[PATCH 06/13] sptests: Remove obsolete semaphore consume driver
Sebastian Huber
Fri Nov 8 14:02:54 UTC 2019
This driver is no longer used by a test program.
Update #3818.
testsuites/sptests/Makefile.am | 16 +-----
testsuites/sptests/spfatal_support/consume_sems.c | 63 -----------------------
testsuites/sptests/spfatal_support/system.h | 11 ----
3 files changed, 2 insertions(+), 88 deletions(-)
delete mode 100644 testsuites/sptests/spfatal_support/consume_sems.c
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index a86b438d61..4d033f6c53 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -1001,7 +1001,7 @@ sp_tests += spfatal14
sp_screens += spfatal14/spfatal14.scn
sp_docs += spfatal14/spfatal14.doc
spfatal14_SOURCES = spfatal_support/init.c \
- spfatal_support/consume_sems.c spfatal_support/system.h \
+ spfatal_support/system.h \
spfatal14/testcase.h
spfatal14_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spfatal14) \
$(support_includes) -I$(top_srcdir)/spfatal14
@@ -1012,24 +1012,12 @@ sp_tests += spfatal15
sp_screens += spfatal15/spfatal15.scn
sp_docs += spfatal15/spfatal15.doc
spfatal15_SOURCES = spfatal_support/init.c \
spfatal15/testcase.h
spfatal15_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spfatal15) \
$(support_includes) -I$(top_srcdir)/spfatal15
endif
-if TEST_spfatal16
-sp_tests += spfatal16
-sp_screens += spfatal16/spfatal16.scn
-sp_docs += spfatal16/spfatal16.doc
-spfatal16_SOURCES = spfatal_support/init.c \
- spfatal16/testcase.h
-spfatal16_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spfatal16) \
- $(support_includes) -I$(top_srcdir)/spfatal16 \
- -DSEMAPHORES_REMAINING=4
-endif
if TEST_spfatal24
sp_tests += spfatal24
sp_screens += spfatal24/spfatal24.scn
diff --git a/testsuites/sptests/spfatal_support/consume_sems.c b/testsuites/sptests/spfatal_support/consume_sems.c
deleted file mode 100644
index 20fa1eeb1b..0000000000
--- a/testsuites/sptests/spfatal_support/consume_sems.c
+++ /dev/null
@@ -1,63 +0,0 @@
- * COPYRIGHT (c) 1989-2012.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems.h>
-/* forward declarations to avoid warnings */
-rtems_device_driver consume_semaphores_initialize(
- rtems_device_major_number major RTEMS_UNUSED,
- rtems_device_minor_number minor RTEMS_UNUSED,
- void *pargp RTEMS_UNUSED
-#define MAXIMUM 20
-rtems_id Semaphores[MAXIMUM];
- int sems;
- rtems_status_code status;
- for ( sems=0 ; sems<MAXIMUM ; sems++ ) {
- status = rtems_semaphore_create(
- rtems_build_name( 'S', 'M', '1', ' ' ),
- 1,
- RTEMS_DEFAULT_MODES,
- RTEMS_NO_PRIORITY,
- &Semaphores[sems]
- if ( status == RTEMS_TOO_MANY )
- break;
- #if 0
- printk( "Consumed %d\n", sems );
- printk( "Freeing %d\n", SEMAPHORES_REMAINING );
- #endif
- #if defined(SEMAPHORES_REMAINING)
- int i;
- for ( i=0 ; i<SEMAPHORES_REMAINING ; i++ ) {
- (void) rtems_semaphore_delete( Semaphores[i] );
- #endif
- return RTEMS_SUCCESSFUL;
diff --git a/testsuites/sptests/spfatal_support/system.h b/testsuites/sptests/spfatal_support/system.h
index 1dc0d8b19b..c03b303c2b 100644
--- a/testsuites/sptests/spfatal_support/system.h
+++ b/testsuites/sptests/spfatal_support/system.h
@@ -40,17 +40,6 @@ void Put_Source( rtems_fatal_source source );
void force_error(void);
-/* need some prototypes for test cases */
-#define CONSUME_SEMAPHORE_DRIVERS \
- { consume_semaphores_initialize, NULL, NULL, NULL, NULL, NULL }
#include "testcase.h"
/* configuration information */
2.16.4
