*.tcfg specification?
    Sebastian Huber
    Mon Nov 11 08:13:16 UTC 2019
Hello,
what is the purpose of the *.tcfg test configuration files? You can
disable compilation of test programs with them, e.g.
exclude: flashdisk01
The "testsuites/rtems-test-check.py" contains a bit more stuff. What is
really needed? I have to map this to the new build system.
One approach is to use the "enabled-by" attribute to disable test
programs on demand, e.g.:
$ cat spec/build/testsuites/samples/RTEMS-BUILD-TEST-SAMPLE-TICKER.yml
active: true
build-type: test-program
cflags: []
cppflags: []
cxxflags: []
derived: false
enabled-by:
- not: DISABLE_TEST_SAMPLE_TICKER
features: c cprogram
header: ''
includes: []
level: 1.15
links: []
normative: true
order: 0
ref: ''
reviewed: null
source:
- testsuites/samples/ticker/init.c
- testsuites/samples/ticker/tasks.c
stlib: []
target: testsuites/samples/ticker.exe
text: ''
type: build
use: []
A BSP can use a "build-type: option" file to disable tests, e.g.
actions:
- disable-tests:
   - SAMPLE/TICKER
   - LIB/FLASHDISK01
An open issue is how and if we should set other states, e.g. expected to
fail. We could generate a "bsp/teststate.h" file for each BSP which
optionally defines for each test a state other than "pass", e.g.
#define TEST_SAMPLE_TICKER_STATE RTEMS_TEST_STATE_FAIL
This could be also realized with a special option action:
actions:
- set-test-states:
   - SAMPLE/TICKER: disable
   - LIB/FLASHDISK01: xfail
The "set-test-states" action can validate if the state exists. I can use
the "enable-by" for "disable" states and the "bsp/teststate.h" file for
other states.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
