sparc-erc32 testsuites failures
Niteesh
gsnb.gn at gmail.com
Mon Nov 18 06:37:34 UTC 2019
I know this, but the docs are not updated so should I send a pull request?
On Mon, Nov 18, 2019 at 12:06 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> On Mon, Nov 18, 2019, 11:12 AM Niteesh <gsnb.gn at gmail.com> wrote:
>> On Mon, Nov 18, 2019 at 3:17 AM Joel Sherrill <joel at rtems.org> wrote:
>>> The instructions are out of date by a couple of months. The SPARC
>>> Instruction Simulator (sis) has seen significant enhancements and it's now
>>> a standalone program. It is not enabled as a built-in with gdb because
>>> that's some very old version of sis. The new version has symmetric
>>> multiprocessing and support for the RISC-V.
>>> Those instructions worked for a LONG time but need to be updated to
>>> reflect the recent changes with SIS.
>>> If you used rtems-tester, it should work. And looking at the .ini file
>>> for this bsp will sure you have to just run programs with the simulator. My
>>> recollection is that by adding -gdb argument, you can attached to it as a
>>> remote debugger.
>> Yes. And I also faced this problem (in my case it was riscv)and i guess
> this question was asked by others also on devel.
> I simply used these steps:
> Open Terminal 1:
> $ sparc-rtems5-sis -gdb
> # It will print 'gdb: listening on port 1234'.
> # Note you can define port number with '-port' option.
> Open Terminal 2:
> $ sparc-rtems5-gdb hello.exe
> # gdb asks for several inputs
> $ target extended-remote localhost:1234
> $ load
> $ r
> You will see output in Terminal 1.
>> I would like to update the docs for this, Can I proceed? I am planning to
>> change the cmd to use erc-sis instead of erc. And also the build your
>> application section is incomplete, can I add the instruction to modify a
>> test program and build it in this section?
>>> BTW I know it's a way too early for GSOC but I have anyway attached the
>>>> patch for hello world.
>>> What type projects are you interested in?
>> I am interested in driver development and BSP support.
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191118/c4cd19c7/attachment-0001.html>
