psxfenv01 fails to compile for RISCV
Chris Johns
chrisj at rtems.org
Tue Nov 19 01:18:52 UTC 2019
On 18/11/19 5:28 pm, Sebastian Huber wrote:
> On 11/11/2019 23:35, Chris Johns wrote:
>> On 12/11/19 12:10 am, Sebastian Huber wrote:
>>> On 11/11/2019 07:04, Sebastian Huber wrote:
>>>> On 09/11/2019 19:57, Joel Sherrill wrote:
>>>>> I thought I fixed this in the upstream newlib.
>>>>> https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=commit;h=9e06ba1ac310c5a2392bb9d150e4686bbb118d6c
>>>>> Either I didn't really fix it or your newlib is a bit old.
>>>>> Did Sebastian bump 5's newlib recently? I recall a binutils bump.
>>>> No, sorry. I planned to do the GCC 7.5 and Newlib update in one rush.
>>> I updated right now the RSB to pick up the latest Newlib.
>> Libbsd is failing for the bbb (plus the other BSPs in 5/bsps/*). The build
>> archive shows the failures ...
>> https://lists.rtems.org/pipermail/build/2019-November/008223.html
>> The error is ...
>> ../../testsuite/syscalls01/test_main.c:174:23: error: 'IPPROTO_SEP' undeclared
>> here (not in a function); did you mean 'IPPROTO_EGP'?
>> { PF_INET, SOCK_RAW, IPPROTO_SEP, 0 },
>> IPPROTO_EGP
> This should be fixed now.
Thanks. I have moved the RSB libbsd to build the 5-freebsd-12 branch. The BSP
vertical stack is building again.
