Performance problem with PyYAML
Fri Nov 8 23:02:30 UTC 2019
On Fri, Nov 8, 2019 at 4:58 PM Chris Johns <chrisj at rtems.org> wrote:
> On 9/11/19 9:52 am, Joel Sherrill wrote:
> > On Fri, Nov 8, 2019 at 4:26 PM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> >     On 9/11/19 2:57 am, Gedare Bloom wrote:
> >     > Ah, pickling makes sense.
> >     > On Fri, Nov 8, 2019 at 4:03 AM Sebastian Huber
> >     > <sebastian.huber at embedded-brains.de
> >     <mailto:sebastian.huber at embedded-brains.de>> wrote:
> >     >> Sorry, for the frequent updates. It turned out to be a very small
> >     >> modification to add a build specification item cache with pickle.
> >     I agree pickle and generation is a good solution.
> > I don't mind processing human readable input to pickle. Let's just keep
> that
> > VERY human readable.
> I can only suggest reviewing the repo and the changes as "VERY human
> readable"
> is subjective. I am not sure how else we can determine readability as it
> is a
> personal thing. :)
Gedare's post earlier to insert "\n\" manually to improve readability takes
something unacceptable to marginally acceptable.
It is subjective but editing long strings of magic input with no normal
line or
paragraph breaks is bad bad bad.
--joel
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191108/cce618ff/attachment.html>
