sparc-rtems-gdb doesn't recognize target "sim"
Jiri Gaisler
jiri at gaisler.se
Wed Nov 13 09:15:48 UTC 2019
On 11/13/19 9:48 AM, Vaibhav Gupta wrote:
> You can also use "sis"
> 1- Open Terminal 1 and write:
> $ sparc-rtems5-sis -gdb
> # It will print 'gdb: listening on port 1234'.
> # Note you can define port number with '-port' option.
> 2-Open Terminal 2 and write:
> $ sparc-rtems5-gdb hello.exe
> # gdb asks for several inputs
> $ target extended-remote localhost:1234
> $ load
> $ r
> Use the notes here: https://github.com/VARoDeK/MyNotes/blob/master/RTEMS/run_a_testsuite.md
Note that the procedure for RISC-V can be exactly the same, usings riscv-rtems5-sis and the RTEMS griscv bsp ..
Jiri.
> On Wed, Nov 13, 2019, 1:06 PM Vijay Kumar Banerjee <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
> On Wed, Nov 13, 2019 at 12:39 AM Shubham Bhagat <shubhambhagat111 at yahoo.com <mailto:shubhambhagat111 at yahoo.com>> wrote:
> Hello everyone,
> I've been trying to run the hello world example in source tree <https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start#Running> to get started with sparc/erc32 but after building all that is required ( followed POSIX Compliance (Getting started challenge for RTEMS beginners) <https://rmeena840.github.io/Third-Post/>). I
> followed all the commands. But, when gdb starts and I set "tar sim" it says:
> Undefined target command: "sim". Try "help target".
> I also tried running hello.exe from the testsuites sample using sparc-rtems5-run but it doesn't recognize the command.
> NOTE: The make and make install steps didn't finish with a "SUCCESS" or anything. They exited without showing any error.
> Am I missing out anything here?
> I guess this thread will be helpful for you:
> https://lists.rtems.org/pipermail/devel/2019-September/055671.html
> Ravindra Kumar Meena
> POSIX stands for Portable Operating System Interface for uni-X. POSIX Compliance allows us to port the source co...
> devel mailing list
> devel at rtems.org <mailto:devel at rtems.org>
> devel mailing list
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191113/fdd2cad5/attachment-0001.html>
