sparc-rtems-gdb doesn't recognize target "sim"
Shubham Bhagat shubhambhagat111 at yahoo.com
Wed Nov 13 09:36:52 UTC 2019
 Thank you for the help! sparc-rtems5-sis works well for me.
    On Wednesday, 13 November, 2019, 2:46:02 pm IST, Jiri Gaisler <jiri at gaisler.se> wrote:
 On 11/13/19 9:48 AM, Vaibhav Gupta wrote:
You can also use "sis"
  1- Open Terminal 1 and write:
  $ sparc-rtems5-sis -gdb         # It will print 'gdb: listening on port 1234'.         # Note you can define port number with '-port' option.
  2-Open Terminal 2 and write:
  $ sparc-rtems5-gdb hello.exe         # gdb asks for several inputs                 $ target extended-remote localhost:1234                 $ load                 $ r
  Use the notes here: https://github.com/VARoDeK/MyNotes/blob/master/RTEMS/run_a_testsuite.md
Note that the procedure for RISC-V can be exactly the same, usings riscv-rtems5-sis and the RTEMS griscv bsp ..
Jiri.
  On Wed, Nov 13, 2019, 1:06 PM Vijay Kumar Banerjee <vijaykumar9597 at gmail.com> wrote:
  On Wed, Nov 13, 2019 at 12:39 AM Shubham Bhagat <shubhambhagat111 at yahoo.com> wrote:
   Hello everyone,  I've been trying to  run the hello world example in source tree to get started with sparc/erc32 but after building all that is required ( followed POSIX Compliance (Getting started challenge for RTEMS beginners)). I  followed all the commands. But, when gdb starts and I set "tar sim" it says:
  Undefined target command: "sim".  Try "help target".
  I also tried running hello.exe from the testsuites sample using sparc-rtems5-run but it doesn't recognize the  command. NOTE: The make and make install steps didn't finish with a "SUCCESS" or anything. They exited without showing any  error.
  Am I missing out anything here?
 I guess this thread will be helpful for you: https://lists.rtems.org/pipermail/devel/2019-September/055671.html
Ravindra Kumar Meena
POSIX stands for Portable Operating System Interface for uni-X. POSIX Compliance allows us to port  the source co...
 devel mailing list
 devel at rtems.org
 http://lists.rtems.org/mailman/listinfo/devel
 devel mailing list
 devel at rtems.org
devel mailing list
devel at rtems.org
devel mailing list
devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191113/d36a82f0/attachment.html>
