RFC: Building RTEMS/RISC-V with LLVM/Clang
Hesham Almatary
hesham.almatary at cl.cam.ac.uk
Wed Nov 13 15:32:37 UTC 2019
On Wed, 13 Nov 2019 at 14:48, Sebastian Huber
> Hello Hesham,
> On 23/10/2019 15:50, Hesham Almatary wrote:
> > Hi,
> > I submitted a RFC patch series to be able to build RTEMS/RISC-V with
> > LLVM/Clang. I'd appreciate your feedback on that.
> > A sample configure line to build RTEMS with LLVM/Clang is:
> > ../rtems/configure --target=riscv-rtems6
> > --enable-rtemsbsp=rv64imafdc_clang CC_FOR_TARGET="clang"
> > CXX_FOR_TARGET="clang++" AR_FOR_TARGET="llvm-ar"
> Could you provide me a 64-bit Linux binary installation of your clang
> toolchain so that I can test it locally?
https://drive.google.com/file/d/1I0WHOMT2CCkxn_9mz7_WxEXXgCp6yNab/view?usp=sharing
You can you also to build it yourself from source here
https://github.com/CTSRD-CHERI/llvm-project
> > NEWLIB_SYSROOT env variable needs to point to where newlib is
> > installed while configuring/building RTEMS.
> To which directory NEWLIB_SYSROOT in the /opt/rtems/5 installation tree
> must this point?
riscv-rtems5. Or the corresponding multilib directory for your RISC-V BSP.
You'll also need to copy or symlink libgcc.a to
NEWLIB_SYSROOT/lib/libclang_rt.builtins-riscv32.a
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
