[PATCH v2] eng: Add Software Requirements Engineering chapter
Sebastian Huber
Fri Nov 8 07:13:30 UTC 2019
Hello Joel,
thanks for the review, I tried to address all your issues in v3 with one
exception:
On 07/11/2019 22:55, Joel Sherrill wrote:
> Overall, this is really good. I am sure we will polish details as
> things progress. I marked a few places with notes. Mostly
> grammar or minor points.
> +.. _ReqEngResAndPerf:
> +Resources and Performance
> +Normally, resource and performance requirements are formulated like
> this:
> +* The resource U shall need less than V storage units.
> +* The operation Y shall complete within X time units.
> +Such statements are difficult to make for a software product like
> RTEMS which
> +runs on many different target platforms in various configurations.
> So, the
> +performance requirements of RTEMS shall be stated in terms of
> benchmarks. The
> +benchmarks are run on the project-specific target platform and
> configuration.
> +The results obtained by the benchmark runs are reported in a human
> readable
> +presentation. The application designer can then use the benchmark
> results to
> +determine if its system performance requirements are met. The
> benchmarks shall
> +be executed under different environment conditions, e.g. varying
> cache states
> +(dirty, empty, valid) and system bus load generated by other
> processors. The
> +application designer shall have the ability to add additional
> environment
> +conditions, e.g. system bus load by DMA engines or different system bus
> +arbitration schemes.
> +To catch resource and performance regressions via test suite runs
> there shall be
> +a means to specify threshold values for the measured quantities.
> The threshold
> +values should be provided for each validation platform. How this
> can be done
> +and if the threshold values are maintained by the RTEMS Project is
> subject to
> +discussion.
> We focused on big-O and whether methods were constant time, bounded, or O(n)
> when designing. Perhaps the focus could be there. But this is a design
> goal for all
> of RTEMS and something we would document. Nothing to do except a general
> design goal.
> This section also sounds like part of what is required by a systems
> integrator
> when leveraging what the FAA calls a Reusable Software Component:
> https://www.faa.gov/regulations_policies/advisory_circulars/index.cfm/go/document.information/documentID/22207
> You get credit for what's common and have to fill in details for your
> system.
I added a ticket for this:
https://devel.rtems.org/ticket/3819
I think it is important to look at, but I need some time to read the
advisory.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
