[PATCH 11/13] mptests/mp14: Make MAX_LONG_TEST_DURATION constant
Sebastian Huber
Fri Nov 8 14:02:59 UTC 2019
If there is a real need, it can be made a configuration option again.
Update #3818.
testsuites/mptests/Makefile.am | 4 ++--
testsuites/mptests/configure.ac | 4 ----
testsuites/mptests/mp14/init.c | 6 ++++++
3 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/testsuites/mptests/Makefile.am b/testsuites/mptests/Makefile.am
index 7111e2d109..6ddb2e80cc 100644
--- a/testsuites/mptests/Makefile.am
+++ b/testsuites/mptests/Makefile.am
@@ -231,7 +231,7 @@ mp14_node1_SOURCES = mp14/init.c mp14/exit.c mp14/delay.c \
mp14/evtask1.c mp14/evtmtask.c mp14/pttask1.c mp14/smtask1.c \
mp14/msgtask1.c mp14/system.h
mp14_node1_CPPFLAGS = -DNODE_NUMBER=1 $(AM_CPPFLAGS) $(TEST_FLAGS_mp14) \
- $(support_includes) -DMAX_LONG_TEST_DURATION=$(MAX_LONG_TEST_DURATION)
+ $(support_includes)
mp_tests += mp14_node2
mp_screens += mp14/mp14-node2.scn
mp_docs += mp14/mp14-node2.doc
@@ -239,7 +239,7 @@ mp14_node2_SOURCES = mp14/init.c mp14/exit.c mp14/delay.c \
mp14_node2_CPPFLAGS = -DNODE_NUMBER=2 $(AM_CPPFLAGS) $(TEST_FLAGS_mp14) \
endif
endif
diff --git a/testsuites/mptests/configure.ac b/testsuites/mptests/configure.ac
index 134d6215d3..bf14579442 100644
--- a/testsuites/mptests/configure.ac
+++ b/testsuites/mptests/configure.ac
@@ -28,10 +28,6 @@ RTEMS_CHECK_CPUOPTS([RTEMS_MULTIPROCESSING])
AM_CONDITIONAL(HAS_MP,test "$rtems_cv_RTEMS_MULTIPROCESSING" = "yes")
-MAX_LONG_TEST_DURATION=${MAX_LONG_TEST_DURATION-100}
-AC_ARG_VAR([MAX_LONG_TEST_DURATION],
-[The longest length of time a "long running" test should run])
# BSP Test configuration
RTEMS_TEST_CHECK([mp01])
RTEMS_TEST_CHECK([mp03])
diff --git a/testsuites/mptests/mp14/init.c b/testsuites/mptests/mp14/init.c
index 68359bcd3a..3591e271f8 100644
--- a/testsuites/mptests/mp14/init.c
+++ b/testsuites/mptests/mp14/init.c
@@ -26,6 +26,12 @@
#define CONFIGURE_INIT
#include "system.h"
+ * This used to be a configuration option. If there is a real need, it can be
+ * made a configuration option again.
+#define MAX_LONG_TEST_DURATION 100
uint8_t my_partition[0x30000] CPU_STRUCTURE_ALIGNMENT;
static rtems_timer_service_routine Stop_Test_TSR(
2.16.4
