fatal after a new source-builder update
Ярослав Лещинский midniwalker at gmail.com
Wed May 15 13:45:17 UTC 2019
yes, I know, I just checked that behavior is the same as before.
With these flags -mthumb -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard
I got error from linker:
/home/midnight/rtems/toolchain/5/lib/gcc/arm-rtems5/7.4.1/../../../../arm-rtems5/bin/ld:
error: o-optimize/test.exe uses VFP register arguments, /
home/midnight/workspace/rtems/build/arm-rtems5/stm32l4/lib/librtemsbsp.a(bspfatal-default.o)
does not
failed to merge target specific data of file /home/midnig
Currently I'm trying to figure out what is a problem.
On Wed, 15 May 2019 at 16:33, Sebastian Huber <
> On 15/05/2019 15:31, Ярослав Лещинский wrote:
> > problem solved after edition of CPU_FLAGS as mentioned in stm32f4.cfg:
> > CPU_FLAGS = -mthumb -mcpu=cortex-m4
> If you use these flags, then you don't use the floating point instructions.
Kind regards,
*Yaroslav Leshchinsky*
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190515/5bd2fe81/attachment-0002.html>
