sparc-erc32 testsuites failures
Niteesh gsnb.gn at gmail.com
Mon Nov 18 07:22:27 UTC 2019
I have updated the doc to use erc32-sis, and attached the patch file in
this mail. Can someone review it.
On Mon, Nov 18, 2019 at 12:07 PM Niteesh <gsnb.gn at gmail.com> wrote:
> I know this, but the docs are not updated so should I send a pull request?
> On Mon, Nov 18, 2019 at 12:06 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> On Mon, Nov 18, 2019, 11:12 AM Niteesh <gsnb.gn at gmail.com> wrote:
>>> On Mon, Nov 18, 2019 at 3:17 AM Joel Sherrill <joel at rtems.org> wrote:
>>>> The instructions are out of date by a couple of months. The SPARC
>>>> Instruction Simulator (sis) has seen significant enhancements and it's now
>>>> a standalone program. It is not enabled as a built-in with gdb because
>>>> that's some very old version of sis. The new version has symmetric
>>>> multiprocessing and support for the RISC-V.
>>>> Those instructions worked for a LONG time but need to be updated to
>>>> reflect the recent changes with SIS.
>>>> If you used rtems-tester, it should work. And looking at the .ini file
>>>> for this bsp will sure you have to just run programs with the simulator. My
>>>> recollection is that by adding -gdb argument, you can attached to it as a
>>>> remote debugger.
>>> Yes. And I also faced this problem (in my case it was riscv)and i guess
>> this question was asked by others also on devel.
>> I simply used these steps:
>> Open Terminal 1:
>> $ sparc-rtems5-sis -gdb
>>         # It will print 'gdb: listening on port 1234'.
>>         # Note you can define port number with '-port' option.
>> Open Terminal 2:
>> $ sparc-rtems5-gdb hello.exe
>>         # gdb asks for several inputs
>>                 $ target extended-remote localhost:1234
>>                 $ load
>>                 $ r
>> You will see output in Terminal 1.
>>> I would like to update the docs for this, Can I proceed? I am planning
>>> to change the cmd to use erc-sis instead of erc. And also the build your
>>> application section is incomplete, can I add the instruction to modify a
>>> test program and build it in this section?
>>>> BTW I know it's a way too early for GSOC but I have anyway attached the
>>>>> patch for hello world.
>>>> What type projects are you interested in?
>>> I am interested in driver development and BSP support.
>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191118/521e93c6/attachment-0001.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191118/521e93c6/attachment-0001.bin>
