[PATCH 10/13] tmtests: Avoid build system defined defines
Sebastian Huber
Fri Nov 8 14:02:58 UTC 2019
Update #3818.
testsuites/tmtests/Makefile.am | 28 +++---
testsuites/tmtests/tm02/task1.c | 189 +------------------------------------
testsuites/tmtests/tm02/tm02impl.h | 187 ++++++++++++++++++++++++++++++++++++
testsuites/tmtests/tm03/task1.c | 180 +----------------------------------
testsuites/tmtests/tm03/tm03impl.h | 178 ++++++++++++++++++++++++++++++++++
testsuites/tmtests/tm31/task1.c | 2 +
testsuites/tmtests/tm32/task1.c | 2 +
testsuites/tmtests/tm33/task1.c | 2 +
testsuites/tmtests/tm34/task1.c | 2 +
testsuites/tmtests/tm35/task1.c | 2 +
testsuites/tmtests/tm36/task1.c | 2 +
11 files changed, 395 insertions(+), 379 deletions(-)
create mode 100644 testsuites/tmtests/tm02/tm02impl.h
create mode 100644 testsuites/tmtests/tm03/tm03impl.h
create mode 100644 testsuites/tmtests/tm31/task1.c
create mode 100644 testsuites/tmtests/tm32/task1.c
create mode 100644 testsuites/tmtests/tm33/task1.c
create mode 100644 testsuites/tmtests/tm34/task1.c
create mode 100644 testsuites/tmtests/tm35/task1.c
create mode 100644 testsuites/tmtests/tm36/task1.c
diff --git a/testsuites/tmtests/Makefile.am b/testsuites/tmtests/Makefile.am
index eb5d2dfeaa..70b67fa6dd 100644
--- a/testsuites/tmtests/Makefile.am
+++ b/testsuites/tmtests/Makefile.am
@@ -28,7 +28,7 @@ tm_docs += tm02/tm02.doc
tm02_SOURCES = tm02/task1.c tm02/system.h include/timesys.h \
../support/src/tmtests_empty_function.c
tm02_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_tm02) $(support_includes) \
- -I$(top_srcdir)/include -DTM02
+ -I$(top_srcdir)/include
endif
if TEST_tm03
@@ -37,7 +37,7 @@ tm_docs += tm03/tm03.doc
tm03_SOURCES = tm03/task1.c tm03/system.h include/timesys.h \
tm03_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_tm03) $(support_includes) \
- -I$(top_srcdir)/include -DTM03
endif
if TEST_tm04
@@ -287,55 +287,55 @@ endif
if TEST_tm31
tm_tests += tm31
tm_docs += tm31/tm31.doc
-tm31_SOURCES = tm02/task1.c tm02/system.h include/timesys.h \
+tm31_SOURCES = tm31/task1.c tm02/system.h include/timesys.h \
tm31_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_tm31) $(support_includes) \
- -I$(top_srcdir)/../tm02 -I$(top_srcdir)/include -DTM31
+ -I$(top_srcdir)/../tm02 -I$(top_srcdir)/include
endif
if TEST_tm32
tm_tests += tm32
tm_docs += tm32/tm32.doc
-tm32_SOURCES = tm03/task1.c tm03/system.h include/timesys.h \
+tm32_SOURCES = tm32/task1.c tm03/system.h include/timesys.h \
tm32_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_tm32) $(support_includes) \
- -I$(top_srcdir)/../tm03 -I$(top_srcdir)/include -DTM32
+ -I$(top_srcdir)/../tm03 -I$(top_srcdir)/include
endif
if TEST_tm33
tm_tests += tm33
tm_docs += tm33/tm33.doc
-tm33_SOURCES = tm02/task1.c tm02/system.h include/timesys.h \
+tm33_SOURCES = tm33/task1.c tm02/system.h include/timesys.h \
tm33_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_tm33) $(support_includes) \
- -I$(top_srcdir)/../tm02 -I$(top_srcdir)/include -DTM33
endif
if TEST_tm34
tm_tests += tm34
tm_docs += tm34/tm34.doc
-tm34_SOURCES = tm03/task1.c tm03/system.h include/timesys.h \
+tm34_SOURCES = tm34/task1.c tm03/system.h include/timesys.h \
tm34_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_tm34) $(support_includes) \
- -I$(top_srcdir)/../tm03 -I$(top_srcdir)/include -DTM34
endif
if TEST_tm35
tm_tests += tm35
tm_docs += tm35/tm35.doc
-tm35_SOURCES = tm02/task1.c tm02/system.h include/timesys.h \
+tm35_SOURCES = tm35/task1.c tm02/system.h include/timesys.h \
tm35_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_tm35) $(support_includes) \
- -I$(top_srcdir)/../tm02 -I$(top_srcdir)/include -DTM35
endif
if TEST_tm36
tm_tests += tm36
tm_docs += tm36/tm36.doc
-tm36_SOURCES = tm03/task1.c tm03/system.h include/timesys.h \
+tm36_SOURCES = tm36/task1.c tm03/system.h include/timesys.h \
tm36_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_tm36) $(support_includes) \
- -I$(top_srcdir)/../tm03 -I$(top_srcdir)/include -DTM36
endif
if TEST_tmck
diff --git a/testsuites/tmtests/tm02/task1.c b/testsuites/tmtests/tm02/task1.c
index 8fe1bfd08f..c77039068e 100644
--- a/testsuites/tmtests/tm02/task1.c
+++ b/testsuites/tmtests/tm02/task1.c
@@ -1,187 +1,2 @@
- * COPYRIGHT (c) 1989-2014.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#if !defined(OPERATION_COUNT)
-#define OPERATION_COUNT 100
-#endif
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#define CONFIGURE_INIT
-#include "system.h"
-#if defined(TM02)
-const char rtems_test_name[] = "TIME TEST 2";
-#define SEMAPHORE_ATTRIBUTES (RTEMS_COUNTING_SEMAPHORE | RTEMS_FIFO)
-#define ATTR_DESC "counting/FIFO"
-#elif defined(TM31)
-const char rtems_test_name[] = "TIME TEST 31";
-#define SEMAPHORE_ATTRIBUTES (RTEMS_COUNTING_SEMAPHORE | RTEMS_PRIORITY)
-#define ATTR_DESC "counting/priority"
-#elif defined(TM33)
-const char rtems_test_name[] = "TIME TEST 33";
-#define SEMAPHORE_ATTRIBUTES RTEMS_BINARY_SEMAPHORE
-#define ATTR_DESC "binary/FIFO"
-#elif defined(TM35)
-const char rtems_test_name[] = "TIME TEST 35";
-#define SEMAPHORE_ATTRIBUTES (RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY)
-#define ATTR_DESC "binary/priority"
-#else
-#error "Unknown test configuration"
-#endif
-rtems_id High_id;
-rtems_id Low_id;
-rtems_id Semaphore_id;
-rtems_task High_task(
- rtems_task_argument argument
-rtems_task Middle_tasks(
-rtems_task Low_task(
-int operation_count = OPERATION_COUNT;
-void test_init(void);
-rtems_task Init(
- rtems_status_code status;
- Print_Warning();
- TEST_BEGIN();
- test_init();
- status = rtems_task_suspend( RTEMS_SELF );
- directive_failed( status, "rtems_task_suspend" );
- int index;
- rtems_task_priority priority;
- priority = 2;
- status = rtems_task_create(
- rtems_build_name( 'H', 'I', 'G', 'H' ),
- priority,
- RTEMS_MINIMUM_STACK_SIZE,
- RTEMS_DEFAULT_MODES,
- RTEMS_DEFAULT_ATTRIBUTES,
- &High_id
- directive_failed( status, "rtems_task_create of high task" );
- priority++;
- status = rtems_task_start( High_id, High_task, 0 );
- directive_failed( status, "rtems_task_start of high task" );
- if ( OPERATION_COUNT > RTEMS_MAXIMUM_PRIORITY - 2u )
- operation_count = (int) (RTEMS_MAXIMUM_PRIORITY - 2u);
- for ( index=2 ; index < operation_count ; index++ ) {
- rtems_build_name( 'M', 'I', 'D', ' ' ),
- priority,
- &Low_id
- directive_failed( status, "rtems_task_create middle" );
- priority++;
- status = rtems_task_start( Low_id, Middle_tasks, 0 );
- directive_failed( status, "rtems_task_start middle" );
- rtems_build_name( 'L', 'O', 'W', ' ' ),
- priority,
- &Low_id
- directive_failed( status, "rtems_task_create low" );
- status = rtems_task_start( Low_id, Low_task, 0 );
- directive_failed( status, "rtems_task_start low" );
- status = rtems_semaphore_create(
- rtems_build_name( 'S', 'M', '1', ' '),
- 0,
- SEMAPHORE_ATTRIBUTES,
- RTEMS_NO_PRIORITY,
- &Semaphore_id
- directive_failed( status, "rtems_semaphore_create of SM1" );
- /* start blocking rtems_semaphore_obtain time */
- benchmark_timer_initialize();
- (void) rtems_semaphore_obtain(
- Semaphore_id,
- RTEMS_DEFAULT_OPTIONS,
- RTEMS_NO_TIMEOUT
- Semaphore_id,
- RTEMS_NO_TIMEOUT
- end_time = benchmark_timer_read();
- put_time(
- "rtems_semaphore_obtain: " ATTR_DESC " not available caller blocks",
- end_time,
- operation_count - 1,
- 0,
- 0
- TEST_END();
- rtems_test_exit( 0 );
+#define TM02
+#include "tm02impl.h"
diff --git a/testsuites/tmtests/tm02/tm02impl.h b/testsuites/tmtests/tm02/tm02impl.h
new file mode 100644
index 0000000000..8fe1bfd08f
--- /dev/null
+++ b/testsuites/tmtests/tm02/tm02impl.h
@@ -0,0 +1,187 @@
+ * COPYRIGHT (c) 1989-2014.
+ * On-Line Applications Research Corporation (OAR).
+#if !defined(OPERATION_COUNT)
+#define OPERATION_COUNT 100
+#endif
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#define CONFIGURE_INIT
+#include "system.h"
+#if defined(TM02)
+const char rtems_test_name[] = "TIME TEST 2";
+#define SEMAPHORE_ATTRIBUTES (RTEMS_COUNTING_SEMAPHORE | RTEMS_FIFO)
+#define ATTR_DESC "counting/FIFO"
+#elif defined(TM31)
+const char rtems_test_name[] = "TIME TEST 31";
+#define SEMAPHORE_ATTRIBUTES (RTEMS_COUNTING_SEMAPHORE | RTEMS_PRIORITY)
+#define ATTR_DESC "counting/priority"
+#elif defined(TM33)
+const char rtems_test_name[] = "TIME TEST 33";
+#define SEMAPHORE_ATTRIBUTES RTEMS_BINARY_SEMAPHORE
+#define ATTR_DESC "binary/FIFO"
+#elif defined(TM35)
+const char rtems_test_name[] = "TIME TEST 35";
+#define SEMAPHORE_ATTRIBUTES (RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY)
+#define ATTR_DESC "binary/priority"
+#else
+#error "Unknown test configuration"
+#endif
+rtems_id High_id;
+rtems_id Low_id;
+rtems_id Semaphore_id;
+rtems_task High_task(
+ rtems_task_argument argument
+rtems_task Middle_tasks(
+rtems_task Low_task(
+int operation_count = OPERATION_COUNT;
+void test_init(void);
+rtems_task Init(
+ rtems_status_code status;
+ Print_Warning();
+ TEST_BEGIN();
+ test_init();
+ status = rtems_task_suspend( RTEMS_SELF );
+ directive_failed( status, "rtems_task_suspend" );
+ int index;
+ rtems_task_priority priority;
+ priority = 2;
+ status = rtems_task_create(
+ rtems_build_name( 'H', 'I', 'G', 'H' ),
+ priority,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &High_id
+ directive_failed( status, "rtems_task_create of high task" );
+ priority++;
+ status = rtems_task_start( High_id, High_task, 0 );
+ directive_failed( status, "rtems_task_start of high task" );
+ if ( OPERATION_COUNT > RTEMS_MAXIMUM_PRIORITY - 2u )
+ operation_count = (int) (RTEMS_MAXIMUM_PRIORITY - 2u);
+ for ( index=2 ; index < operation_count ; index++ ) {
+ rtems_build_name( 'M', 'I', 'D', ' ' ),
+ priority,
+ &Low_id
+ directive_failed( status, "rtems_task_create middle" );
+ priority++;
+ status = rtems_task_start( Low_id, Middle_tasks, 0 );
+ directive_failed( status, "rtems_task_start middle" );
+ rtems_build_name( 'L', 'O', 'W', ' ' ),
+ priority,
+ &Low_id
+ directive_failed( status, "rtems_task_create low" );
+ status = rtems_task_start( Low_id, Low_task, 0 );
+ directive_failed( status, "rtems_task_start low" );
+ status = rtems_semaphore_create(
+ rtems_build_name( 'S', 'M', '1', ' '),
+ 0,
+ SEMAPHORE_ATTRIBUTES,
+ RTEMS_NO_PRIORITY,
+ &Semaphore_id
+ directive_failed( status, "rtems_semaphore_create of SM1" );
+ /* start blocking rtems_semaphore_obtain time */
+ benchmark_timer_initialize();
+ (void) rtems_semaphore_obtain(
+ Semaphore_id,
+ RTEMS_DEFAULT_OPTIONS,
+ RTEMS_NO_TIMEOUT
+ Semaphore_id,
+ RTEMS_NO_TIMEOUT
+ end_time = benchmark_timer_read();
+ put_time(
+ "rtems_semaphore_obtain: " ATTR_DESC " not available caller blocks",
+ end_time,
+ operation_count - 1,
+ 0,
+ 0
+ TEST_END();
+ rtems_test_exit( 0 );
diff --git a/testsuites/tmtests/tm03/task1.c b/testsuites/tmtests/tm03/task1.c
index 50bbe1b4d2..88c13f3b64 100644
--- a/testsuites/tmtests/tm03/task1.c
+++ b/testsuites/tmtests/tm03/task1.c
@@ -1,178 +1,2 @@
-#endif
-#endif
-#if defined(TM03)
-const char rtems_test_name[] = "TIME TEST 3";
-#elif defined(TM32)
-const char rtems_test_name[] = "TIME TEST 32";
-#elif defined(TM34)
-const char rtems_test_name[] = "TIME TEST 34";
-#elif defined(TM36)
-const char rtems_test_name[] = "TIME TEST 36";
-#else
-#endif
-rtems_task test_init(
-rtems_task Init(
- rtems_id task_id;
- Print_Warning();
- TEST_BEGIN();
- rtems_build_name( 'T', 'A', '1', ' ' ),
- RTEMS_MAXIMUM_PRIORITY - 1u,
- &task_id
- directive_failed( status, "rtems_task_create of test_init" );
- status = rtems_task_start( task_id, test_init, 0 );
- directive_failed( status, "rtems_task_start of test_init" );
- rtems_task_exit();
- int index;
- rtems_id task_id;
- priority = RTEMS_MAXIMUM_PRIORITY - 2u;
- rtems_build_name( 'S', 'M', '1', '\0'),
- 0,
- &Semaphore_id
- for ( index = 2 ; index < operation_count ; index ++ ) {
- rtems_task_create(
- priority,
- &task_id
- priority--;
- rtems_task_start( task_id, Middle_tasks, 0 );
- priority,
- &task_id
- status = rtems_task_start( task_id, High_task, 0 );
- benchmark_timer_initialize(); /* start the timer */
- status = rtems_semaphore_release( Semaphore_id );
- Semaphore_id,
- RTEMS_NO_TIMEOUT
- (void) rtems_semaphore_release( Semaphore_id );
- Semaphore_id,
- RTEMS_NO_TIMEOUT
- put_time(
- "rtems_semaphore_release: " ATTR_DESC " task readied preempts caller",
- end_time,
- 0,
- 0
- TEST_END();
+#define TM03
+#include "tm03impl.h"
diff --git a/testsuites/tmtests/tm03/tm03impl.h b/testsuites/tmtests/tm03/tm03impl.h
index 0000000000..50bbe1b4d2
--- /dev/null
+++ b/testsuites/tmtests/tm03/tm03impl.h
@@ -0,0 +1,178 @@
+#endif
+#endif
+#if defined(TM03)
+const char rtems_test_name[] = "TIME TEST 3";
+#elif defined(TM32)
+const char rtems_test_name[] = "TIME TEST 32";
+#elif defined(TM34)
+const char rtems_test_name[] = "TIME TEST 34";
+#elif defined(TM36)
+const char rtems_test_name[] = "TIME TEST 36";
+#else
+#endif
+rtems_task test_init(
+rtems_task Init(
+ rtems_id task_id;
+ Print_Warning();
+ TEST_BEGIN();
+ rtems_build_name( 'T', 'A', '1', ' ' ),
+ RTEMS_MAXIMUM_PRIORITY - 1u,
+ &task_id
+ directive_failed( status, "rtems_task_create of test_init" );
+ status = rtems_task_start( task_id, test_init, 0 );
+ directive_failed( status, "rtems_task_start of test_init" );
+ rtems_task_exit();
+ int index;
+ rtems_id task_id;
+ priority = RTEMS_MAXIMUM_PRIORITY - 2u;
+ rtems_build_name( 'S', 'M', '1', '\0'),
+ 0,
+ &Semaphore_id
+ for ( index = 2 ; index < operation_count ; index ++ ) {
+ rtems_task_create(
+ priority,
+ &task_id
+ priority--;
+ rtems_task_start( task_id, Middle_tasks, 0 );
+ priority,
+ &task_id
+ status = rtems_task_start( task_id, High_task, 0 );
+ benchmark_timer_initialize(); /* start the timer */
+ status = rtems_semaphore_release( Semaphore_id );
+ Semaphore_id,
+ RTEMS_NO_TIMEOUT
+ (void) rtems_semaphore_release( Semaphore_id );
+ Semaphore_id,
+ RTEMS_NO_TIMEOUT
+ put_time(
+ "rtems_semaphore_release: " ATTR_DESC " task readied preempts caller",
+ end_time,
+ 0,
+ 0
+ TEST_END();
diff --git a/testsuites/tmtests/tm31/task1.c b/testsuites/tmtests/tm31/task1.c
index 0000000000..158c2d3dd4
--- /dev/null
+++ b/testsuites/tmtests/tm31/task1.c
@@ -0,0 +1,2 @@
+#define TM31
+#include "../tm02/tm02impl.h"
diff --git a/testsuites/tmtests/tm32/task1.c b/testsuites/tmtests/tm32/task1.c
index 0000000000..a1787fdb3e
--- /dev/null
+++ b/testsuites/tmtests/tm32/task1.c
@@ -0,0 +1,2 @@
+#define TM32
+#include "../tm03/tm03impl.h"
diff --git a/testsuites/tmtests/tm33/task1.c b/testsuites/tmtests/tm33/task1.c
index 0000000000..17917e11ba
--- /dev/null
+++ b/testsuites/tmtests/tm33/task1.c
@@ -0,0 +1,2 @@
+#define TM33
diff --git a/testsuites/tmtests/tm34/task1.c b/testsuites/tmtests/tm34/task1.c
index 0000000000..2f3a888d14
--- /dev/null
+++ b/testsuites/tmtests/tm34/task1.c
@@ -0,0 +1,2 @@
+#define TM34
diff --git a/testsuites/tmtests/tm35/task1.c b/testsuites/tmtests/tm35/task1.c
index 0000000000..4f1ee856d4
--- /dev/null
+++ b/testsuites/tmtests/tm35/task1.c
@@ -0,0 +1,2 @@
+#define TM35
diff --git a/testsuites/tmtests/tm36/task1.c b/testsuites/tmtests/tm36/task1.c
index 0000000000..1dcdcefd64
--- /dev/null
+++ b/testsuites/tmtests/tm36/task1.c
@@ -0,0 +1,2 @@
+#define TM36
2.16.4
