[PATCH 05/13] spfatal16: Remove obsolete test program
Sebastian Huber
Fri Nov 8 14:02:53 UTC 2019
The "TRrc" semaphore was removed in commit
2c12262f9a8fe7975556729f0574fab8d5a792f5.
testsuites/sptests/spfatal16/spfatal16.doc | 19 -------------------
testsuites/sptests/spfatal16/spfatal16.scn | 3 ---
testsuites/sptests/spfatal16/testcase.h | 29 -----------------------------
3 files changed, 51 deletions(-)
delete mode 100644 testsuites/sptests/spfatal16/spfatal16.doc
delete mode 100644 testsuites/sptests/spfatal16/spfatal16.scn
delete mode 100644 testsuites/sptests/spfatal16/testcase.h
diff --git a/testsuites/sptests/spfatal16/spfatal16.doc b/testsuites/sptests/spfatal16/spfatal16.doc
deleted file mode 100644
index f4b388b2c9..0000000000
--- a/testsuites/sptests/spfatal16/spfatal16.doc
+++ /dev/null
@@ -1,19 +0,0 @@
-# COPYRIGHT (c) 1989-2010.
-# On-Line Applications Research Corporation (OAR).
-# The license and distribution terms for this file may be
-# found in the file LICENSE in this distribution or at
-# http://www.rtems.org/license/LICENSE.
-This file describes the directives and concepts tested by this test set.
-test set name: spfatal16
-directives:
- rtems_termios_open
-concepts:
-+ fatal error for one of the semaphore creates
diff --git a/testsuites/sptests/spfatal16/spfatal16.scn b/testsuites/sptests/spfatal16/spfatal16.scn
index 3fd27db533..0000000000
--- a/testsuites/sptests/spfatal16/spfatal16.scn
+++ /dev/null
@@ -1,3 +0,0 @@
-*** TEST FATAL 16 ***
-Fatal error (termios sem create #1) hit
-*** END OF TEST FATAL 16 ***
diff --git a/testsuites/sptests/spfatal16/testcase.h b/testsuites/sptests/spfatal16/testcase.h
index 412f20e04a..0000000000
--- a/testsuites/sptests/spfatal16/testcase.h
+++ /dev/null
@@ -1,29 +0,0 @@
- * COPYRIGHT (c) 1989-2010.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-/* generate fatal errors in termios.c
- * rtems_semaphore_create( rtems_build_name ('T', 'R', 'r', c),...);
-#include <rtems/test.h>
-#define FATAL_ERROR_TEST_NAME "16"
-#define FATAL_ERROR_DESCRIPTION "termios sem create #1"
-#define FATAL_ERROR_EXPECTED_SOURCE INTERNAL_ERROR_RTEMS_API
-#define FATAL_ERROR_EXPECTED_ERROR RTEMS_TOO_MANY
-#define CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS \
- CONSUME_SEMAPHORE_DRIVERS
-void force_error()
- /* This fatal error depends on the Termios device configuration */
- TEST_END();
- rtems_test_exit(0);
2.16.4
