[PATCH] user/start/bsp-test.rst: Changed bsp to erc32-sis.
Niteesh
gsnb.gn at gmail.com
Tue Nov 19 17:25:15 UTC 2019
I am new to this, so can you please elaborate on the steps.
On Tue, Nov 19, 2019 at 10:16 PM Gedare Bloom <gedare at gwmail.gwu.edu> wrote:
> Hi Niteesh,
> Can you please provide a patch with your name on the authorship for
> tracking copyright purpose?
> On Mon, Nov 18, 2019, 2:29 AM <gsnb.gn at gmail.com> wrote:
>> From: gs-niteesh <gsnb.gn at gmail.com>
>> This commit (id=abc540105d10ddc9cad7de3c7ac0a9aa209ac828) removed
>> the target sim from gdb, but the doc was not updated, so on running
>> rtems test as per the doc caused failures, this commit changes it
>> use the erc32-sis which used standalone sis simulator.
>> user/start/bsp-test.rst | 2 +-
>> 1 file changed, 1 insertion(+), 1 deletion(-)
>> diff --git a/user/start/bsp-test.rst b/user/start/bsp-test.rst
>> index 5278375..8a14862 100644
>> --- a/user/start/bsp-test.rst
>> +++ b/user/start/bsp-test.rst
>> @@ -21,7 +21,7 @@ Just run this command:
>> .. code-block:: none
>> cd $HOME/quick-start/build/b-erc32
>> - rtems-test --rtems-bsp=erc32 --rtems-tools=$HOME/quick-start/rtems/5
>> + rtems-test --rtems-bsp=erc32-sis
>> --rtems-tools=$HOME/quick-start/rtems/5 .
>> This command should output something like this (omitted lines are
>> denoted by
>> ...). In this output the base directory :file:`$HOME/quick-start` was
>> replaced
>> 2.17.1
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191119/2bda2e01/attachment.html>
