[PATCH 05/13] spfatal16: Remove obsolete test program
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Nov 11 11:47:23 UTC 2019
You remove the sources here but the Makefile.am part is removed in the
next patch 06/13. This will be a problem for git bisect.
On 08/11/2019 15:02, Sebastian Huber wrote:
> The "TRrc" semaphore was removed in commit
> 2c12262f9a8fe7975556729f0574fab8d5a792f5.
>  testsuites/sptests/spfatal16/spfatal16.doc | 19 -------------------
>  testsuites/sptests/spfatal16/spfatal16.scn |  3 ---
>  testsuites/sptests/spfatal16/testcase.h    | 29 -----------------------------
>  3 files changed, 51 deletions(-)
>  delete mode 100644 testsuites/sptests/spfatal16/spfatal16.doc
>  delete mode 100644 testsuites/sptests/spfatal16/spfatal16.scn
>  delete mode 100644 testsuites/sptests/spfatal16/testcase.h
> diff --git a/testsuites/sptests/spfatal16/spfatal16.doc b/testsuites/sptests/spfatal16/spfatal16.doc
> deleted file mode 100644
> index f4b388b2c9..0000000000
> --- a/testsuites/sptests/spfatal16/spfatal16.doc
> +++ /dev/null
> @@ -1,19 +0,0 @@
> -#  COPYRIGHT (c) 1989-2010.
> -#  On-Line Applications Research Corporation (OAR).
> -#  The license and distribution terms for this file may be
> -#  found in the file LICENSE in this distribution or at
> -#  http://www.rtems.org/license/LICENSE.
> -This file describes the directives and concepts tested by this test set.
> -test set name:  spfatal16
> -directives:
> -  rtems_termios_open
> -concepts:
> -+ fatal error for one of the semaphore creates
> diff --git a/testsuites/sptests/spfatal16/spfatal16.scn b/testsuites/sptests/spfatal16/spfatal16.scn
> index 3fd27db533..0000000000
> --- a/testsuites/sptests/spfatal16/spfatal16.scn
> +++ /dev/null
> @@ -1,3 +0,0 @@
> -*** TEST FATAL 16 ***
> -Fatal error (termios sem create #1) hit
> -*** END OF TEST FATAL 16 ***
> diff --git a/testsuites/sptests/spfatal16/testcase.h b/testsuites/sptests/spfatal16/testcase.h
> index 412f20e04a..0000000000
> --- a/testsuites/sptests/spfatal16/testcase.h
> +++ /dev/null
> @@ -1,29 +0,0 @@
> - *  COPYRIGHT (c) 1989-2010.
> - *  On-Line Applications Research Corporation (OAR).
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.org/license/LICENSE.
> -/* generate fatal errors in termios.c
> - *    rtems_semaphore_create( rtems_build_name ('T', 'R', 'r', c),...);
> -#include <rtems/test.h>
> -#define FATAL_ERROR_TEST_NAME            "16"
> -#define FATAL_ERROR_DESCRIPTION          "termios sem create #1"
> -#define FATAL_ERROR_EXPECTED_SOURCE      INTERNAL_ERROR_RTEMS_API
> -#define FATAL_ERROR_EXPECTED_ERROR       RTEMS_TOO_MANY
> -#define CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS \
> -  CONSUME_SEMAPHORE_DRIVERS
> -void force_error()
> -  /* This fatal error depends on the Termios device configuration */
> -  TEST_END();
> -  rtems_test_exit(0);
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
