[PATCH 12/13] ada/samples: Avoid build system defined defines
Sebastian Huber
Fri Nov 8 14:03:00 UTC 2019
Update #3818.
testsuites/ada/samples/base_mp/node1/Makefile.am | 5 +----
testsuites/ada/samples/base_mp/node1/init.c | 2 ++
testsuites/ada/samples/base_mp/node2/Makefile.am | 5 +----
testsuites/ada/samples/base_mp/node2/init.c | 2 ++
4 files changed, 6 insertions(+), 8 deletions(-)
create mode 100644 testsuites/ada/samples/base_mp/node1/init.c
create mode 100644 testsuites/ada/samples/base_mp/node2/init.c
diff --git a/testsuites/ada/samples/base_mp/node1/Makefile.am b/testsuites/ada/samples/base_mp/node1/Makefile.am
index 4916854597..83b1db2894 100644
--- a/testsuites/ada/samples/base_mp/node1/Makefile.am
+++ b/testsuites/ada/samples/base_mp/node1/Makefile.am
@@ -7,15 +7,12 @@ AM_ADAFLAGS += -I$(srcdir)/..
if EXPADA
noinst_PROGRAMS = ada_base_mp_node1
-ada_base_mp_node1_SOURCES = mptest-per_node_configuration.adb
+ada_base_mp_node1_SOURCES = init.c mptest-per_node_configuration.adb
endif
ada_base_mp_node1$(EXEEXT): ../mptest.adb init.o
$(GNATCOMPILE) -margs -a $< -o $@
-init.o: ../../../support/init.c
- $(COMPILE.c) $(AM_CPPFLAGS) -DNODE_NUMBER=1 -I$(srcdir)/.. -c $<
scndir = $(rtems_ada_testsdir)
dist_scn_DATA = ada_base_mp-node1.scn
diff --git a/testsuites/ada/samples/base_mp/node1/init.c b/testsuites/ada/samples/base_mp/node1/init.c
new file mode 100644
index 0000000000..073c033378
--- /dev/null
+++ b/testsuites/ada/samples/base_mp/node1/init.c
@@ -0,0 +1,2 @@
+#define CONFIGURE_MP_NODE_NUMBER 1
+#include "../../../support/init.c"
diff --git a/testsuites/ada/samples/base_mp/node2/Makefile.am b/testsuites/ada/samples/base_mp/node2/Makefile.am
index 277a3940a8..e1a6777ea1 100644
--- a/testsuites/ada/samples/base_mp/node2/Makefile.am
+++ b/testsuites/ada/samples/base_mp/node2/Makefile.am
if EXPADA
noinst_PROGRAMS = ada_base_mp_node2
-ada_base_mp_node2_SOURCES = mptest-per_node_configuration.adb
+ada_base_mp_node2_SOURCES = init.c mptest-per_node_configuration.adb
endif
ada_base_mp_node2$(EXEEXT): ../mptest.adb init.o
- $(COMPILE.c) $(AM_CPPFLAGS) -DNODE_NUMBER=2 -I$(srcdir)/.. -c $<
dist_scn_DATA = ada_base_mp-node2.scn
diff --git a/testsuites/ada/samples/base_mp/node2/init.c b/testsuites/ada/samples/base_mp/node2/init.c
index 0000000000..ea6db06eab
--- /dev/null
+++ b/testsuites/ada/samples/base_mp/node2/init.c
@@ -0,0 +1,2 @@
+#define CONFIGURE_MP_NODE_NUMBER 2
2.16.4
