How important is Cygwin support for host tools?
Jiri Gaisler
jiri at gaisler.se
Thu May 30 13:29:15 UTC 2019
On 5/30/19 2:46 PM, Joel Sherrill wrote:
> On Thu, May 30, 2019, 7:41 AM Jiri Gaisler <jiri at gaisler.se
> <mailto:jiri at gaisler.se>> wrote:
> Does anyone still use Cygwin for RTEMS development? The reason I
> ask is
> that I have some portability issues for sis (no async I/O on
> sockets in
> Cygwin) and I would like to avoid some ugly workarounds if
> possible. In
> the age of virtualization and even WSL in Win 10, do we still need
> Cygwin ...?
> There are still users on Cygwin and we test there periodically to
> avoid breakage.
> It would be nice to see sis work on Cygwin but I understand if it won't.
There is really only one issue - when sis is connected to gdb, a running
program cannot be interrupted by pressing ctrl-C in gdb. The program can
be stopped by pressing ctrl-C in the simulator window instead, which is
maybe a sufficient workaround..? I will start by letting sis print a
warning for this if gdb mode is entered under cygwin. If there are (too)
many complaints, I will look at it again...
Jiri.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190530/b2ea8fe0/attachment-0002.html>
