RFC: Building RTEMS/RISC-V with LLVM/Clang
Wed Nov 13 14:48:00 UTC 2019
Hello Hesham,
On 23/10/2019 15:50, Hesham Almatary wrote:
> Hi,
> I submitted a RFC patch series to be able to build RTEMS/RISC-V with
> LLVM/Clang. I'd appreciate your feedback on that.
> A sample configure line to build RTEMS with LLVM/Clang is:
> ../rtems/configure --target=riscv-rtems6
> --enable-rtemsbsp=rv64imafdc_clang  CC_FOR_TARGET="clang"
> CXX_FOR_TARGET="clang++" AR_FOR_TARGET="llvm-ar"
Could you provide me a 64-bit Linux binary installation of your clang
toolchain so that I can test it locally?
> NEWLIB_SYSROOT env variable needs to point to where newlib is
> installed while configuring/building RTEMS.
To which directory NEWLIB_SYSROOT in the /opt/rtems/5 installation tree
must this point?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
