[PATCH v2] eng: Add Software Requirements Engineering chapter
Joel Sherrill
joel at rtems.org
Thu Nov 7 21:55:32 UTC 2019
Overall, this is really good. I am sure we will polish details as
things progress. I marked a few places with notes. Mostly
grammar or minor points.
On Thu, Nov 7, 2019 at 3:24 AM Sebastian Huber <
> v2:
> * Updates due to Doorstop improvements, e.g. UID with names, use of SHA256
> for item fingerprints, adding custom attributes to the fingerprint.
> * More detailed specification item types.
> * The normal patch review process is now described in the RTEMS User
> Manual.
> I removed the binary files from the patch. For the generated document see:
> https://ftp.rtems.org/pub/rtems/people/sebh/eng.pdf
> Unfortunately, on openSUSE 15.1 the RTEMS branding of the document no
> longer
> works.
> This is still work in progress. It is a good first step from my point of
> view
> from nothing to something. We have to work out the details throughout the
> next
> year.
> eng/index.rst | 1 +
> eng/req-eng.rst | 1127
> images/eng/req-add.pdf | Bin 0 -> 81320 bytes
> images/eng/req-add.png | Bin 0 -> 50516 bytes
> images/eng/req-add.uml | 40 ++
> images/eng/req-modify.pdf | Bin 0 -> 68500 bytes
> images/eng/req-modify.png | Bin 0 -> 37776 bytes
> images/eng/req-modify.uml | 34 ++
> images/eng/req-spec-items.pdf | Bin 0 -> 84896 bytes
> images/eng/req-spec-items.png | Bin 0 -> 86050 bytes
> images/eng/req-spec-items.uml | 60 +++
> 11 files changed, 1262 insertions(+)
> create mode 100644 eng/req-eng.rst
> create mode 100644 images/eng/req-add.pdf
> create mode 100644 images/eng/req-add.png
> create mode 100644 images/eng/req-add.uml
> create mode 100644 images/eng/req-modify.pdf
> create mode 100644 images/eng/req-modify.png
> create mode 100644 images/eng/req-modify.uml
> create mode 100644 images/eng/req-spec-items.pdf
> create mode 100644 images/eng/req-spec-items.png
> create mode 100644 images/eng/req-spec-items.uml
> diff --git a/eng/index.rst b/eng/index.rst
> index cfc831b..802eec9 100644
> --- a/eng/index.rst
> +++ b/eng/index.rst
> @@ -26,6 +26,7 @@ RTEMS Software Engineering (|version|)
> preface
> prequalification
> stakeholders
> + req-eng
> management
> test-plan
> test-framework
> diff --git a/eng/req-eng.rst b/eng/req-eng.rst
> new file mode 100644
> index 0000000..8d64f2b
> --- /dev/null
> +++ b/eng/req-eng.rst
> @@ -0,0 +1,1127 @@
> +.. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2019 embedded brains GmbH
> +.. |E40| replace:: ECSS-E-ST-40C
> +.. |E10-06| replace:: ECSS-E-ST-10-06C
> +.. _ReqEng:
> +Software Requirements Engineering
> +Software engineering standards for critical software such as |E40| demand
> that
> +software requirements for a software product are collected in a software
> +requirements specification (technical specification in |E40| terms).
> They are
> +usually derived from system requirements (requirements baseline in |E40|
> +terms). RTEMS is designed as a reusable software product which can be
> utilized
> +by application designers to ease the development of their applications.
> The
> +requirements of the end system (system requirements) using RTEMS are only
> known
> +to the application designer. RTEMS itself is developed by the RTEMS
> +maintainers and they do not know the requirements of a particular end
> system in
> +general. RTEMS is designed as a real-time operating system to meet
> typical
> +system requirements for a wide range of applications. Its suitability
> for a
> +particular application must be determined by the application designer
> based on
> +the technical specification provided by RTEMS accompanied with
> performance data
> +for a particular target platform.
> The paragraph below is quite long. I think starting "A key success..."
could
start another paragraph. There is likely another break to be found. The SMP
could be another paragraph.
> +Currently, no technical specification of RTEMS exists in the form of a
> +dedicated document. Since the beginning of the RTEMS evolution in the
> late
> +1980s it was developed iteratively. It was never developed in a waterfall
> +model. During initial development the RTEID :cite:`Motorola:1988:RTEID`
> and
> +later the ORKID :cite:`VITA:1990:ORKID` draft specifications were used as
> +requirements. These were evolving during the development and an iterative
> +approach was followed often using simple algorithms and coming back to
> +optimise. In 1993 and 1994 a subset of pthreads sufficient to support
> +:term:`GNAT` was added as requirements. At this time the Ada tasking was
> +defined, however, not implemented in GNAT, so this involved guessing
> during the
> +development. Later some adjustments were made when Ada tasking was
> actually
> +implemented. So, it was consciously iterative with the specifications
> evolving
> +and feedback from performance analysis. Benchmarks published from other
> real
> +time operating systems were used for comparison. Optimizations were
> carried
> +out until the results were comparable. Development was done with distinct
> +contractual phases and tasks for development, optimization, and the
> addition of
> +priority inheritance and rate monotonic scheduling. The pthreads
> requirement
> +has grown to be as much POSIX as possible. Portability to FreeBSD to use
> the
> +network stack, USB stack, SD/MMC card stack and device drivers resulted in
> +another set of requirements.
"Portability to FreeBSD" seems inverted from what I think of. We provided
a FreeBSD device driver kernel interface compatible implementation to
support hosting FreeBSD kernel code on RTEMS. We didn't port to FreeBSD.
> The support for symmetric multiprocessing (SMP)
> +was a huge driver for change. It was developed step by step and
> sponsored by
> +several independent users with completely different applications and
> target
> +platforms in mind. The high performance OpenMP support introduced the
> Futex as
> +a new synchronization primitive.
The addition of support for SMP...
> A key success element of RTEMS is the ability
> +to accept changes driven by user needs and still keep the operating system
> +stable enough for production systems. Procedures that place a high
> burden on
> +changes are doomed to be discarded by the RTEMS project. We have to keep
> this
> +in mind when we introduce a requirements management work flow which
> should be
> +followed by RTEMS community members and new contributors.
The middle sentence could be in an emphasis box. It is a critical point to
this
entire process.
> +We have to put in some effort first into the reconstruction of software
> +requirements through reverse engineering using the RTEMS documentation,
> test
> +cases, sources, standard references, mailing list archives, etc. as input.
> +Writing a technical specification for the complete RTEMS code base is
> probably
> +a job of several person-years. We have to get started with a moderate
> feature
> +set (e.g. subset of the Classic API) and extend it based on user demands
> step
> +by step.
> +The development of the technical specification will take place in two
> phases.
> +The first phase tries to establish an initial technical specification for
> an
> +initial feature set. This technical specification will be integrated into
> +RTEMS as a big chunk. In the second phase the technical specification is
> +modified through arranged procedures. There will be procedures
> +* to modify existing requirements,
> +* add new requirements, and
> +* mark requirements as obsolete.
> +All procedures should be based on a peer review principles.
> +Requirements for Requirements
> +.. _ReqEngIdent:
> +Identification
> +Each requirement shall have a unique identifier (UID). The question is in
> +which scope should it be unique? Ideally, it should be universally
> unique. As
> +a best effort approach, the name *RTEMS* shall be used as a part in all
> +requirement identifiers. This should ensure that the RTEMS requirements
> can be
> +referenced easily in larger systems. The standard ECSS-E-ST-10-06C
> recommends
> +in section 8.2.6 that the identifier should reflect the type of the
> requirement
> +and the life profile situation. Other standards may have other
> +recommendations. To avoid a bias of RTEMS in the direction of ECSS, this
> +recommendation will not be followed.
> +.. topic:: Doorstop
> + The UID of an item (requirement) is defined by its file name without
> the
> + extension. An UID consists of two parts, the prefix and a name or a
> number.
> + The parts are divided by an optional separator. The prefix is
> determined by
> + the document.
> +The UID scheme for RTEMS requirements is the concatenation of *RTEMS*,
> one or
> +more component names, and a name. Each part is separated by a "-"
> +character. For example, the UID RTEMS-CLASSIC-TASK-CRATERRINVADDR may
> specify
> +that the `rtems_task_create()` directive shall return a status of
> +`RTEMS_INVALID_ADDRESS` if the `id` parameter is `NULL`.
The CRATERRINVADDR part is undecipherable to me. Can we have more than 4
letters
for the method name? :I couldn't figure out what RTEMS had to do with
Crates. :)
> + Doorstop uses documents to create namespaces (named a prefix in
> Doorstop).
> + For the example above, you can create the documents like this:
> + .. code-block:: none
> + doorstop create -s - RTEMS-CLASSIC -p RTEMS spec/classic
> + doorstop create -s - RTEMS-CLASSIC-TASK -p RTEMS-CLASSIC
> spec/classic/task
> + doorstop create -s - RTEMS-CLASSIC-SEMAPHORE -p RTEMS-CLASSIC
> spec/classic/semaphore
> + The requirement files are organized in directories.
> +A initial requirement item hierarchy could be this:
> +* RTEMS
> + * BUILD (building RTEMS BSPs and libraries)
> + * CONFIG (application configuration)
> + * CLASSIC
> + * TASK
> + * CRAT* (requirements for `rtems_task_create()`)
> + * DELT* (requirements for `rtems_task_delete()`)
> + * EXIT* (requirements for `rtems_task_exit()`)
> + * GAFF* (requirements for `rtems_task_get_affinity()`)
> + * GPRI* (requirements for `rtems_task_get_priority()`)
> + * GSHD* (requirements for `rtems_task_get_scheduler()`)
> + * IDNT* (requirements for `rtems_task_ident()`)
> + * ISUS* (requirements for `rtems_task_is_suspended()`)
> + * ITER* (requirements for `rtems_task_iterate()`)
> + * MODE* (requirements for `rtems_task_mode()`)
> + * RSRT* (requirements for `rtems_task_restart()`)
> + * RSME* (requirements for `rtems_task_resume()`)
> + * SELF* (requirements for `rtems_task_self()`)
> + * SAFF* (requirements for `rtems_task_set_affinity()`)
> + * SPRI* (requirements for `rtems_task_set_priority()`)
> + * SSHD* (requirements for `rtems_task_set_scheduler()`)
> + * STRT* (requirements for `rtems_task_start()`)
> + * SUSP* (requirements for `rtems_task_suspend()`)
> + * WAFT* (requirements for `rtems_task_wake_after()`)
> + * WWHN* (requirements for `rtems_task_wake_when()`)
> Some are OK with 4 letters. Others are mysterious. Six letters may be
better
if possible. Hmmm.. The RTEID names were 6 letters prefixed with one or
two letters for the manager and an underscore. It used to be t_create, etc.
> + * Semaphore
> + * POSIX
> +The specification of the validation of requirements should be maintained
> also by
> +Doorstop. For each requirement document there should be a validation
> child
> +Doorstop document with a *TEST* component name, e.g.
> RTEMS-CLASSIC-TASK-TEST. A
> +test document may contain also validations by analysis, by inspection,
> and by
> +design, see :ref:`ReqEngValidation`.
> +Level of Requirements
> +The level of a requirement shall be expressed with one of the verbal forms
> +listed below and nothing else. The level of requirements are derived
> from RFC
> +2119 :cite:`RFC2119` and |E10-06| :cite:`ECSS_E_ST_10_06C`.
> +Absolute Requirements
> +Absolute requirements shall be expressed with the verbal form *shall* and
> no
> +other terms.
> +Absolute Prohibitions
> +Absolute prohibitions shall be expressed with the verbal form *shall not*
> and
> +no other terms.
> +.. warning::
> + Absolute prohibitions may be difficult to validate. They should not
> be
> + used.
> +Recommendations
> +Recommendations shall be expressed with the verbal forms *should* and
> +*should not* and no other terms with guidance from RFC 2119:
> + SHOULD This word, or the adjective "RECOMMENDED", mean that there
> + may exist valid reasons in particular circumstances to ignore a
> + particular item, but the full implications must be understood and
> + carefully weighed before choosing a different course.
> + SHOULD NOT This phrase, or the phrase "NOT RECOMMENDED" mean that
> + there may exist valid reasons in particular circumstances when the
> + particular behavior is acceptable or even useful, but the full
> + implications should be understood and the case carefully weighed
> + before implementing any behavior described with this label.
> +Permissions
> +Permissions shall be expressed with the verbal form *may* and no other
> terms
> +with guidance from RFC 2119:
> + MAY This word, or the adjective "OPTIONAL", mean that an item is
> + truly optional. One vendor may choose to include the item because a
> + particular marketplace requires it or because the vendor feels that
> + it enhances the product while another vendor may omit the same item.
> + An implementation which does not include a particular option MUST be
> + prepared to interoperate with another implementation which does
> + include the option, though perhaps with reduced functionality. In the
> + same vein an implementation which does include a particular option
> + MUST be prepared to interoperate with another implementation which
> + does not include the option (except, of course, for the feature the
> + option provides.)
> +Possibilities and Capabilities
> +Possibilities and capabilities shall be expressed with the verbal form
> *can*
> +and no other terms.
> +.. _ReqEngSyntax:
> +Syntax
> +Use the Easy Approach to Requirements Syntax (:term:`EARS`) to formulate
> +requirements. A recommended reading list to get familiar with this
> approach is
> +:cite:`Mavin:2009:EARS`, :cite:`Mavin:2010:BigEars`, and
> +:cite:`Mavin:2016:LLEARS`. Please also have a look at the EARS quick
> reference
> +sheet :cite:`Uusitalo:2012:EARS`. The sentence types are:
> +* Ubiquitous
> + The <system name> shall <system response>.
> +* Event-driven
> + *When* <optional preconditions> <trigger>, the <system name> shall
> <system response>.
> +* State-driven
> + *While* <in state>, the <system name> shall <system response>.
> +* Unwanted behaviour
> + *If* <optional preconditions> <trigger>, *then* the <system name>
> +* Optional
> + *Where* <feature>, the <system name> shall <system response>.
> +The optional sentence type should be only used for application
> configuration
> +options. The goal is to use *enabled-by* and *disabled-by* attributes to
> +enable or disable requirements based on configuration parameters that
> define
> +the RTEMS artefacts used to build an application executable (header files,
> +libraries, linker command files). Such configuration parameters are for
> +example the architecture, the platform, CPU port options, and build
> +configuration options (e.g. uniprocessor vs. SMP).
> +Wording Restrictions
> +To prevent the expression of imprecise requirements, the following terms
> shall
> +not be used in requirement formulations:
> +* "acceptable"
> +* "adequate"
> +* "almost always"
> +* "and/or"
> +* "appropriate"
> +* "approximately"
> +* "as far as possible"
> +* "as much as practicable"
> +* "best"
> +* "best possible"
> +* "easy"
> +* "efficient"
> +* "e.g."
> +* "enable"
> +* "enough"
> +* "etc."
> +* "few"
> +* "first rate"
> +* "flexible"
> +* "generally"
> +* "goal"
> +* "graceful"
> +* "great"
> +* "greatest"
> +* "ideally"
> +* "i.e."
> +* "if possible"
> +* "in most cases"
> +* "large"
> +* "many"
> +* "maximize"
> +* "minimize"
> +* "most"
> +* "multiple"
> +* "necessary"
> +* "numerous"
> +* "optimize"
> +* "ought to"
> +* "probably"
> +* "quick"
> +* "rapid"
> +* "reasonably"
> +* "relevant"
> +* "robust"
> +* "satisfactory"
> +* "several"
> +* "shall be included but not limited to"
> +* "simple"
> +* "small"
> +* "some"
> +* "state-of-the-art".
> +* "sufficient"
> +* "suitable"
> +* "support"
> +* "systematically"
> +* "transparent"
> +* "typical"
> +* "user-friendly"
> +* "usually"
> +* "versatile"
> +* "when necessary"
> +For guidelines to avoid these terms see Table 11-2, "Some ambiguous terms
> to
> +avoid in requirements" in :cite:`Wiegers:2013:SR`.
> Good stuff. Are we enforcing this somehow?
> +Separate Requirements
> +Requirements shall be stated separately. A bad example is:
> +RTEMS-CLASSIC-TASK-CRAT
> + The task create directive shall evaluate the parameters, allocate a
> task
> + object and initialize it.
> +To make this a better example, it should be split into separate
> requirements:
> + When the task create directive is called with valid parameters and a
> free
> + task object exists, the task create directive shall assign the
> identifier of
> + an initialized task object to the id parameter and return the
> + RTEMS_SUCCESSFUL status.
> +RTEMS-CLASSIC-TASK-CRATERRTOOMANY
> + If no free task objects exists, the task create directive shall
> return the
> + RTEMS_TOO_MANY status.
> +RTEMS-CLASSIC-TASK-CRATERRINVADDR
> + If the id parameter is NULL, the task create directive shall return
> the
> + RTEMS_INVALID_ADDRESS status.
> +RTEMS-CLASSIC-TASK-CRATERRINVNAME
> + If the name parameter is not valid, the task create directive shall
> return
> + the RTEMS_INVALID_NAME status.
> +Conflict Free Requirements
> +Requirements shall not be in conflict with each other inside a
> specification.
> +A bad example is:
> +RTEMS-CLASSIC-SEMAPHORE-MTXOBWAIT
> + If a mutex is not available, the mutex obtain directive shall enqueue
> the
> + calling thread on the wait queue of the mutex.
> +RTEMS-CLASSIC-SEMAPHORE-MTXOBERRUNSAT
> + If a mutex is not available, the mutex obtain directive shall return
> the
> + RTEMS_UNSATISFIED status.
> +To resolve this conflict, a condition may be added:
> + If a mutex is not available, when the RTEMS_WAIT option is set, the
> mutex
> + obtain directive shall enqueue the calling thread on the wait queue
> of the
> + mutex.
> + If a mutex is not available, when the RTEMS_WAIT option is not set,
> the
> + mutex obtain directive shall return the RTEMS_UNSATISFIED status.
> +Use of Project-Specific Terms and Abbreviations
> +All project-specific terms and abbreviations used to formulate
> requirements
> +shall be defined in the project glossary.
> +.. _ReqEngJustReq:
> +Justification of Requirements
> +Each requirement shall have a rationale or justification recorded in a
> +dedicated section of the requirement file.
> + See *rationale* attribute for :ref:`ReqEngSpecItems`.
> +.. _ReqEngSpecItems:
> +Specification Items
> +The technical specification of RTEMS will contain requirements,
> specializations
> +of requirements, :ref:`test procedures <ReqEngTestProcedure>`,
> +:ref:`test suites <ReqEngTestSuite>`, :ref:`test cases <ReqEngTestCase>`,
> and
> +:ref:`requirement validations <ReqEngValidation>`. These things will be
> called
> +*specification items* or just *items* if it is clear from the context.
> + Doorstop maintains *items* which are included in *documents*. The
> normal
> + use case is to store a requirement with meta-data in an item.
> However,
> + items can be also used to store other things like test procedures,
> test
> + suites, test cases, and requirement validations. Items contain
> key-value
> + pairs called attributes. Specializations of requirements may contain
> extra
> + attributes, e.g. interface, build, configuration requirements. All
> items
> + have the following standard Doorstop attributes:
> + active
> + A boolean value which indicates if the requirement is active or
> not.
> + The value is included in the fingerprint via a document
> configuration
> + option.
> + derived
> + A boolean value which indicates if the requirement is derived or
> not.
> + For the
> + `definition of derived <
> https://github.com/jacebrowning/doorstop/blob/develop/docs/reference/item.md#derived
> >`_.
> + see the Doorstop documentation. For RTEMS, this value shall be
> false
> + for all requirements. The value is not included in the
> fingerprint.
> + normative
> + A boolean value which indicates if the requirement is normative
> or not.
> + For the
> + `definition of normative <
> https://github.com/jacebrowning/doorstop/blob/develop/docs/reference/item.md#normative
> >`_.
> true
> fingerprint.
> + level
> + Indicates the presentation order within a document. For RTEMS,
> this
> + value shall be unused. The value is not included in the
> fingerprint.
> + header
> + A header for an item. For RTEMS, this value shall be the empty
> string.
> + The value is not included in the fingerprint.
> + reviewed
> + The fingerprint of the item. Maintain this attribute with the
> + `doorstop clear` command.
> + links
> + The links from this item to parent items. Maintain this
> attribute with
> + the `doorstop link` command. The value is included in the
> fingerprint.
> + ref
> + References to files and directories. See
> + `#365 <https://github.com/jacebrowning/doorstop/issues/365>`_,
> + The value is included in the fingerprint.
> + text
> + The item text. The value is included in the fingerprint.
> + All items shall have the following extended attributes:
> + type:
> + A list of :ref:`item types <ReqEngItemTypes>`. The value is not
> + included in the fingerprint.
> + enabled-by:
> + The value is a list of expressions. The value is included in the
> + fingerprint. An expression is an operator or an option. An
> option
> + evaluates to true if it is set in the configuration. An operator
> is a
> + dictionary with exactly one key and a value. The value of the
> `not`
> + operator shall be an expression. It negates the outcome of its
> + expression. The value of the `and` operator shall be a list of
> + expressions. It evaluates to the logical and of all outcomes of
> the
> + expressions in the list. The outcome of a list of expressions is
> the
> + logical or of all outcomes of the expressions in the list.
> Example:
> + enabled-by:
> + - OPT1
> + - OPT2
> + - not: OPT3
> + - and:
> + - OPT4
> + - OPT5
> + - not:
> + - OPT6
> + - OPT7
> Do you have an example from RTEMS for this?
> + rationale:
> + The rationale or justification of the specification item. The
> value is
> + **not** included in the fingerprint.
> +.. _ReqEngItemTypes:
> +Item Types
> +Specification items can have all sorts of *types*. The selection of
> types and the
> +level of detail depends on a particular standard and product model. We
> need
> +enough flexibility to be in line with ECSS-E-ST-10-06 and possible future
> +applications of other standards. Each item may have a list of types.
> Valid
> +types are listed below. This list may change over time. If new types are
> +added, then a mapping between types should be specified. The item types
> and
> +their definition is work in progress. A list of types follows:
> +* functional requirements - Functional requirements shall describe the
> behaviour of the
> + software product under specific conditions.
> + * *capability*
> + * *dependability-function*
> + * *function*
> + * *operational* - Operational requirements shall
> + * define the operation modes (e.g. initialization, multitasking,
> termination),
> + * describe the operation modes, and
> + * describe the operation mode transitions.
> + * *safety-function*
> +* non-functional requirements
> + * *build-configuration*
> + * *constraint*
> + * *design*
> + * *interface*
> + * *interface-requirement*
> + * *maintainability*
> + * *performance*
> + * *portability*
> + * *quality*
> + * *reliability*
> + * *resource*
> + * *safety*
> +* *test-procedure*
> +* *test-suite*
> +* *test-case*
> +* *validation-by-analysis*
> +* *validation-by-inspection*
> +* *validation-by-review-of-design*
> +* *validation-platform*
> +.. image:: ../images/eng/req-spec-items.*
> + :scale: 70
> + :align: center
> +Build Configuration
> +Build configuration requirements define what needs to be built (libraries,
> +object files, test executables, etc.) and how (configuration option header
> +files, compiler flags, linker flags, etc.). The goal is to generate build
> +files (Makefile or waf) and content for the Software Configuration File
> (SCF)
> +from it. A YAML scheme needs to be defined for this purpose.
> +.. _ReqEngInterfaceReq:
> +Interface Requirement
> +Interface requirements shall describe the high level aspects of
> interfaces.
> +The item type shall be *interface-requirement*.
> +.. _ReqEngInterface:
> +Interface
> +Interface items shall specify the interface of the software product to
> other
> +software products and the hardware. The item type shall be *interface*.
> The
> +interface items shall have an *interface-category* which is one of the
> +following and nothing else:
> +* *application*: Application interface items shall describe the interface
> + between the software product and the application (:term:`API`). The
> goal is
> + to generate header files with Doxygen markup and user manual
> documentation
> + parts from the application interface specification.
> +* *application-configuration*: Application configuration items shall
> define
> + parameters of the software product which can be set by the application
> at
> + link-time. The goal is to generate user manual documentation parts and
> test
> + cases from the application configuration specification.
> +* *architecture*: Architecture interface items shall define the
> + interface between the software product and the processor architecture
> + (:term:`ABI`).
> +* *gcc*: GCC interface items shall define the interface between the
> software
> + product and GCC components such as libgcc.a, libatomic.a, libgomp.a,
> + libstdc++.a, etc.
> +* *hardware*: Hardware interface items shall define the interface between
> the
> + software product and the hardware.
> +* *newlib*: Newlib interface items shall define the interface between the
> + software product and the Newlib (libc.a).
> +The interface items shall have an *interface-type* which is one of the
> +* *configuration-option*
> +* *define*
> +* *enum*
> +* *function*
> +* *header*
> +* *macro*
> +* *register-block*
> +* *structure*
> +* *typedef*
> +* *union*
> +* *variable*
> +.. _ReqEngInterfaceApplicationConfig:
> +Interface - Application Configuration
> + The application configuration items shall have the following attribute
> + specializations:
> + type
> + The type value shall be *interface*.
> + interface-category
> + The interface category value shall be *application-configuration*.
> + interface-type
> + The interface type value shall be *configuration-option*.
> + link
> + There shall be a link to a higher level requirement.
> + text
> + The application configuration requirement.
> + configuration-category:
> + A category to which this application configuration option belongs.
> + define:
> + The name of the configuration define.
> + data-type:
> + The data type of the configuration define.
> + value-range:
> + The range of valid values.
> + default-value:
> + The default value.
> + description:
> + The description of the application configuration. The description
> + should focus on the average use-case. It should not cover
> potential
> + problems, constraints, obscure use-cases, corner cases and
> everything
> + which makes matters complicated.
> + note:
> + Notes for this application configuration. The notes should
> explain
> + everything which was omitted from the description. It should
> cover all
> + the details.
> +.. _ReqEngTestProcedure:
> +Test Procedure
> +Test procedures shall be executed by the Qualification Toolchain.
> + The test procedure items shall have the following attribute
> + specializations:
> + type
> + The type value shall be *test-procedure*.
> + text
> + The purpose of this test procedure.
> + platform
> + There shall be links to validation platform requirements.
> + steps
> + The test procedure steps. Could be a list of key-value pairs.
> The key
> + is the step name and the value is a description of the actions
> + performed in this step.
> +.. _ReqEngTestSuite:
> +Test Suite
> +Test suites shall use the :ref:`RTEMS Test Framework
> <RTEMSTestFramework>`.
> + The test suite items shall have the following attribute
> specializations:
> + type
> + The type value shall be *test-suite*.
> + text
> + The test suite description.
> +.. _ReqEngTestCase:
> +Test Case
> +Test cases shall use the :ref:`RTEMS Test Framework <RTEMSTestFramework>`.
> + The test case items shall have the following attribute
> specializations:
> + type
> + The type value shall be *test-case*.
> + link
> + The link to the requirement validated by this test case or no
> links if
> + this is a unit or integration test case.
> + ref
> + If this is a unit test case, then a reference to the
> :term:`software
> + item` under test shall be provided. If this is an integration
> test
> + case, then a reference to the integration under test shall be
> provided.
> + The integration is identified by its Doxygen group name.
> + text
> + A short description of the test case.
> + inputs
> + The inputs to execute the test case.
> + outputs
> + The expected outputs.
> + The test case code may be also contained in the test case
> specification
> + item in a *code* attribute. This is subject to discussion on the
> RTEMS
> + mailing list. Alternatively, the test code could be placed directly
> in
> + source files. A method is required to find the test case
> specification of
> + a test case code and vice versa.
> +.. _ReqEngResAndPerf:
> +Resources and Performance
> +Normally, resource and performance requirements are formulated like this:
> +* The resource U shall need less than V storage units.
> +* The operation Y shall complete within X time units.
> +Such statements are difficult to make for a software product like RTEMS
> which
> +runs on many different target platforms in various configurations. So,
> the
> +performance requirements of RTEMS shall be stated in terms of
> benchmarks. The
> +benchmarks are run on the project-specific target platform and
> configuration.
> +The results obtained by the benchmark runs are reported in a human
> readable
> +presentation. The application designer can then use the benchmark
> results to
> +determine if its system performance requirements are met. The benchmarks
> shall
> +be executed under different environment conditions, e.g. varying cache
> states
> +(dirty, empty, valid) and system bus load generated by other processors.
> The
> +application designer shall have the ability to add additional environment
> +conditions, e.g. system bus load by DMA engines or different system bus
> +arbitration schemes.
> +To catch resource and performance regressions via test suite runs there
> shall be
> +a means to specify threshold values for the measured quantities. The
> threshold
> +values should be provided for each validation platform. How this can be
> done
> +and if the threshold values are maintained by the RTEMS Project is
> subject to
> +discussion.
> We focused on big-O and whether methods were constant time, bounded, or
O(n)
when designing. Perhaps the focus could be there. But this is a design goal
for all
of RTEMS and something we would document. Nothing to do except a general
design goal.
This section also sounds like part of what is required by a systems
integrator
when leveraging what the FAA calls a Reusable Software Component:
https://www.faa.gov/regulations_policies/advisory_circulars/index.cfm/go/document.information/documentID/22207
You get credit for what's common and have to fill in details for your
system.
> +.. _ReqEngTrace:
> +Traceability of Specification Items
> +The standard |E10-06| demands that requirements shall be under
> configuration
> +management, backwards-traceable and forward-traceable. Requirements are a
> +specialization of specification items in RTEMS.
> +.. _ReqEngTraceHistory:
> +History of Specification Items
> +The RTEMS specification items should placed in the RTEMS sources using
> Git for
> +version control. The history of specification items can be traced with
> Git.
> +Special commit procedures for changes in specification item files should
> be
> +established. For example, it should be allowed to change only one
> +specification item per commit. A dedicated Git commit message format may
> be
> +used as well, e.g. use of ``Approved-by:`` or ``Reviewed-by:`` lines which
> +indicate an agreed statement (similar to the
> +`Linux kernel patch submission guidelines <
> https://www.kernel.org/doc/html/latest//process/submitting-patches.html#using-reported-by-tested-by-reviewed-by-suggested-by-and-fixes
> >`_).
> +Git commit procedures may be ensured through a server-side pre-receive
> hook.
> +The history of requirements may be also added to the specification items
> +directly in a ``revision`` attribute. This would make it possible to
> generate
> +the history information for documents without having the Git repository
> +available, e.g. from an RTEMS source release archive.
> +.. _ReqEngTraceBackward:
> +Backward Traceability of Specification Items
> +Providing backward traceability of specification items means that we must
> be
> +able to find the corresponding higher level specification item for each
> refined
> +specification item. This is a standard Doorstop feature.
> +.. _ReqEngTraceForward:
> +Forward Traceability of Specification Items
> +Providing forward traceability of specification items means that we must
> be
> +able to find all the refined specification items for each higher level
> +specification item. This is a standard Doorstop feature. The links from
> +parent to child specification items are implicitly defined by links from a
> +child item to a parent item.
> +.. _ReqEngTraceReqArchDesign:
> +Traceability between Software Requirements, Architecture and Design
> +The software requirements are implemented in Doorstop compatible YAML
> files.
> +The software architecture and design is written in Doxygen markup.
> Doxygen
> +markup is used throughout all header and source files. A Doxygen filter
> +program may be provided to place Doxygen markup in assembler files. The
> +software architecture is documented via Doxygen groups. Each Doxygen
> group
> +name should have a project-specific name and the name should be unique
> within
> +the project, e.g. RTEMSTopLevel\ MidLevel\ LowLevel. The link from a
> Doxygen
> +group to its parent group is realized through the `@ingroup` special
> command.
> +The link from a Doxygen group or software component to the corresponding
> +requirement is realized through a `@satisfy{req}`
> +`custom command <http://www.doxygen.nl/manual/custcmd.html>`_
> +which needs the identifier of the requirement as its one and only
> parameter.
> +Only links to parents are explicitly given in the Doxygen markup. The
> links
> +from a parent to its children are only implicitly specified via the link
> from a
> +child to its parent. So, a tool must process all files to get the
> complete
> +hierarchy of software requirements, architecture and design. Links from a
> +software component to another software component are realized through
> automatic
> +Doxygen references or the ``@ref`` and ``@see`` special commands.
> +.. _ReqEngValidation:
> +Requirement Validation
> +The validation of each requirement shall be accomplished by one or more of
> +the following methods and nothing else:
> +* *By test*: A :ref:`ReqEngTestCase` specification item is provided to
> + demonstrate that the requirement is satisfied when the software product
> is
> + executed on the target platform.
> +* *By analysis*: A statement is provided how the requirement is met, by
> + analysing static properties of the software product.
> +* *By inspection*: A statement is provided how the requirement is met, by
> + inspection of the :term:`source code`.
> +* *By review of design*: A rationale is provided to demonstrate how the
> + qualification requirement is satisfied implicitly by the software
> design.
> +Validation by test is strongly recommended. The choice of any other
> validation
> +method shall be justified.
I would say that if it isn't by test, then the requirements author is
obligated to
provide the means to verify the requirement and instructions. They provide
the
design artifacts, etc. You can't throw us a verify by inspection without
telling
us what to inspect, how to do it, and providing the artifact to inspect.
This is
not a new project and each requirement added comes with an obligation.
> + For an item in a parent document it is checked that at least one item
> in a
> + child document has a link to it. For example a child document could
> + contain validation items. With this feature you can check that all
> + requirements are covered by at least one validation item.
> + The requirement validation by analysis, by inspection, and by design
> + specification items shall have the following attribute
> specializations:
> + type
> + The type attribute value shall be *validation-by-analysis*,
> + *validation-by-inspection*, or *validation-by-review-of-design*.
> + link
> + There shall be exactly one link to the validated requirement.
> + text
> + The statement or rational of the requirement validation.
> +Requirement Management
> +Change Control Board
> +Working with requirements usually involves a Change Control Board
> +(:term:`CCB`). The CCB of the RTEMS project is the
> +`RTEMS developer mailing list <
> https://lists.rtems.org/mailman/listinfo/devel>`_.
> +There are the following actors involved:
> +* *RTEMS users*: Everyone using the RTEMS real-time operating system to
> design,
> + develop and build an application on top of it.
> +* *RTEMS developers*: The persons developing and maintaining RTEMS. They
> write
> + patches to add or modify code, requirements, tests and documentation.
> +* *RTEMS maintainers*: They are listed in the
> + `MAINTAINERS <https://git.rtems.org/rtems/tree/MAINTAINERS>`_ file and
> have
> + write access to the project repositories.
> +Adding and changing requirements follows the normal patch review
> process. The
> +normal patch review process is described in the
> +`RTEMS User Manual <
> https://docs.rtems.org/branches/master/user/support/contrib.html#patch-review-process
> >`_.
> +Reviews and comments may be submitted by anyone, but a maintainer review
> is
> +required to approve *significant* changes. In addition for significant
> +changes, there should be at least one reviewer with a sufficient
> independence
> +from the author which proposes a new requirement or a change of an
> existing
> +requirement. Working in another company on different projects is
> sufficiently
> +independent. RTEMS maintainers do not know all the details, so they
> trust in
> +general people with experience on a certain platform. Sometimes no review
> +comments may appear in a reasonable time frame, then an implicit
> agreement to
> +the proposed changes is assumed. Patches can be sent at anytime, so
> +controlling changes in RTEMS requires a permanent involvement on the RTEMS
> +developer mailing list.
> +For a qualification of RTEMS according to certain standards, the
> requirements
> +may be approved by an RTEMS user. The approval by RTEMS users is not the
> +concern of the RTEMS project, however, the RTEMS project should enable
> RTEMS
> +users to manage the approval of requirements easily. This information
> may be
> +also used by a independent authority which comes into play with an
> Independent
> +Software Verification and Validation (:term:`ISVV`). It could be used to
> +select a subset of requirements, e.g. look only at the ones approved by a
> +certain user. RTEMS users should be able to reference the determinative
> +content of requirements, test procedures, test cases and justification
> reports
> +in their own documentation. Changes in the determinative content should
> +invalidate all references to previous versions.
> +Add a Requirement
> +.. image:: ../images/eng/req-add.*
> + :scale: 70
> + :align: center
> +.. _ReqEngModifyRequirement:
> +Modify a Requirement
> +.. image:: ../images/eng/req-modify.*
> + :scale: 70
> + :align: center
> +Mark a Requirement as Obsolete
> +Requirements shall be never removed. They shall be marked as obsolete.
> This
> +ensures that requirement identifiers are not reused. The procedure to
> obsolete
> +a requirement is the same as the one to :ref:`modify a requirement
> +<ReqEngModifyRequirement>`.
> +Tooling
> +Tool Requirements
> +To manage requirements some tool support is helpful. Here is a list of
> requirements for the tool:
> +* The tool shall be open source.
> +* The tool should be actively maintained during the initial phase of the
> RTEMS
> + requirements specification.
> +* The tool shall use plain text storage (no binary formats, no database).
> +* The tool shall support version control via Git.
> +* The tool should export the requirements in a human readable form using
> the Sphinx documentation framework.
> +* The tool shall support traceability of requirements to items external
> to the tool.
> +* The tool shall support traceability between requirements.
> +* The tool shall support custom requirement attributes.
> +* The tool should ensure that there are no cyclic dependencies between
> requirements.
> +* The tool should provide an export to :term:`ReqIF`.
> +Tool Evaluation
> +During an evaluation phase the following tools were considered:
> +* `aNimble <https://sourceforge.net/projects/nimble/>`_
> +* :term:`Doorstop`
> +* `OSRMT <https://github.com/osrmt/osrmt>`_
> +* `Papyrus <https://www.eclipse.org/papyrus/>`_
> +* `ProR <https://www.eclipse.org/rmf/pror/>`_
> +* `ReqIF Studio <https://formalmind.com/tools/studio/>`_
> +* `Requirement Heap <https://sourceforge.net/projects/reqheap/>`_
> +* `rmToo <http://rmtoo.florath.net/>`_
> +The tools aNimble, OSRMT and Requirement Heap were not selected since
> they use
> +a database. The tools Papyrus, ProR and ReqIF are Eclipse based and use
> +complex XML files for data storage. They were difficult to use and lack
> good
> +documentation/tutorials. The tools rmToo and Doorstop turned out to be
> the
> +best candidates to manage requirements in the RTEMS project. The
> Doorstop tool
> +was selected as the first candidate mainly due a recommendation by an
> RTEMS
> +user.
> +Selected Tool - Doorstop
> +:term:`Doorstop` is a requirements management tool. It has a modern,
> +object-oriented and well-structured implementation in Python 3.6 under the
> +LGPLv3 license. It uses a continuous integration build with style
> checkers,
> +static analysis, documentation checks, code coverage, unit test and
> integration
> +tests. In 2019, the project was actively maintained. Pull requests for
> minor
> +improvements and new features were reviewed and integrated within days.
> Each
> +requirement is contained in a single file in :term:`YAML` format.
> Requirements
> +are organized in documents and can be linked to each other
> +:cite:`Browning:2014:RequirementsManagement`.
> +Doorstop consists of three main parts
> +* a stateless command line tool `doorstop`,
> +* a file format with a pre-defined set of attributes (YAML), and
> +* a primitive GUI tool (not intended to be used).
> +For RTEMS, its scope will be extended to manage specifications in
> general. The
> +primary reason for selecting Doorstop as the requirements management tool
> for
> +the RTEMS Project is its data format which allows a high degree of
> customization. Doorstop uses a directed, acyclic graph of
> +items. The items are files in YAML format. Each item has a set of
> +`standard attributes <
> https://doorstop.readthedocs.io/en/latest/reference/item/>`_
> +(key-value pairs).
Paragraph has a line which seems too long
> +The use case for the standard attributes is requirements management.
> However,
> +Doorstop is capable to manage custom attributes as well. We will heavily
> use
> +custom attributes for the specification items. Enabling Doorstop to
> effectively
> +use custom attributes was done specifically for the RTEMS Project in
> several
> +patch sets.
> +A key feature of Doorstop is the `fingerprint of items
> +<https://doorstop.readthedocs.io/en/latest/reference/item/#reviewed>`_.
> +For the RTEMS Project, the fingerprint hash algorithm was changed from
> MD5 to
> +SHA256. In 2019, it can be considered cryptographically secure. The
> +fingerprint should cover the normative values of an item, e.g. comments
> etc. are
> +not included. The fingerprint helps RTEMS users to track the significant
> +changes in the requirements (in contrast to all the changes visible in
> Git). As
> +an example use case, a user may want to assign a project-specific status
> to
> +specification items. This can be done with a table which contains
> columns for
> +1. the UID of the item,
> +2. the fingerprint, and
> +3. the project-specific status.
> +Given the source code of RTEMS (which includes the specification items)
> and this
> +table, it can be determined which items are unchanged and which have
> another
> +status (e.g. unknown, changed, etc.).
> diff --git a/images/eng/req-add.uml b/images/eng/req-add.uml
> index 0000000..52b01f0
> --- /dev/null
> +++ b/images/eng/req-add.uml
> @@ -0,0 +1,40 @@
> +' SPDX-License-Identifier: CC-BY-SA-4.0
> +' Copyright (C) 2019 embedded brains GmbH
> + at startuml
> +start
> +:Invoke: ""doorstop add RTEMS"";
> +note right
> + This will create a new requirement.
> + For this activity its UID shall be NEW.
> + It is located in a file NEW.yml.
> +end note
> +while (Needs a link to a parent requirement?) is (Yes)
> + :Invoke: ""doorstop link NEW PARENT"";
> +endwhile (No)
> +repeat
> + :Invoke: ""doorstop edit NEW"";
> + :Edit the requirement according to your needs and save it;
> + :Commit NEW.yml with a proper message;
> + :Send the patch to the devel at rtems.org mailing list for review;
> +repeat while (Reviewers demand changes in the new requirement?) is (Yes)
> +->No;
> +if (New requirement was accepted by reviewers?) then (Yes)
> + :Push the commit to the project repository;
> +else (No)
> + :Discard the NEW requirement;
> +endif
> +stop
> + at enduml
> diff --git a/images/eng/req-modify.uml b/images/eng/req-modify.uml
> index 0000000..cb104a6
> --- /dev/null
> +++ b/images/eng/req-modify.uml
> @@ -0,0 +1,34 @@
> + at startuml
> +start
> +repeat
> + :Invoke: ""doorstop edit REQ"";
> + note right
> + For this activity the UID
> + of the requirement shall be REQ.
> + It is located in a file REQ.yml.
> + end note
> + :Commit REQ.yml with a proper message;
> +repeat while (Reviewers demand changes in the modified requirement?) is
> (Yes)
> +->No;
> +if (Modified requirement was accepted by reviewers?) then (Yes)
> +else (No)
> + :Keep the requirement as is;
> +endif
> +stop
> + at enduml
> diff --git a/images/eng/req-spec-items.uml b/images/eng/req-spec-items.uml
> index 0000000..f837a85
> --- /dev/null
> +++ b/images/eng/req-spec-items.uml
> @@ -0,0 +1,60 @@
> + at startuml
> +class SpecificationItem {
> + active
> + derived
> + enabled-by
> + header
> + level
> + links
> + normative
> + rationale
> + ref
> + reviewed
> + text
> + type
> +class Interface {
> + interface-type
> +class TestProcedure {
> + platform
> + steps
> +class TestCase {
> + inputs
> + outputs
> +class TestCase
> +note right: test cases not validating\na requirement are unit tests
> +SpecificationItem <|-- Requirement
> +Requirement <|-- Functional
> +Requirement <|-- NonFunctional
> +NonFunctional <|-- Interface
> +SpecificationItem <|-- TestProcedure
> +SpecificationItem <|-- TestSuite
> +SpecificationItem <|-- TestCase
> +SpecificationItem <|-- Validation\nByAnalysis
> +SpecificationItem <|-- Validation\nByInspection
> +SpecificationItem <|-- Validation\nByReviewOfDesign
> +SpecificationItem <|-- ValidationPlatform
> +TestProcedure "1..n" -- TestSuite : "run by"
> +TestSuite "1..n" -- TestCase : "contained in"
> +ValidationPlatform "1..n" -- TestProcedure : "requires"
> +Requirement "0..1" -- TestCase : "validates"
> +Requirement "1" -- Validation\nByAnalysis : "validates"
> +Requirement "1" -- Validation\nByInspection : "validates"
> +Requirement "1" -- Validation\nByReviewOfDesign : "validates"
> + at enduml
> 2.16.4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191107/1030fc08/attachment-0001.html>
