
> functions
> On Mon, May 6, 2019 at 8:49 AM <dufault at hda.com
> <mailto:dufault at hda.com> > wrote:
> 		On May 6, 2019, at 01:02 , Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de> > wrote:
> 		On 05/05/2019 03:00, Chris Johns wrote:
> 			On 5/5/19 12:21 am, Joel Sherrill wrote:
> 				Sorry for missing that it actually was
> referenced
> 				Rcmd can and should work. Rcmdsh will not
> ever and should be removed from libbsd.
> 				Does rcmd need testing? It clearly had no test
> since it wouldn't have linked.
> 			Yes that would be great. Testing libbsd is a
> complicated.
> 		If it is used by applications it should be tested, otherwise we
> should remove it from the build to make it a little faster and reduce the
> maintenance costs of libbsd.
> 	It is used.  The use may be removed (this is a port from vxWorks) but
> as part of a baseline it is used.
> Just to be specific again. rcmd() can be made to work. rcmdsh() uses fork()
> and exec() so will never work.
> Lou's patch added conditionals to rcmd() to get around missing netgroup
> methods and avoid invoking rcmdsh() on one path.
> An update to this patch (or a follow up) needs to remove rcmdsh* from the
> rtems-libbsd source
> I suppose Lou also needs to add a test that verifies rcmd() works.
> --joel
> 	Peter
> 	Peter Dufault
> 	HD Associates, Inc.      Software and System Engineering
> 	This email is delivered through the public internet using protocols
> subject to interception and tampering.
