fatal after a new source-builder update
Ярослав Лещинский midniwalker at gmail.com
Wed May 15 14:06:16 UTC 2019
if change to CPU_CFLAGS =  -mthumb -mcpu=cortex-m4 -mfpu=fpv4-sp-d16
-mfloat-abi=softfp, application not responded at all.
On Wed, 15 May 2019 at 16:45, Ярослав Лещинский <midniwalker at gmail.com>
wrote:
> yes, I know, I just checked that behavior is the same as before.
> With these flags -mthumb -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard
> I got error from linker:
> /home/midnight/rtems/toolchain/5/lib/gcc/arm-rtems5/7.4.1/../../../../arm-rtems5/bin/ld:
> error: o-optimize/test.exe uses VFP register arguments, /
> home/midnight/workspace/rtems/build/arm-rtems5/stm32l4/lib/librtemsbsp.a(bspfatal-default.o)
> does not
> failed to merge target specific data of file /home/midnig
> Currently I'm trying to figure out what is a problem.
> On Wed, 15 May 2019 at 16:33, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 15/05/2019 15:31, Ярослав Лещинский wrote:
>> > problem solved after edition of CPU_FLAGS as mentioned in stm32f4.cfg:
>> > CPU_FLAGS = -mthumb -mcpu=cortex-m4
>> If you use these flags, then you don't use the floating point
>> instructions.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Kind regards,
> *Yaroslav Leshchinsky*
Kind regards,
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190515/cf579990/attachment-0002.html>
